• 11-30-2012
    Simpledesign
    First time with the camera
    <iframe width="960" height="540" src="http://contour.com/stories/second-clip--2/embed?map=false&width=960px&height=540px" frameborder="0"></iframe>
    Need to find a way to reduce the vibrations.....didn't have a helmet mount and the flex strap kept slipping down :madman:
  • 11-30-2012
    skiahh
    I've had very good luck with the flex strap. A Lefty fork will give you a much clearer view.
    My mount:
    Video perspective:
    Ute Valley Ride - YouTube
  • 11-30-2012
    Simpledesign
    <iframe src="http://player.vimeo.com/video/54564762?badge=0&amp;color=c9ff23" width="500" height="281" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/54564762">First ride with Countour+ 2</a> from <a href="http://vimeo.com/user14611167">Kelly C.</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
    Here another one in 1080p....I also had the camera in the housing which probably didn't help (paranoia)
  • 11-30-2012
    Simpledesign
    Almost the same location....
  • 12-01-2012
    skiahh
    Yeah, you don't need the weight of the housing with the Contours. They're pretty darn rugged.
    If you can move it up a bit, you'll get a slightly higher perspective and get the fork crown out of the bottom of your shot. Cables will still be an issue, though. Before I put my Leffty on, I had a mass of cables in the shot that made me run it as a helmet mount mostly. A bonus of the Lefty was that it moved all the cables to the other side, leaving a clear view forward.
  • 12-06-2012
    Simpledesign
    Second time out....changed some settings and mounting. Much more stable
    <iframe src="http://player.vimeo.com/video/55058492?badge=0&amp;color=c9ff23" width="500" height="281" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/55058492">White River....take 2</a> from <a href="http://vimeo.com/user14611167">Kelly C.</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
  • 12-06-2012
    thomllama
    that last one is nice...
    don't bother with the helmet mount, it's crappy.. better off with the "profile" mount and put it just above the temple of your helmet... I actually zip tied it .. had to notch out little spots so the Cam can slide by the ties but it's much better and firmer mounting. WAY better and tighter to your head also. Issue is most regular bike helmets aren't made rigid, they use a "cage" in the rear and it allows the helmet and cam to bobble a bit.. unless you are using a full face.
    Also having a cable or a bit of the fork isn't bad, give perspective and interest to the wide angle vids which is highly lacking, but it is nice to have very little of it on an edge.. I get too much myself and thing I'm going to add something to pad the flex mount out another 1/2-1 inch to have the tire and maybe a cable off to just the very edge of the shot.... :skep:
  • 12-06-2012
    Simpledesign
    I have some video with the helmet mount...it just looks like a giant walking through the woods. I am much happier with the bike perspective
    Sent from my Samsung Galaxy SIII using Tapatalk 2
  • 12-07-2012
    adcolgrz
    it is stable ?
  • 12-07-2012
    Simpledesign
    Originally Posted by adcolgrz View Post
    it is stable ?
    Compared to the first video....the helmet mount video is uploading now
  • 12-07-2012
    Simpledesign
    <iframe width="960" height="540" src="http://contour.com/stories/helmet-mount--4/embed?map=false&width=810px&height=465px" frameborder="0"></iframe>
    the helmet mount
