Results 1 to 3 of 3
Thread: Advice/help
    Reputation: VICpt's Avatar
    Good job! Advice/help
    Hello
    Im having an annoying problem, my lens glass gets foggy while riding, on the inside of it.
    I have a Drift Ghost and it happened a couple of times, do you guys have any advice or solution?
    Trail Tire TV on blogger
    Reputation: thomllama's Avatar
    Oct 2007
    isn't that a somewhat water proof /resistant cam? think I'd contact Drift as there is probably an issue with the seals..?
    Going to try and bring Trail Tire TV back. go take a look... http://trailtiretv.blogspot.com/
    Good job! The reason why!
    Contacted Drift support, gave me a quick reply - thanks for the suggestion thomilama -, it seems that it happens just because of the impermeability and the temperature shock between the inside of the camera and the outside. They told to open the back door of the camera and let it breed a while. Ill see the next time it happens.
  1. Bad advice from Nova, seeking more bad advice
    By unterhausen in forum Frame Building
    Last Post: 04-20-2013, 08:39 AM
  2. Need some Advice
    By nstp0316 in forum 29er Bikes
    Last Post: 04-03-2013, 02:18 PM
  3. ML8 advice
    By nicolap99 in forum Maverick
    Last Post: 12-09-2012, 08:46 AM
  4. Need your advice
    By nikobimmer in forum Ibis
    Last Post: 11-22-2012, 11:01 AM
  5. Replies: 18
    Last Post: 02-18-2012, 07:09 PM
