Results 1 to 14 of 14
Thread: Contour Roam/2
    Jul 2013
    Contour Roam/2
    Ok I just got my contour and I successfully updated the Roam 2 firm ware. Yeah me!! Some quick questions for a challenged mind...
    1. How can I import videos to I photos, it won't recognize mp4
    2. Is there a way to modify videos to email a smaller file
    3. Can you message videos?
    Damien
    Reputation: skiahh's Avatar
    I don't do i anything, so can't help you with that one. You could try downloading different codecs, but again, not sure how the fruit does that.
    You can reduce the quality of a video, but other than that, you'll have to trim the length of the video. There are formats that produce smaller sizes, too, but you'll need photo editing software to manipulate the videos. Again, no idea if imovie does that or not. I use Premiere Elements.
    Message via....? Text? Email? Other? Most videos are pretty large file sizes, so I just upload mine, then message the link. That way, file size becomes not that big an issue.
    Jan 2013
    Quote Originally Posted by esteroali View Post
    Damien
    i updated my ROAM's firmware, this past friday after receiving it from amazon, successfully, too!
    i am also using iMovie '11.
    i was able to import the video from the ROAM into iMovie but only after using the StoryTeller app from contour to download movie from the camera and then saving it to my mac's hard drive.
    in iMovie i simply went to the file menu item and then selected Import and then chose Camera Archive.
    locate the file and it will import
    good luck.
    joel
    Reputation: shiggy's Avatar
    Dec 1998
    Contour Roam/2
    Damien
    I just download the files to my hard drive
    Edit with iMovie
    mtbtires.com
    Sep 2004
    Thanks and I ordered one of the Water Sports model from Amazon. I'll do the upgrade as soon as it arrives Wednesday. I just got a Windows 8 laptop (and am hating it). Has anyone done the firmware update on Windows 8 and it went ok? Thanks.
    Jan 2013
    Contour Roam/2
    Quote Originally Posted by K2D2 View Post
    awesome... welcome to the club!!!
    luckily, the update to the camera is NOT operating system dependent
    meaning, you update the firmware on the camera using the camera itself.
    you only need a computer to copy the firmware file to the camera's microSD card.
    and then modify the file to tell the camera to update the firmware after booting.
    i guess in a way that could be a problem... but, i think you will find that win8 will see the camera's microSD card with no problem.
    having said that - i have a mac - lol.
    recap:
    * download the roam2 firmware
    * charge the camera
    * insert the microSD card and format using the camera - look for the pinhole
    * connect the camera via usb to your computer
    * copy the firmware to the camera's microSD card to the root/top level
    * edit the file that tells the camera to perform a firmware update
    * disconnect the camera
    * turn on camera
    * wait and watch and giggle
    * enjoy!!!
    of course, there are no REAL details above. i'm on my ipad and copying and pasting is a chore!!!
    the thread has the info as i'm sure you have reviewed.
    also, the contour www site is a good reference, too.
    joel
    2013 Trek Fuel EX 7
    IMBA Member
    Sep 2013
    If any one of you still has a copy of contourroam2.bin, please share it with me. Much appreciated!
    MTB is for animals
    Oct 2013
    Here are some guys who have the files shared...
    Turn your Contour Roam into a Contour Roam 2.
    Apr 2013
    I bought a Roam2 and comes with a V 2.0, if i tried to do the steps on the roam1 to update the firmware the file text it will not let me save the file once i modified, any suggestions? i can change the name of the file then delete the original file and then rename the new file with the original name previously deleted, but appears once i tried to eject, the drive is in use and doesn't let me do it.
    I'm currently using version 2.0 and i have some issues maybe 2.16 version will help me, i installed a 32GB class 10 micro HDSD card and once i start recording for the first time there is no issues, in fact i let it record continuesly until i decided to stop, i slided the top button to do it, then when i tried to start to record again it record only a couple of seconds and then turn it off, i can do this severel times and i can not get the full record on for longer time. Once i got back i connected and i got a big file for about 40 minutes then about 5 file i was trying to get it on without luck those other files are small about 10-15 seconds.
    Is any way i can set a file size for letting my camera record my whole trip that way i will not need to stop and start everytime?
    Not sure what you're asking. You slide the switch forward, it records. Slide it back, it stops. If you slide the button forward and leave it, you'll get large files, up to 4GB. Then it will start a second file, so instead of FILE055, you'll get FI0055 or something like that.
    But it's much easier to edit using smaller clips since you don't have to go through 40 minutes of video to find the good clips. Just a thought.
    As for upgrading, you should be able to do it just fine by putting the 2.16 firmware in your root directory, renamed appropriately.
    Dec 1998
    Contour Roam/2
    Quote Originally Posted by sepoga View Post
    I am using 2.16. I have had this happen.
    Sounds more like the battery is going dead. The camera should be completely recharged before each use.
    At best, the battery life is not nearly enough to fill a 32gb card. I can not fill a 16gb during a single session.
    mtbtires.com
    I know this thread is a little old, but I did this little "hack" and now the first 10-15 seconds of recording for me is very choppy, then it smooths out and records like normal until I stop it and start it again, then the first 10-15 seconds is choppy yet again. Has anyone else noticed this or found a fix? How can I revert back to the Roam firmware?
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    have you tried viewing it on another computer? sounds to me more like your graphics card and the newer file format that it can't handle. I had this issue using an older laptop that I had carried with me.. got home on the real computer and the vids were fine.
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    You were right. I had a bad driver, reinstalled latest and all is well now. I actually found this out about 30 seconds after posting, but figured Id leave the post to see if there were any other causes too. Thanks a lot!
  1. Turn your Contour Roam into a Contour Roam 2.
    By Krunk_Kracker in forum Videos and POV Cameras
    Last Post: 06-03-2015, 08:30 PM
  2. Contour Roam
    By jesse101 in forum Videos and POV Cameras
    Last Post: 07-16-2013, 09:49 PM
  3. Contour Roam and iMovie
    By cowboygrrl in forum Videos and POV Cameras
    Last Post: 12-30-2011, 11:36 PM
  4. How do you like your Contour Roam
    By csermonet in forum Downhill - Freeride
    Last Post: 12-24-2011, 01:34 AM
  5. Contour Roam for 89$ at amazon
    By etal in forum Where are the Best Deals?
    Last Post: 12-22-2011, 08:32 AM
