Results 1 to 10 of 10
    Zeus suspension question
    Anybody else notice a tiny amount of vertical play at the shock/linkage bolt after swapping the travel change chip on your Zeus?
    Team Hardcore Cornbread
    Reputation: Phishin Paul's Avatar
    Dec 2004
    I have taken my shock off a handful of times for cleaning purposes. One time I thought I had tightened the bolts sufficiently but they were too loose. This did create the play I think you are talking about. I also have already had to replace the Fox eyelet on the shock which also created some play.
    "Set the gearshift for the high gear of your soul".
    Cool thanks! How many rides before u replaced the eyelet bushing? Also, did u end up using washers, or were u able to get the bolt tight enough without?
    It's only been on four short rides (1.5 hrs each) so shouldn't be bushing...
    Dec 2004
    I replaced the bushing right at a year. I do believe it was a result of not having the bolt tight enough which stripped the bushing. The bolt will appear tight but double check with a Park tool wrench and Allen.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Quote Originally Posted by Phishin Paul View Post
    Where they the new Fox Polymer bushings or DP4 Bushings?
    Dec 2004
    Quote Originally Posted by mtnbiker4life View Post
    The new Fox polymer bushing.
    I tried to torque it down about as strongly as I can, but there is still a tiny (but reduced) amount of play. What torque are you going to?
    Also, how do you get it tightened well while in the 160mm mode? I have found it difficult due to the recessed position relative to the rocker...
    Dec 2004
    Make sure you use a socket wrench and the hex wrench together. It will appear that it tightens itself with the use of the hex alone but I found you have to hold the nut bolt while tightening. If that does not work you probably need a new Fox bushing.
    Add extra washers on each side, then you can get rid of the recess and tighten it as well as on the 140mm travel position.
    Quote Originally Posted by JC822 View Post
    Thanks! Will try that!
  1. My Zeus
    By mike thompson in forum Ventana
    Last Post: 04-17-2014, 07:59 PM
  2. My Zeus
    By fai in forum Ventana
    Last Post: 10-13-2013, 02:02 AM
  3. A New Zeus to the mix
    By Internal14 in forum Ventana
    Last Post: 03-16-2013, 10:40 AM
  4. Zeus built
    Last Post: 12-08-2012, 09:53 AM
  5. Zeus?
    By nhodge in forum Ventana
    Last Post: 07-25-2012, 03:47 PM
