Results 1 to 11 of 11
    Reputation: Simpledesign's Avatar
    First time with the camera
    Need to find a way to reduce the vibrations.....didn't have a helmet mount and the flex strap kept slipping down
    '12 Trek Marlin Signature Green
    '13 Santa Cruz Tallboy LT Gulf Blue/Orange
    Reputation: skiahh's Avatar
    I've had very good luck with the flex strap. A Lefty fork will give you a much clearer view.
    My mount:
    Video perspective:
    Ute Valley Ride - YouTube
    www.teamnavycycling.org
    10 Pivot Mach 429
    09 Felt Nine Race
    03 Litespeed Tuscany
    First ride with Countour+ 2 from Kelly C. on Vimeo.
    Here another one in 1080p....I also had the camera in the housing which probably didn't help (paranoia)
    Almost the same location....
    Yeah, you don't need the weight of the housing with the Contours. They're pretty darn rugged.
    If you can move it up a bit, you'll get a slightly higher perspective and get the fork crown out of the bottom of your shot. Cables will still be an issue, though. Before I put my Leffty on, I had a mass of cables in the shot that made me run it as a helmet mount mostly. A bonus of the Lefty was that it moved all the cables to the other side, leaving a clear view forward.
    10 Pivot Mach 429
    09 Felt Nine Race
    Second time out....changed some settings and mounting. Much more stable
    White River....take 2 from Kelly C. on Vimeo.
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    that last one is nice...
    don't bother with the helmet mount, it's crappy.. better off with the "profile" mount and put it just above the temple of your helmet... I actually zip tied it .. had to notch out little spots so the Cam can slide by the ties but it's much better and firmer mounting. WAY better and tighter to your head also. Issue is most regular bike helmets aren't made rigid, they use a "cage" in the rear and it allows the helmet and cam to bobble a bit.. unless you are using a full face.
    Also having a cable or a bit of the fork isn't bad, give perspective and interest to the wide angle vids which is highly lacking, but it is nice to have very little of it on an edge.. I get too much myself and thing I'm going to add something to pad the flex mount out another 1/2-1 inch to have the tire and maybe a cable off to just the very edge of the shot....
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    I have some video with the helmet mount...it just looks like a giant walking through the woods. I am much happier with the bike perspective
    Sent from my Samsung Galaxy SIII using Tapatalk 2
    Dec 2012
    it is stable ?
    Quote Originally Posted by adcolgrz View Post
    it is stable ?
    Compared to the first video....the helmet mount video is uploading now
    the helmet mount
Hot Deals
Contests
Latest Mountain Bike Articles
