    Reputation: dnoyeb's Avatar
    Contour +2 (Case vs. No Case)
    I have a contour +2 which I am really enjoying. I haven't taken it out on the trail yet, just the pool. My question to you who have is this.
    Do you use the Contour inside the waterproof case on the trail, or just mount it directly to your helmet? If you mount it directly, are there any conditions that would make you put it in the case before mounting it?
    Seems like the case would kill my audio, plus I wonder what its effects will be on the image?
    2012 Fianceť
    2011 Spc SJ Cmp Crbn 29
    2010 Fantom Cross Outlaw
    2009 Spc RH Exprt Disc 29
    2008 Trek Fuel EX7
    2007 Spc RH
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    I don't have the +2 but I just mount it to the bike (most helmets shake too much and give crappy vid unless it's full face or you mod it to keep it steady)
    don't really ride in conditions where I's worry about getting it wet..
    Going to try and bring Trail Tire TV back. go take a look...
    Reputation: woodyak's Avatar
    I've been using the Contour +2 since winter. I've used it snowboarding in some really wet conditions. The worst time it was a misting rain for most of the day and the camera got dunked in some wet snow from time to time w/o any problems. I've found the camera to be very weather proof. As long as the camera doesn't get dunked you should be fine. If I were to kayak or surf with it I'd put on the case. But for mountain biking in any conditions I don't even think about the case.
    Rabid Lana fan
    One thing you can do that's free and effective is to cut an old inner tube section, about an inch or so wide, and stretch it over the lens so that it covers the interface where the lens rotates. Keeps grit and water out pretty well.
    rOCktoberfest 2015 pt I here
    rOCktoberfest 2015 pt II here
  1. Just in case
    By AZ in forum Off Camber (off topic)
    Last Post: 12-16-2012, 05:26 AM
  2. In case you didn't know
    By kubaner in forum Massachusetts
    Last Post: 05-09-2012, 06:57 PM
  3. What case do you keep your Go Pro in?
    By ManianMTB in forum Videos and POV Cameras
    Last Post: 10-06-2011, 10:45 AM
  4. Map Case
    By cowboygrrl in forum Endurance XC Racing
    Last Post: 06-25-2011, 03:34 PM
  5. Case Mtn.
    By XC62701 in forum Connecticut, Rhode Island
    Last Post: 06-15-2011, 07:16 PM
