Results 1 to 22 of 22
    Reputation: ucdengboss's Avatar
    Low angle POV GoPro mounting
    I have shot some video with my GoPro mounted along the bottom of the bike (see video below), however I do not like having the front tire so centered in the video. Is there a way to mount on the fork? Or perhaps on bike but offset to the side a little bit? I want some low angles, just not dead centered behind the front tire. Thanks in advance.
    <iframe width="640" height="360" src="//www.youtube.com/embed/TvWhebI5AcQ" frameborder="0" allowfullscreen></iframe>
    Certifiably Crazy
    Reputation: Carloswithac's Avatar
    Feb 2012
    You could try a ram mount on the fork. I've used one with success.
    2013 Felt Edict Nine
    Reputation: shiggy's Avatar
    Dec 1998
    Re: Low angle POV GoPro mounting
    Quote Originally Posted by Carloswithac View Post
    I do that, too, with my Contour on a RAM roll cage mount. Love the camera angles.
    mtbtires.com
    2006 Yeti AS-X
    Reputation: Lawson Raider's Avatar
    Mount on the bottom tube but have the mount on the left or ride side versus on the bottom of the tube. Then you need a 90 degree mount and you are set. Here is example footage I did with mine.
    <iframe width="560" height="315" src="//www.youtube.com/embed/GYbowag2GDs" frameborder="0" allowfullscreen></iframe>
    I don't use Strava. Don't need an application to tell me I am slow because I already know.
    Quote Originally Posted by Lawson Raider View Post
    &lt;iframe width="560" height="315" src="//www.youtube.com/embed/GYbowag2GDs" frameborder="0" allowfullscreen&gt;&lt;/iframe&gt;
    That's just about the perfect angle I am looking for.
    May 2013
    go pro mounts
    I have made a mount from alu .. may be this give you an idea ...
    Jeroen
    i don't give a shift
    Reputation: collideous's Avatar
    Here's my solution: GoPro tripod mount, a piece of 1" tubing, a 1" stem cap, a 1/4"-20 bolt and finally a universal velcro mount for flashlights.
    blogging @29in.CH
    Reputation: XC Mike's Avatar
    Sep 2004
    Quote Originally Posted by collideous View Post
    Nice Work!!
    Got a video using it?
    Quote Originally Posted by XC Mike View Post
    Nothing all that recent, but here's one where I used the above shown mount with the camera attached to the seatpost.
    blogging @29in.CH
    newb
    Jun 2013
    i like those fork mounted options Carloswithac and Lawson Raider . nice spot! I'll have to try it out.
    I've got a boom pole that i mount on the back of my frame, gives a pretty dynamic look to the shots. What do you guys think?
    This is a couple years old, but I had made a mount that attaches to water bottle cage bolts. It is out of the way of pedaling and works pretty good.
    2006 Yeti AS-X
    Here is a side picture of the mount.
    I have a k-edge handlebar mount, and a piece of 1-1/4" aluminum counterbored to fit my rear axle bolt. That allows me to position the camera anywhere within say a 4" radius (or whatever the length of that mount is) of the rear axle.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    my knee would break that right off mounted there! don't you end up whacking it?
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    2006 Yeti AS-X
    Quote Originally Posted by thomllama View Post
    Nope. Never whacked it once. It sits a little in front of where the rotational radius of my legs go.
    2006 Yeti AS-X
    Quote Originally Posted by jduffett View Post
    That's a cool mount.
    Sep 2004
    Nice!! post some pics of the mount if you have them handy
    Sorry, I don't have any pics, and I don't have the pieces handy, but here's what it looks like:
    The K-edge mount is this one: GO BIG Pro Handlebar Mount - GoPro™ Cycling Mounts - K-EDGE GO BIG Mounts
    The adapter is just a piece of 1-1/4" aluminum bar stock with a counterbore in it for the axle bolt. One downside to this arrangement is that if you hang the camera on the bottom on the left side of the bike, if you hit the camera on anything, and the mount bolts are tight, the mount will spin and loosen your axle bolt! I also lose a small amount of thread engagement this way, but not a big deal. This design won't work for a QR or thru-axle unless you make the material thickness under the bolt head very thin.
    Rabid Lana fan
    I use a pedco ultraclamp mount all over the bike for different angles. About 22 bux on Amazon.
    <iframe src="//player.vimeo.com/video/92586216?color=ffffff" width="600" height="337" frameborder="0" webkitallowfullscreen mozallowfullscreen allowfullscreen></iframe> <p><a href="http://vimeo.com/92586216">April-2014 Huntsville AL</a> from <a href="http://vimeo.com/morgan48">Clay Morgan</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
    Dec 1998
    &lt;iframe src="//player.vimeo.com/video/92586216?color=ffffff" width="600" height="337" frameborder="0" webkitallowfullscreen mozallowfullscreen allowfullscreen&gt;&lt;/iframe&gt; &lt;p&gt;&lt;a href="http://vimeo.com/92586216"&gt;April-2014 Huntsville AL&lt;/a&gt; from &lt;a href="http://vimeo.com/morgan48"&gt;Clay Morgan&lt;/a&gt; on &lt;a href="https://vimeo.com"&gt;Vimeo&lt;/a&gt;.&lt;/p&gt;
    I broke two of those mounts. The RAM roll bar mounts are stronger and more stable. Not as easy to move as the RAM uses a hose clamp, but it is also lower profile and can be used in more locations.
    mtbtires.com
    Sep 2004
    Something I put together, cheap and easy using the stock frame mounts
    Fandango Mount - YouTube
    Great stuff guys. Keep the ideas coming.
  1. What's the "correct" mounting angle when using a GoPro & chest mount?
    By AuhsojoshuA in forum Videos and POV Cameras
    Last Post: 09-08-2013, 05:57 PM
  2. Gopro mounting tip :)
    By sjoseth in forum Videos and POV Cameras
    Last Post: 08-30-2013, 12:27 PM
  3. Different gopro angle
    By dillboy in forum Vermont, New Hampshire, Maine
    Last Post: 11-21-2012, 01:06 PM
  4. GoPro Mounting
    By girgl in forum Videos and POV Cameras
    Last Post: 12-12-2011, 04:54 PM
  5. Replies: 1
    Last Post: 07-17-2011, 11:10 AM
