    Jun 2014
    Aluminum GoPro Mount Extensions
    I mount my camera on the side of my helmet and use two 35mm straight extensions and one 50mm extension. By 'straight' I mean both ends of the extensions are same direction vs having a 90 degree turn like the standard GP extensions.
    I have found some aluminum extensions made by Rec-Mounts (in Japan), but wondering if they will slip due to vibration? Anyone know? They aren't cheap, so want to make sure before I consider ordering.
    https://www.amazon.com/Rec-mounts-Ex...c-mounts+gopro
    Thanks.
    Reputation: Globetrottngeek's Avatar
    Jan 2016
    Regardless of the material, use some friction paste (the same kind you use for carbon frames) to keep your mounts from moving due to vibrations. I use a q-tip to apply it and then give the knobs a few good turns with the tightening tool. Those mounts don't move for Jack after doing that.
    As for those mounts, unless you find yourself breaking mounts often I'd save some cash and just get plastic ones.
    Jun 2014
    Quote Originally Posted by Globetrottngeek View Post
    Thanks!! I ordered the plastic ones....hopefully they are high quality. Is Fiber Grip the friction paste you are referring to?
    Jan 2016
    Quote Originally Posted by dmac1 View Post
    Yup, fiber grip or Park Tools SAC-2 SuperGrip will do ya. If you get a bit on the threads of the tightening knob you may notice it's a bit crunchy while you tighten. Just unscrew it, clean off the excess, and tighten as normal.
    Have fun!
  1. Brake handle extensions for bar ends?
    By khaytsus in forum General Discussion
    Last Post: 09-24-2016, 07:36 PM
  2. Handlebar extensions...
    By OldschoolReloaded in forum Bikepacking and Bike Expedition
    Last Post: 05-07-2015, 01:37 PM
  3. wanted: brake lever extensions
    By wholt in forum Brake Time
    Last Post: 05-07-2013, 07:48 PM
  4. Your thoughts on handlebar extensions?
    By littlebadboy in forum Beginner's Corner
    Last Post: 07-16-2012, 12:06 PM
  5. Leg Press, Hamstring Curls and Knee Extensions for Cyclists: NOPE!
    By bikerbert in forum XC Racing and Training
    Last Post: 03-31-2011, 08:23 AM
Members who have read this thread: 10
