Page 2 of 3 FirstFirst 123 LastLast
Results 101 to 200 of 213
  1. #101
    Very slick, Nick.
    I will definitely get a zipline setup happening, but a very dodgy one, might even use foam to brake it as it hits the tree the line is attached to.
    I am quite a fan of leaving a GoPro on 2sec still mode, there are usually 2 or 3 great shots out of the 1000 or so it takes. Much like most people use "normal" digital still cameras.
    Come on 10 posts!
  2. #102
    Quote Originally Posted by BiciMapas View Post
    Great idea. What did you use to cut the plexiglass?
    I used a dremel with a cut off blade, and sandpaper to round over the edges.
  3. #103
    Reputation: illbedeadbefore30's Avatar
    "Nothing ventured, nothing gained.
  4. #104
    Reputation: Iridethedirt's Avatar
    Quote Originally Posted by NastyNick View Post
    After cruising through this thread; I figured I'd better upload some pics and vids of my homemade mounts.
    First mount is just a short boom i made from some aluminum shower channel, a chunk of old handle bar, and a recycled lock on grip.
    Next is a chest mount. I used a 3M GoPro mount on the front of my 661 Coresaver. I was concerned about 3M mount coming off; but has put up with alot of use with no issues so far.
    <object width='500' height='375'><param name='allowFullScreen' value='true' /><param name='allowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/185314/l/' /><embed src='http://www.pinkbike.com/v/185314/l/' type='application/x-shockwave-flash' width='500' height='375' allowFullScreen='true' allowScriptAccess='always'></embed></object><p><a href="http://www.pinkbike.com/video/185314/">Chest Mount GoPro</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    Last is what I call the unicorn or narwhal helmet mount.
    <object width='500' height='375'><param name='allowFullScreen' value='true' /><param name='allowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/186908/l/' /><embed src='http://www.pinkbike.com/v/186908/l/' type='application/x-shockwave-flash' width='500' height='375' allowFullScreen='true' allowScriptAccess='always'></embed></object><p><a href="http://www.pinkbike.com/video/186908/">GoPro, Unicorn Helmet Mount</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    you might want to make sure that unicorn mount will break free decently easy, or you might be breaking your neck instead of protecting your head if you fall, and need to make use of the helmet.
  5. #105
    www.swampclub.org
    Reputation: anthonyi's Avatar
    Nov 2008
    People,
    Do we really need to see the same pictures over and over and over and over and over?
    "Wish not so much to live long, as to live well." - Benjamin Franklin
  6. #106
    Yes, that's fonetic
    Reputation: whoda*huck's Avatar
    Feb 2005
    Quote Originally Posted by anthonyi View Post
    People,
    Some haven't clued into editing quotes.
  7. #107
    www.swampclub.org
    Nov 2008
    Quote Originally Posted by whodaphuck View Post
    Yep.
  8. #108
    People,
    Obviously.
  9. #109
    Oct 2010
    Just ordered a GoPro finally today. Went with the motorsports package as the camera will be seeing multi-sport use very soon.
    I definitely will be making some mounts for my bike, may even start dummy'ing some ideas into cardboard tonight and picking up some materials. A slew of custom mounts will be used for my quad as well, I'll post some mount-builds once it happens.
    Love the ideas so far.
  10. #110
    Reputation: Uncle Stinky's Avatar
    Good info here thanks
  11. #111
    www.swampclub.org
    Nov 2008
    Quote Originally Posted by uncle stinky View Post
    good info here thanks
  12. #112
    great tips! thanks!
  13. #113
    Dec 2010
    Hi
    Just got my gopro hd, i was wondering if i attached my gopro to a hardtail bike seatpost and rode it offroad, would the vibrations break the camera in the long run?
    I was just curiouse because shurely the camera is taking a bit of a shake in!
    Also is it worth updating my firmware?
    Yours sincerely
    Wayne
  14. #114
    Quote Originally Posted by frehgv View Post
    Hi
    Yours sincerely
    Wayne
    The GoPro cameras are pretty damn tough and given that they don't have any moving parts it should be fine for that set-up. I think the problem will more likely be that the video will have a lot of vibration in it so you aren't going to want to watch hours of it set up like that. Setting up on your seat post will be good to get a different angle every now and then to create different angles for editing videos but I don't think you'll want to use this set-up as your primary shot.
    If what you are riding over is smooth enough to get a half decent shot then I am sure the GoPro will handle many hours of that level of vibration.
    Matt Fitzhardinge
    Launch Helmet Cams
    We'll beat any online price for mtbr.com members!
  15. #115
    Dec 2010
    Quote Originally Posted by Launch Helmet Cams View Post
    Thanks for reply
    Is it advisable to do gopro firmware update?
    Yours sincerely
    Wayne
  16. #116
    Yep, it's always a good idea to be running the latest firmware on your GoPro. You will definitely need the latest version of the firmware if you want to run it in upside down mode which you may need to do if you use the seatpost mount.
    Matt Fitzhardinge
    Launch Helmet Cams
  17. #117
    Dec 2010
    What if i'm already happy with the way my camera is, does the firmware improve recording quality?
    If i don't install it is it bad for the gopro cam in the future?
    I already have the upside down mode aswell.. does this mean i could have the latest version?
    Thanks for replies
    Yours sincerely
    wayne
  18. #118
    www.swampclub.org
    Nov 2008
    Hi
    Yours sincerely
    Wayne
    I use my seat post mount all the time on some very rough trails. No problems.
  19. #119
    Dec 2010
    Do you worry about the firmware updates?
    I don't see them being any good to me..
    The gopro hd has everything i really need. Does the firmware improve video quality?
    When ever i do stuff like updating the firmware i always have problems!
    Thanks for reply
    Yours sincerely
    Wayne
  20. #120
    Thanks for reply
    Yours sincerely
    Wayne
    You dont really need the update, it won't effect the video quality. but if you use it upside down or for 3D you may want to update, also I think it also makes it so you can use some of the newer accesories like the battery bac pac and the video viewer
  21. #121
    Dec 2010
    Quote Originally Posted by simple78 View Post
    Why do i need to update for the upside down mode?
    Does the gopro not come with it? because i've got upside down mode
    thanks for all the helpfull info everyone
    Yours sincerely
    Wayne
  22. #122
    Dec 2010
    Hey
    I can't seem to find my sierial number on my gopro is it the one on a silver sticker with barcode when you take the battery out?
    many thanks guys
  23. #123
    Yours sincerely
    Wayne
    If you allready have the Upside down mode you probably allready have the current firmware.
    My gopro did not have the upside down mode but I got it over a year ago.
  24. #124
    www.swampclub.org
    Nov 2008
    Thanks for reply
    Yours sincerely
    Wayne
    Always do your firmware updates. They usually include bug fixes.
  25. #125
    Dec 2010
    How often do they bring out new firmwares?
    But sometimes they can bring bugs!!!
  26. #126
    www.swampclub.org
    Nov 2008
    All of your questions can be answered here:
    GoPro Customer Support - Contact Us for Knowledge & Instruction
  27. #127
    how about a backpack mount to get a good third person shot of you riding?
    I dig the narwall mount
  28. #128
    Dec 2010
    Turns out i never needed to do the firmware update
    Checked it online if its a bigger sirial number than the one it said on there website
    its already done!!!
    Thanks everyone!
  29. #129
    Reputation: red5jedi's Avatar
    Feb 2006
    Hi
    You will be surprise how stable it will look. Here's one I did.
    http://www.cyclingtrek.org/video/Cedro%20ST%202010.wmv
  30. #130
    good post
  31. #131
    stunning video and an excellent thread.
    It's just amazing that now we can attached hd gear to bikes and load up to the web - for all to see and even better is the help supplied here - I bow to you all
    K
  32. #132
    I have been looking at ideas on here and trying to think of a stable mount on my helmet. This is my attempt at a scorpion, unicorn what ever you want to call it. I was just testing so yes that is a brush on my head ;-) I will be using a carbon pole with a counter weight for the finished mount. This was just a test for angles and pole length.
    Small test video in my kitchen.
    <iframe style="COLOR: rgb(0,153,0)" height="225" src="http://player.vimeo.com/video/32227296?title=0&amp;byline=0&amp;portrait=0" frameborder="0" width="400" webkitallowfullscreen="" allowfullscreen=""></iframe>
    The Mount is an old Mini pump braket:
  33. #133
    www.swampclub.org
    Nov 2008
    Quote Originally Posted by karltimber View Post
    K
    Quote Originally Posted by chuscoto View Post
    good post
  34. #134
    Texan
    Reputation: Gary H's Avatar
    Here's how I mounted my Go Pro to my stem. The first problem was keeping it light, and how to use the provided mount on a round stem. Since I am into building RC planes, I had some extra balsa wood laying around. I thought if I could stick some on the edges on the mount, I could sort of make a semi radius to match the diameter of the stem if I used enough 3M outdoor double sided tape. Meh, my first try.
  35. #135
    www.swampclub.org
    Nov 2008
    Quote Originally Posted by Gary H View Post
    Be weary. I almost lost my GoPro by using the best DS tape I could find and assuming it would hold.
  36. #136
    Quote Originally Posted by MREGAN View Post
    I forgot about this thread. Here is my first ride with the boom I showed you above.
    <iframe src="http://player.vimeo.com/video/33449166?title=0&amp;byline=0&amp;portrait=0" width="400" height="225" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
  37. #137
    Rolling
    Reputation: lidarman's Avatar
    Another quick release tripod mount. (referring to Custom GoPro mounts )
    That Gopro tripod mount is a waste of money and a pain to use. Described below might be the easiest project ever for a homebrew Gopro mount---and you already have it.... So I hope you saved that large plastic square base that the camera was mounted on when you bought it.
    You can cut it down. In my case I used a bandsaw. I cleaned up the edges with a belt sander
    Drill a hole. If you have a 1/4 tap, drill it smaller than 1/4 inch and tap it. If not, drill it .265" get a 1/4 -20 nut.
    <a href="http://photobucket.com" target="_blank"><img src="http://i6.photobucket.com/albums/y228/lidarman/Projects/P1070477b.jpg" border="0" alt="Photobucket"></a>
    Mount it on your tripod.
    <a href="http://photobucket.com" target="_blank"><img src="http://i6.photobucket.com/albums/y228/lidarman/Projects/P1070478b.jpg" border="0" alt="Photobucket"></a>
    Done.
  38. #138
    No Clue Crew
    Reputation: big0mike's Avatar
    Jun 2010
    Quote Originally Posted by lidarman View Post
    Very slick idea.
  39. #139
    www.swampclub.org
    Nov 2008
    FYI...
    Some great chest-mount information is here...
    http://forums.mtbr.com/videos-helmet...os-547174.html
  40. #140
    North Van/Whistler
    Nice. Thanks Rich
    Locals' Guide to North Shore Rides http://mtbtrails.ca/
  41. #141
    www.swampclub.org
    Nov 2008
    Done.
    Neither of mine came mounted on a large plastic piece. It was actually just on a standard adhesive mount stuck to a piece of black plastic.
    Great idea though! I'll have to mod one.
  42. #142
    Reputation: Jason B's Avatar
    I use that black plastic square as my actual tripod. I do a lot of filming with it like that.
    [Deleted by administrator; linking to site hosting malware]
    This video was made using that as the tripod. Being so low it does great job of catching the leaves as you blow past.
    <iframe width="640" height="360" src="http://www.youtube.com/embed/IbRmPV1MzME?hd=1" frameborder="0" allowfullscreen=""></iframe>
    Last edited by in4mer; 03-12-2013 at 11:45 AM. Reason: Linking to site hosting malware
    Transition Bank
    Transition ToP
    Transition Covert
  43. #143
    www.swampclub.org
    Nov 2008
    Quote Originally Posted by Jason B View Post
    Beats trying to balance the thing on the clip like I always try to do!
  44. #144
    Rolling
    I got a trick for that...that I use a lot for my still camera.. Get a beanbag or make one by filling up a sunglasses bag with beans or dried corn....put the camera on that and point it where you want.
  45. #145
    www.swampclub.org
    Nov 2008
    Good thought. Thanks.
  46. #146
    Reputation: JeffGabriel's Avatar
    I needed a thread like this! Seeing all this stuff makes me come up with ideas for a chesty. Thanks!
  47. #147
    www.swampclub.org
    Nov 2008
    Quote Originally Posted by JeffGabriel View Post
    Don't forget to post a few pictures when you are done.
  48. #148
    stoneyfromgermany
    Reputation: stoneyfromgermany's Avatar
    nice "personal" mounts :-D
  49. #149
    DIY Chesty using the display lid of the box. The straps and clips were salvaged from old bags.
    Cost of project. $ZERO$
  50. #150
    www.swampclub.org
    Nov 2008
    [QUOTE=discombobulated_conundrum;8956468
    Cost of project. $ZERO$[/QUOTE]
    Nice job!
  51. #151
    Reputation: kyle_vk's Avatar
    Made my own quick DIY seat post mount after my buddy when over the handlebars twice behind me yesterday, i promised i wouldn't miss it again haha.
    Just used some mounting foam on the inside of the pvc to get a snug fit, cut about an 1/8 section of the pvc out so that i could use the hose clamps to keep it tight...works like a charm, now i just need to get my car back from the shop to get my mounts out of the trunk!
    Edit: Also old reflector brackets make the perfect/easiest handle bar mounts ever.
  52. #152
    Reputation: socalfyre's Avatar
    Dec 2010
    DIY Chest mount
    I thought I'd share my recent DIY project. I never used or planned on using the head strap mount that came with my GoPro and I only sparingly used the chest mount harness I bought for $40. So I took ideas from here and other web searches and came up with this...
    So I used both elastic straps that came on the head strap mount and attached a couple buckles from the waist belt of an old backpack. Then added two nylon straps with buckles for the shoulder part of the harness and BAM! Now I can return the chest mount harness and get the LCD back pack
    For some reason the flickr link isn't showing up, at least on my computer so here's the link,
    DIY CHESTY | Flickr - Photo Sharing!
  53. #153
    Wow your's looks a better than mine! haha, this is just a pinned together proto...my salvaged backpack straps weren't long enough
  54. #154
    thought i'd throw this update out there...made a functional version using some nylon strap, clips, and sliders. the base is made out of the bottom of an old disc golf bag, two pieces sewn together. Seems to work pretty well just riding around the house, i'll be taking it out this afternoon to give it a full test.
  55. #155
    Reputation: Mr. Lynch's Avatar
    Jun 2010
    I'd recommend mounting the camera upside down and angling it as far up as you can so it almost points at your chin. It will seem way off when walking around but should be close to perfect when riding.
  56. #156
    May 2012
    I love some peoples creativity
  57. #157
    Here is the latest video from my dolly.
    <object width='500' height='281'><param name='allowFullScreen' value='true' /><param name='allowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/207393/l/' /><embed src='http://www.pinkbike.com/v/207393/l/' type='application/x-shockwave-flash' width='500' height='281' allowFullScreen='true' allowScriptAccess='always'></embed></object><p><a href="http://www.pinkbike.com/video/207393/">R/C Zipline Dolly Prototype #3, Test #2</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    3-axis camera gimbal for GoPro (back cage) by sfx on Shapeways
    Have you looked into all various gimbal mounts in the FPV rc community???
  58. #158
    VP/ Terrain Designer
    Reputation: NastyNick's Avatar
    Quote Originally Posted by Boobslappy View Post
    Well i'm sure we haven't seen everything thats out there; but we've done plenty of research.
    Check us out on Facebook, LineCam Systems.
    <iframe src="http://player.vimeo.com/video/41586777?color=f0001c" width="720" height="405" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe>
    This is our current carriage.
    Braun Enterprises LLC, Building Cool Stuff
  59. #159
    Not sure why the vids didn't post; here are some links to a vid of the rigging setup process, and some quick clips from the slalom play loop.
    LineCam Rigging Set-Up Video - Pinkbike.com
    Slalom Quick Clips Video - Pinkbike.com
  60. #160
    nice!
  61. #161
    HANK
    May 2012
    If you break those your a hurtin unit.. :)
    There are some creative mounts out there. I was looking at a 360 swivel option that some moto guys wear.. May have to try one of those. Here is one that I did recently.. Looking at making one for my ankle when I surf. Nice work by the way burly foo shoaa..
    You can view my mount on youtube search for zenxteninc that will do it..
  62. #162
    Reputation: dfilp's Avatar
    Very good ideas !
  63. #163
    Quote Originally Posted by kyle_vk View Post
    http://i799.photobucket.com/albums/y...-29-28_992.jpg
    That's a great idea. Thanks.
    I completely forgot I had a bunch of those reflector brackets.
    Now, I will see how well they hold up.
  64. #164
    Quote Originally Posted by Mr. Lynch View Post
    This is very true. way too many chest mount vids getting around that are pointed at the ground whilst riding
  65. #165
    Mar 2012
    Just bought a gopro yesterday and was doing some research on how to mount it to get the best video and came across these. Thought they were really cool and worth passing on.
    DIY Steadycam
    DIY Steadicam
    DIY Glidecam
    How To Shoot Video with DIY Glidecam
  66. #166
    Reputation: mojojojoaf's Avatar
    I guilt a mount for teh water bottle area using 1/4" acrylic - works great let me know what you think:
    <iframe src="http://player.vimeo.com/video/43750818" width="500" height="281" frameborder="0" webkitAllowFullScreen mozallowfullscreen allowFullScreen></iframe> <p><a href="http://vimeo.com/43750818">LOWER RUSH DRAPER UTAH.</a> from <a href="http://vimeo.com/user12075790">mojojojoaf</a> on <a href="http://vimeo.com">Vimeo</a>.</p>
  67. #167
    www.swampclub.org
    Nov 2008
    Glad to see that this thread is still going strong! Please post pictures of your mounts!
  68. #168
    Oct 2007
    I've been experimenting with different mounting options for my gopro using a mini ultrapod tripod. Its dead handy to use because of the attached velcro strap and the ball joint. Its not the most robust mount but is quick and easy for adding different views
    First in response to another thread asking for headbadge mounts here is one I think will work easily. I havent tried it. You can see a couple of big zip ties reinforcing it to reduce shake
    Now a couple on the down tube pointing at the point where the wheels meet the ground. Originally used this to show how well the Moonlander works in the sand, front and back
    Lastly the ultrapod mounted to a pole and then mounted to a chainstay to give an off the back close to the ground view.
    There are 2 videos here Fatbike in the desert gopro videos that used these (not the headbadge mount) options
    Thanks to all who have posted their mounts, its given me lots to think about and work on, shukkran.
  69. #169
    www.swampclub.org
    Nov 2008
    More great ideas! Thanks!
  70. #170
    All that is POV
    Feb 2012
    Nice three axis gimbals for the GoPro...
    Hero 1000 Photo Higher
    So fluffy it hurts!
    GPCB
  71. #171
    www.swampclub.org
    Nov 2008
    Quote Originally Posted by Goprocowboy View Post
    So fluffy it hurts!
    GPCB
    No price?
  72. #172
    All that is POV
    Feb 2012
    Brand new and being produced as we speak. I am not sure about price, but I think he is close to release? Sorry that is all that I know.
    GPCB
  73. #173
    Dec 2010
    Any news on the three axis gimbals?? Has it been released yet?
  74. #174
    My first post here! I picked up this idea somewhere on the internet, can't remember where...
    Our new Mountain Bike GoPro Mount | Flickr - Photo Sharing!
    Here is a short movie testing this custom mount in my backyard. I mounted it on both on the front and the rear brake caliper mount. Next step is testing it on rougher trails, but i'll have to wait just a little more for the spring...
    First Hero3 Movie - YouTube
    Cheers, Alex
    btw, i hate youtube downsizing video quality... the original export looks much better
  75. #175
    Oct 2012
    vented helmet mount
    i've had the gopro for over a year now with only a handful of usage since the seatpost mount playback was extremely jittery. i tried the chest mount but withe the camelback on it was uncomfortable. yesterday i finally tried the vented helmet mount but the plastic clips were not strong enough so i replaced it with industrial velcro and so far so good!!! and only $17!
  76. #176
    May 2012
    Custom GoPro mounts
    Alex,
    What are the different mounts you used for the video and where did you get them? I have a Hero2 model and am looking to add different perspectives to my videos.
    Thnx,
    Hawk
    Quote Originally Posted by Alexe View Post
    Cheers, Alex
  77. #177
    Apr 2013
    Quote Originally Posted by discombobulated_conundrum View Post
    Thanks for the inspiration discombobulated_conundrum.
    Here is a version I made which is even more budget and only took about 10 minutes to put together - also for $0.
    I burned slices into the display lid using a hot butter knife, and rounded the sharp edges with the same hot knife. threaded through an elastic strap cut from an old mtb light head strap and it's done.
    I put my camelbak on, sit the plate against my chest and just loop the strap around the two backpack side straps, thread the free end through the plastic clip, pull tight and it sits solid as a rock.
    I used Mr Lynch's suggestion of mounting upside down and pointing the camera upwards towards my chin, works a treat.
  78. #178
    Nov 2013
    You guys do top looking mount, there are awesome.
    Here's mine but nothing compare to somes really nice out here
    How to do a free GoPro chest harness... almost out of the box - YouTube
  79. #179
    i don't give a shift
    Reputation: collideous's Avatar
    A piece of steerer tube, a stem cap, a 1/4" bolt, a GoPro tripod mount and a cheap Velcro mount.
    And when it's all put together.
    Still need to test it.
    blogging @29in.CH
  80. #180
    Jun 2010
    Nice!!!
    14 Aurum, 16 Fuse, 17 T130
  81. #181
    Here's my chest mount.
    blogging @29in.CH
  82. #182
    Reputation: the petes's Avatar
    Mar 2014
    Great thread.
    I like my gopro, I use it alot on the slopes but biking has been rough due to the vibrations, so I'll try out some of these ideas mentioned here.
  83. #183
    Sep 2014
    Aquaminor Talon Gopro Mount
    Hey Gang,
    This thread has some awesome mounts! Aquaminor has developed the Talon action camera mount for Gopro cameras. We just launched our Kickstarter project. The Talon utilizes 4 contouring hemispherical surfaces that allows for numerous camera angles, you can lock in those angle using an easy clamping mechanism. Check out our Kickstarter project.
    https://www.kickstarter.com/projects...ount-for-bikes
  84. #184
    Well--I went ahead and backed the project--if it makes it I will make sure and post when I get to try it out.
  85. #185
    BC
    BC is offline
    Reputation: BC's Avatar
    I've been testing and making these for over a year specifically for mountain bikes. There are some example video's to check out. Quick change mounting system. All parts are precision machined for direct mounting points. No foam/rubber between mounting surfaces. Any flexible material between the mounting surfaces leaves room for movement (Shake) in the camera. The heart of the system is the machined Door interface eliminating the flexy plastic mounts.
    All metal mounts are anodized black. The Torso Harness is a combination of machined HDPE and aluminum using our exclusive "gloves friendly" latching system and ultra wide platform.
  86. #186
    Sep 2014
    Thank you!
    Quote Originally Posted by orind View Post
    Hello orind, thank you backing our project! Check out our updates to see Talon's performance!
  87. #187
    Reputation: Fakawi's Avatar
    Apr 2005
    ((((((((( FAKAWI )))))))))))
  88. #188
    Reputation: WheresWaldo's Avatar
    Wow, some of these mounts are really ghetto! I have used RAM mounts in the past to mount Contour & GoPro cameras. Picked up a couple of Sony AZ1 Mini Action Cams and wanted something smaller and more refined than the RAM stuff. The Sony mounts are rather large and the GoPro bicycle mount is a disaster. So I created a few mounts in FreeCAD and am currently having them printed by Shapeways.
    Here is a link to a 27.2 and 31.6 seat post clamp for the GoPro.
    GoPro Seatpost Mount 31.6 x 17 on Shapeways
    GoPro Seatpost Mount 27.2 x 17 on Shapeways
    My original attempt had the arm extending straight out from the mount, but I have found that this limits the movement a bit. With a 17 angle, the arm is parallel to the ground with most standard geometries. Here is a picture of the original mount. The new angled mount should be here by the end of the week.
    Why aren't threads like this stickied!
  89. #189
    Custom camera mounts
    I posted these a long time ago but I thought it would be good to bring them back. If you use RAM mounts here is what I did for a rear wheel skewer mount.
    Took a ball mount with the 1.4 x 20 threads and retapped it a bit larger so I could insert a 5 mm insert
    Then used it in place of a skewer nut.
    Here is a replacement for a top cap.
    Same top cap screw with RAM mount attached.
    The skewer mount needs to be redone and I am still thinking about how to do it, I cannot get it to stay tight after a lot of bouncing down the trail.
  90. #190
    I decided to make my mounts much more robust. Rather than using multiple adapters connected together, I am 3D printing some direct camera to GoPro mounts. Using GoPro as a "standard" monuting system makes a lot of sense to me as there are just so many different parts and they are cheap on eBay. But there are things that are just not available or are very clunky in operation or looks. I own a GoPro, three Contour and two Sony Action cams so here is what I have built.
    To go from a Sony HDR-AZ1 (Sony Mini) direct to GoPro, I built one of these:
    To go directly from my Contour cameras T-Rail system to GoPro, I made a couple of these:
    I modified my seat post mount (pictured above) to sit parallel to the ground instead of at an angle down.
    I also drew up the same seat post mount for a 31.6 mm post, but I have not printed it yet. The seat post clamps use two M4 x 16 mm socket head cap screws and nylon lock nuts. The rest of the hardware is the standard sized GoPro thumbscrew and acorn nut. The Sony Direct mount uses one M4 x 10 mm socket head cap screw. Click on any of the three images above if your interested in purchasing any of these. This is not a business for me, I just wanted to share what I was doing with the cycling community. One problem with 3d Printing, is that each part created is very labor and time intensive. Its not like making a mold and then injection molding thousands of parts, it is one part at a time. Hence the cost of building is more for the avid tinkerer and those who want to say they have something unique. I also try to focus on things that haven't been built yet (like the direct to GoPro mounts), or are of such poor design that they could use a reworking (like the GoPro handlebar/seat post mount).
    Last edited by WheresWaldo; 01-28-2015 at 01:46 AM. Reason: New links to Shapeways store
  91. #191
    No Clue Crew
    Jun 2010
    What are these "3D Printed" mounts made out of? I don't know anything about them but I'm pretty sure I wouldn't trust anything that was "printed" to hold my GoPro...
  92. #192
    Quote Originally Posted by big0mike View Post
    Many home printers will use ABS (think LEGOS, but not as smooth and shiny), there are other options available. Many commercial printers print using a different method that uses Nylon powder fused with a laser. This is what Shapeways uses and what each image links to. Commercial 3D printers can also print some metals, although the cost goes up exponentially.
    ABS printed parts are close to but not exactly as strong as the injection molded parts that come from GoPro or any compatible mount manufacturer. The Nylon parts are a bit more flexible if you make the walls thin, but stiffen up by adding material. Nylon can also be colored with RIT dye after printing. I have not had any issues with the 3D printed parts I have on my bike, which also includes Garmin mounts as well as camera mounts. Of course as with anything, how a part is designed contributes a lot to the overall quality and strength. That is why I tried to make the mounts direct types, that go directly from Sony to GoPro or Contour to GoPro, instead of using something like a Sony/Contour to Tripod + Tripod to GoPro.
    Considering that this thread is full of homebrew amalgamations of parts and adapters, there is more of those I wouldn't trust than any 3D part I have. We have PVC pipe, Velcro straps, hose clamps, clamps made for other devices, epoxy, you name it. I have always believed, especially after years of trying different things, that direct mounts offer better device protection, stability, strength, lower weight and usually smaller profiles than a bunch of adapters strung together to get something to work. If I can make that happen with a 3D printed part, then that will be my first choice.
    Just look at my Contour post above. I had to "build" an adapter to thread a 6 mm rod into the bottom of a RAM-B-273SS-M6U then use a RAP-B-201U-A Composite short extension arm attached to a RAM-B-348U-GP1. This ends up with a camera that is canted out to the side so it doesn't stand 12" above the bars. It is also highly prone to shaking no matter how tight you clamp down the extension arm. With my direct to GoPro 3D part I just use a cheap alloy GoPro style top cap and my adapter slid into the t_rail. Much lower profile and less prone to breaking in the event of a crash. Also the part count is lower, just two instead of three (not counting that the arm is two parts), and one 3D part is cheaper than all those RAM mount parts.
  93. #193
    I added a few more direct connect mounts to go from the Contour and Sony to the GoPro. I am trying hard not to duplicate what is already available unless the current versions are just poor designs or too universal. You know the saying, jack of all trades, master of none. I really think that direct mounting is way better and will help eliminate shakes and jello by having less connections and lower weight. I love seeing all the innovative ways you guys are mounting your cams, and I often take inspiration from them.
    I have them available on Shapeways Store here: https://www.shapeways.com/shops/revolutionaries
  94. #194
    So I am fooling around with chainstay mounts and found this in one of my old parts boxes.
    So I decided to create this mount.
    Just requires a single M5 x 45 mm socket head cap screw and one M5 nylon insert lock nut. Retains full functionality as a light mount. I am thinking that something like a small bar mounted Cree flashlight could be used as a movie light mounted on the same bracket. Or a double mount could be designed to add a Knog Qudos, which already has a GoPro compatible mounting tab. Should know in a couple of weeks if it will work.
    The setup will put the GoPro mounting tabs about 60 mm away from the bicycle frame, so at its closest the camera will be about 30 mm (~ 1 3/16") away from the frame.
    I think this same setup with no changes should work in the currently available KCNC Light Mount Bracket.
  95. #195
    Sony AZ1 direct to GoPro mount
    Here is the results of my 3D print for mounting the Sony AZ1 directly into a GoPro mount,
    There are a few small areas where I feel like an adjustment is necessary, otherwise it works fine and holds the camera very securely.
  96. #196
    Reputation: A Little Bird's Avatar
    Oct 2014
    WheresWaldo, Awesome work man! Ill have to take a look at that store link because i've been looking for some mount options for cool views down by the wheels. Very cool stuff, for other DIYgopro.com has some pretty awesome home projects, one the mount a swivel arm to a helmet so its spins around as you ride. Sounds retarded, looks retarded, but the video sure is cool. Obviously not for trail use but neat none the less.
    And whoever said they wouldn't trust a 3d printed connection to hold, they are making receivers for AR15s that are 3d printed, I would venture to guess that the gun powder propellant probably exerts a little more force and stress than a bike bouncing over some rocks.
  97. #197
    @A Little Bird - If I can be of some assistance let me know. I really like working out tailored solutions to these types of challenges. See my thread here so we don't clutter up this one with the 3D stuff. 3D Printed Camera Mounts and Accessories
    I just stopped by DIYGoPro, some interesting stuff, but not a large community just yet. Although I didn't spend a whole lot of time there.
  98. #198
    I made this piece and kept it open source, as I am not interested in building it other than for myself. But if you have a GoPro and have or can get a hold of the older Contour rotating mount with LOCK button, then you can convert it to a Rotating GoPro mount without the use of an adapter. Any 3D printer should be able to print this part. It is up on Thingiverse. Original 123D Design source file is included.
    Convert Contour Rotating Mount to GoPro Rotating Mount by WheresWaldo - Thingiverse
    This is the Contour mount I am talking about, generation 1 rotating mount.
    This conversion cannot be done with the newer lower profile Contour rotating mounts, but it is the only way to get a very low profile rotating mount for a GoPro without using two extensions strung together. When you take apart the Contour mount do not lose or break and of the pieces, especially the little U shaped locking piece.
  99. #199
    Good job! Custom 3D printed GoPro seat post mounts (free download)
    Anyone who has a 3D printer or has access to a 3D printer and wants a size specific seat post mount for their GoPro style action camera. I have posted 2 simplified designs on YouMagine. They both look essentially the same one is size specific to 27.2 mm round seat posts the other to 31.6 mm.
    To print have your slicer program re-position the two halves and add support material. Cut away the support material after printing. The mounts use two M3 x 15 mm socket head cap screws and matching M3 nylon insert lock nuts to secure it to the seat post. A standard GoPro style thumbscrew and acorn nut (M5) attaches the camera. Long and short arm versions are available at the download links.
    31.6 GoPro Seat Post Mount
    27.2 GoPro Seat Post Mount
    My way of saying thanks to this community. If you do not want to print your own I have more streamlined versions of these in many more sizes on my Shapeways page (see link in signature), plus stuff for Garmin and Sony too!
  100. #200
    Seat post mount looks cool but I lost a gopro from that position so make sure to tether it, I know some 3D printed materials are somewhat brittle.
