Results 1 to 37 of 37
    Woodlot local
    Reputation: BobRocket's Avatar
    Contour HD - Chest Cam
    Here is a test run I did of a chest mount I made for the Contour HD. Next time I think I'll tweak the angle but for the most part it works.
    I'd like comments on whether you think I should aim it higher or lower next time.
    <object width='500' height='281'><param name='allowFullScreen' value='true' /><param name='allowScriptAccess' value='always' /><param name='movie' value='http://www.pinkbike.com/v/214997/l/' /><embed src='http://www.pinkbike.com/v/214997/l/' type='application/x-shockwave-flash' width='500' height='281' allowFullScreen='true' allowScriptAccess='always'></embed></object><p><a href="http://www.pinkbike.com/video/214997/">ContourHD Chest Cam (Test #1)</a> on <a href="http://www.pinkbike.com">pinkbike.com</a></p>
    North Van/Whistler
    Pictures of the setup would be appreciated. See other thread - it had the same shakiness as your video. Needs to be pointed higher imo
    Here was my half-hearted attempt in this article and video which was disappointing
    <iframe src="http://player.vimeo.com/video/5614344?title=0&amp;byline=0&amp;portrait=0" width="800" height="450" frameborder="0"></iframe>
    Locals' Guide to North Shore Rides http://mtbtrails.ca/
    Woodlot local
    I promise I will share my mount when I have it dialed. This was prototype #1 that took my 20 minutes the conceive and build. The current design flaws are that it is a touch low on the chest and protrudes a couple inches too far for my liking. It is my first attempt at filming with a Contour Chest Cam and when I aimed the lasers I put them a little too high.
    So I'll tweak my creation. Re-test and reveal when it is dialed. I promise that I will provide detailed instructions on how to make it.
    Have you tweaked the mount yet?
    I'm contemplating returning my contour 1080p because I cant stand all the shakiness in the video while using the vented helmet mount. I don't want to use software to eliminate the vibration since rendering takes forever.
    Woodlot local
    Quote Originally Posted by Dictatorsaurus View Post
    Yes I have tweaked it but need to test it on a regular trail.
    I've done one ride with it, but I was on my XC bike on somewhat rough trail around. There is a little bit of bouncing, but considering the small bike and trail roughness I'd say it is pretty damn good.
    In regards to your complaint about the helmet visor shakiness; throw the Contour vented helmet mount in the garbage and make your own.
    I am in middle of making mine and will post up the details within a week. I have tested a prototype and it works really well.
    One thing to note that most people don't realize. You must ensure that your helmet fits really tight on your head. Even half an inch of rotation on your head will make the video look unstable.
    <iframe width="500" height="281" src="http://contour.com/stories/the-woodlot-cabin-trail-chest-cam-test-2--2/embed?map=false&width=500px&height=281px" frameborder="0"></iframe>
    Me personally, I appreciate the angle. It's refreshing to see what's coming into the shot rather than having it being pointed down observing the front fork in action.
    On a separate note, doesn't the Contour have a an application for either the IPhone or Android allowing you to wirelessly stream your video live to a smartphone? I think I remember seeing this on their website at one point or another. If this works for yours, I would suggest getting that dialed in so you have an idea as to what your angel looks like before you start shooting.
    Woodlot local
    Here version #1 of my chest mount. It works well, but its a little low (almost gut level when riding) it also protrudes a little too far for my liking. I used an Ultraclamp for pivoting and aiming.
    My other bike is a GasGas
    I'm going to work on a shoulder strap mount (on curved plastic backing for rigidity).
    Fezzari Alta Peak
    nice mount.
    PROEDGEBIKER.COM
    Reputation: ProEdgeBiker's Avatar
    Quote Originally Posted by bobrocket View Post
    here version #1 of my chest mount. It works well, but its a little low (almost gut level when riding) it also protrudes a little too far for my liking. I used an ultraclamp for pivoting and aiming.
    cool!
    Woodlot local
    Here is version #2.
    It is WAY more stable and sits closer to the body out of harms way.
    Reputation: KTMDirtFace's Avatar
    Nice.
    I found these videos awhile back. Yours looks better setup.
    HowTo: Contour | Stories | How to make a chest harness for the VholdR camera
    and Sample: Contour | Stories | Duthie Hill Park Dirt Corps Line first half
    Guerrilla Gravity Pedalhead XL
    Contour Chest Mount
    We put together a Contour Chest Mount using some products that are available off the shelf. It is built around the GoPro Chest Mount Harness with a Contour Universal Mount and a Drift GoPro Mount Adaptor. Here is a video of how it all goes together. It is possible to get the camera to sit a bit further back on the mount, closer to your chest:
    <iframe width="560" height="345" src="http://www.youtube.com/embed/e-JqrG6wkiE" frameborder="0" allowfullscreen></iframe>
    Matt Fitzhardinge
    Launch Helmet Cams
    We'll beat any online price for mtbr.com members!
    Woodlot local
    Quote Originally Posted by Launch Helmet Cams View Post
    Nicely done. I really like the integration of the standard parts. You should put up some test footage to see how it compares to a GoPro standard set-up.
    Contour Chest Mount
    Yep, we'll put together some footage and post it soon. The camera isn't quite all the way in to the Contour Universal Mount, which will get it back another 1" or so. I'm also going to test using the standard GoPro clip on the Chest Mount, rather than the J-mount clip which we used in this video. That should bring the camera closer to the chest mount as well (it's a bit hard to see/explain from the photo, the clip that I'm talking about creates the connection between the mount plate and the Drift Mount Adaptor).
    Matt Fitzhardinge
    Launch Helmet Cams
    TranceX Rider
    Reputation: Onie's Avatar
    Mounting hardware made easy! Awesome, Matt!
    Thanks for sharing yours too, Bob!
    Quote Originally Posted by jcatienza
    There was no need to scare potential buyers and burn bridges "buddy"
    Tell me now, what's Product testing all bout then?
    why not buy a gopro?
    Contour cameras are smaller, lighter, easier to use and better shaped for helmet mounting. GoPro cameras are better shaped for chest mounting. Neither camera does it all perfectly, so you need to pick which features are more important and then work around the ones that aren't ideal. Some people like GoPro, some like Contour, others like Drift, etc......
    Matt Fitzhardinge
    Launch Helmet Cams
    Oct 2010
    noob question...
    if you fall... isnt there a higher risk of shattering your rib cage with that chest mount for the contour compared to a gopro? im scared of going this route to mount a vid camera, because i most certainly do not want to shatter my rib cage.
    Quote Originally Posted by Silviu View Post
    Some prefer the optics and video quality of the Contour. While the GoPro might have a cleaner (tight to the chest) chest mount, the helmet mounting options have the GoPro realling hangin' out there.
    As far as chest mounts and "shattered ribs" I would suspect the physical mounting hardware would have more to do with any injury, shattered or not, than would the type of camera.
    Quote Originally Posted by Mattlikestobike View Post
    noob question...
    Nope, that is a good question and one I asked when we were putting ours together. I don't think there is a higher risk of damaging your rib cage or sternum for two reasons:
    1) The "plate" at the centre of the GoPro Chest mount which we've used is quite big and will help distribute the force of an impact. So, although the camera hitting the ground is quite "sharp", the force on your chest will be over a larger area.
    2) The way the camera and mount adaptors attach to the GoPro chest mount is via the standard GoPro clip which has a weak point in the sides of the clip. In the sort of impact that would break ribs that clip is going to break and the camera will come away from the chest mount.
    Matt Fitzhardinge
    Launch Helmet Cams
    Quote Originally Posted by BobRocket View Post
    OK, so here is an update. We used the standard GoPro clip rather than the protruding J-mount that comes with the GoPro Chest Mount. This really helped bring the camera in closer to the chest mount:
    I've posted a short bit of test footage. You can hear the camera rattling in the mount - this is coming from the GoPro clip that connects everything to the chest mount. We should have used the GoPro white rubber thing to cut down the shake. We also could have had the chest harness a bit tighter. We'll post another test soon with those problems fixed.
    <iframe width="560" height="315" src="http://www.youtube.com/embed/N5-GYxIK0EU" frameborder="0" allowfullscreen></iframe>
    Matt Fitzhardinge
    Launch Helmet Cams
    Contour chest mount
    After doing some more testing we've come up with what we feel is a pretty solid solution. We changed the mounting clip on the GoPro chest mount and added the white rubber plug to stop the shaking and the results are much better. Both these items are available in the GoPro Grab Bag. This video shows the mods and some demo footage (still could have been pointing a bit higher )
    <iframe width="680" height="383" src="http://www.youtube.com/embed/NDAp9uelYdI" frameborder="0" allowfullscreen></iframe>
    Matt Fitzhardinge
    Launch Helmet Cams
    Launch Helmets Cams,
    Nice one for working out how to chest mount the Contour, but I have a problem as I only have an older model of Contour HD and was wondering how to go about mounting it using your system. Seeing as the lens will not rotate when the camera is upside down (As it is in your system)
    Is there a workaround for these older models of Contour?
    Reputation: WheresWaldo's Avatar
    Quote Originally Posted by krissboo View Post
    Launch Helmets Cams,...Seeing as the lens will not rotate when the camera is upside down (As it is in your system)
    The camera they showed in their video is the ContourGPS which won't go upside-down mounting / right-side up video either, only the Contour+ and the ROAM are made to rotate 270 allowing upside-down camera mounting with right-side up video.
    They must be flipping the video in post.
    BTW, the ROAM would be a better choice for this as it would be even closer to the chest since it has a built in tripod socket and does not need the Universal mount. That is if you acn live with the limitations of the ROAM.
    Thanks for the reply WheresWaldo.
    I didn't look too closely at the camera they were using!! Just got excited that there's a chest mount available lol.
    I like BobRocket's design, but don't trust my homebuild skills enough to make one for myself. Would rather just buy all the gear and then bodge something together
    Unfortunately a new camera is out the question at current time in my life....no money to spend on new toys. So I'll have to stick with the limitations of my Contour HD!!
    Woodlot local
    A friend of mine came up with this.
    Simple and effective.
    Hey Bobrocket.
    That looks good...how is it out on the trails as far as vibration?
    Woodlot local
    Hey Bobrocket.
    Personally I have not tried the GoPro mod above. I cannot comment on the vibration. However it should be just as stable as any GoPro you have seen.
    Reputation: dirtyjack's Avatar
    Has anyone tried mounting to the shoulder strap of a camelback so it sits on your shoulder?
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    Woodlot local
    Quote Originally Posted by dirtyjack View Post
    A mount will work anywhere IF it is mounted solidly and not allowed to move or vibrate.
    If you can pull it off then kudos to you, but I think it will be pretty difficult to mount a camera to a shoulder strap without either a SUPER TIGHT strapping system or braces all over the place to limit movement of the pack and the strap.
    Give it a try and post up your results.
    Quote Originally Posted by WheresWaldo View Post
    The camera they showed in their video is the ContourGPS which won't go upside-down mounting / right-side up......
    Yep, that is correct, with the Contour GPS we had to flip the video (easy to do in iMovie which is what we used) to get it the right way up.
    Matt Fitzhardinge
    Launch Helmet Cams
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    I was thinking the same thing, using the goggle strap mount..? might have to try it out later
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Quote Originally Posted by thomllama View Post
    exactly, just a few wraps of stretchy velcro, should be able to slide it a bit to fine-tune.
    Here's my bar mount:
    and my under-seat mount:
    SantaCruz Tallboy C
    SantaCruz Solo C
    Specialized Fatboy
    Trek Madone 8
    Kestrel RT 700
    Lemond Zurich
    I have the GoPro chest mount using it with the Contour Roam.
    The issue I have with the mount is the vertical stability as the camera's weight makes it rather bouncy which results in shaky video even though I have the straps as tight as possible.
    Any suggestions how to make the mount and harness more stable?
    Contour chest mount
    We have a customer who took the foam and bolt out of the GoPro/Drift mount adapter (assuming you are using this to attach the Contour to the Chest Mount) and then stuck a trimmed down profile mount on the mount adapter. That should get the camera in closer to the Chest Mount.
    Also, if you are using the J-mount clip that comes with the GoPro Chest Mount, try to get your hands on one of the smaller standard GoPro quick release buckles. Again, this will bring the camera in closer to the chest mount to make it more stable.
    Always run your Contour ROAM in the 720p or 960p mode, those will give the widest field of view and hence the smoothest footage.
    Matt Fitzhardinge
    Launch Helmet Cams
    Feb 2013
    goos view
  1. Go-Pro or Contour Cam
    By baumi in forum Downhill - Freeride
    Last Post: 09-24-2011, 10:19 PM
  2. Contour HD First Try
    By NastyNick in forum Videos and POV Cameras
    Last Post: 09-16-2011, 08:55 PM
  3. Contour HD Plus
    By wormvine in forum Videos and POV Cameras
    Last Post: 04-19-2011, 09:21 AM
  4. contour chest mount?
    By locobaylor in forum Videos and POV Cameras
    Last Post: 03-04-2011, 12:01 AM
