After almost losing (and / or destroying) my GoPro Wide and breaking my only seat-post mount, I decided to build a rock-solid seat-post mount and a new handlebar mount. I should be able to test them out this weekend and post a video.
Anyway, here are my two new mounts - made with a few dollars worth of hardware store PVC parts, SS clamps and 5-minute epoxy....
P.S.
I am always interested in seeing new mounts, so please post your photos. I know that Lee and others have posted some cool ones in other forums.
I made a mount by attaching a flat adhesive GoPro mount with two bolts through a flat-topped headset topcap. Works ok, but there is some high frequency vibration. Nice and smooth when the bike is in the air. Can't see the stem in shot when using 720p 16:9 mode. I will post pics when I get to 10 posts.
I also made one from an old Vistalite handlebar mount for attaching to the seatpost. This one works really well. I tried it on the handlebars but with less success.
Strangely, on playback, even when the image is jumping up and down with vibration, the lens flare is perfectly smooth.
I will definitely get a zipline setup happening, but a very dodgy one, might even use foam to brake it as it hits the tree the line is attached to.
I am quite a fan of leaving a GoPro on 2sec still mode, there are usually 2 or 3 great shots out of the 1000 or so it takes. Much like most people use "normal" digital still cameras.
Just ordered a GoPro finally today. Went with the motorsports package as the camera will be seeing multi-sport use very soon.
I definitely will be making some mounts for my bike, may even start dummy'ing some ideas into cardboard tonight and picking up some materials. A slew of custom mounts will be used for my quad as well, I'll post some mount-builds once it happens.
Just got my gopro hd, i was wondering if i attached my gopro to a hardtail bike seatpost and rode it offroad, would the vibrations break the camera in the long run?
I was just curiouse because shurely the camera is taking a bit of a shake in!
The GoPro cameras are pretty damn tough and given that they don't have any moving parts it should be fine for that set-up. I think the problem will more likely be that the video will have a lot of vibration in it so you aren't going to want to watch hours of it set up like that. Setting up on your seat post will be good to get a different angle every now and then to create different angles for editing videos but I don't think you'll want to use this set-up as your primary shot.
If what you are riding over is smooth enough to get a half decent shot then I am sure the GoPro will handle many hours of that level of vibration.
It's just amazing that now we can attached hd gear to bikes and load up to the web - for all to see and even better is the help supplied here - I bow to you all :thumbsup:
I have been looking at ideas on here and trying to think of a stable mount on my helmet. This is my attempt at a scorpion, unicorn what ever you want to call it. I was just testing so yes that is a brush on my head ;-) I will be using a carbon pole with a counter weight for the finished mount. This was just a test for angles and pole length.
Here's how I mounted my Go Pro to my stem. The first problem was keeping it light, and how to use the provided mount on a round stem. Since I am into building RC planes, I had some extra balsa wood laying around. I thought if I could stick some on the edges on the mount, I could sort of make a semi radius to match the diameter of the stem if I used enough 3M outdoor double sided tape. Meh, my first try.
That Gopro tripod mount is a waste of money and a pain to use. Described below might be the easiest project ever for a homebrew Gopro mount---and you already have it.... So I hope you saved that large plastic square base that the camera was mounted on when you bought it.
You can cut it down. In my case I used a bandsaw. I cleaned up the edges with a belt sander
Drill a hole. If you have a 1/4 tap, drill it smaller than 1/4 inch and tap it. If not, drill it .265" get a 1/4 -20 nut.
Don't forget to post a few pictures when you are done.
Related Threads
Mountain Bike Reviews Forum
15.4M posts
515.2K members
Since 1990
