Page 1 of 2 12 LastLast
Results 1 to 100 of 105
    Zeus frame design flaw?
    i just read that in a Dirt Rag review of the Zeus that the rear tire at full travel hits the seatube. i'm really bummed & troubled to hear this is still happening w/ Ventanas. i've owned a Terremoto for over 3 years & that is the one problem i have w/ the ride character of the bike. when i first got it, & had it happen i ended up doing the RP23 space reducer fix, which reduced it from happening too often to a rare acceptable event. that fix doesn't reduce the overall travel of the frame, just the too easy to go through all the travel problem. my rear tire actually hits the rear deraileur brazeon. that brazeon has now been lowered on the seatube for the lower pull action of the derailure, putting it out of the way of the tire under full compression. so, why is the frame capable of hitting the seatube still? it seems like something Sherwood would just not allow to still be a problem.
    i haven't read the review, just a thread on the 650 forum mentioning the article, so i'm unaware of the tire/rim combo & obviously unaware of the tire/rim combo stats the frame was designed/tested w/. how 'bout you, Ciclistagonzo? do you know a few details here?
    the Zeus is one of the very few bikes i'll be considering to buy in the future. i didn't foresee having to figure this trait into the decision.
    breezy shade
    Ultra Ventanaphile
    Dec 2001
    Which thread, haven't seen the review or heard of this issue either.
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    I had this problem at the beginning when running my Zeus at 160mm travel with a big fat Nobby Nic 2.35 at the back. My problem was that I did not use enough air in the Float CTD and this was solved by both adding 5 psi (which preserved full travel) and also switching to the 140mm travel position, which is plenty for my riding. Since then, I have never had any tire rub. I spoke with Sherwood about it and, if I remember correctly, he said that getting the shock Pushed to increase compression damping would solve the problem.
    i misstated that it was on the 650 forum. it's on the Knolly forum under the thread Dirt Rag Reviews Endorphin.
    breezy shade
    Reputation: Kronk's Avatar
    Not going to go look it up right now. I think it was the first XL built, and Ventana is looking into the issue. Magazine staff said it will stay parked.
    Read this while waiting to be put under for a medical procedure, memory may be foggy to what the article actually said.
    That is a shame. It shouldn't be an issue in either 140 or 160 travel. The frame is not cheap and shouldn't have that type of issue. But luckily they do all of their stuff in house so they should figure this out pretty quickly. The Zeus is still on my shortlist, but I will be keeping my eye out to see if the issue gets fixed, or to see what the problem was.
    Just A Mountain Biker.
    Reputation: blaklabl's Avatar
    Mar 2011
    Quote Originally Posted by Stripes View Post
    Issue is from the print issue of Dirt Rag, 10.1.13, pages 68-69. I couldn't find a version online, because it looks like it's print only.
    OUCH for Ventana. Guess that really puts the Zeus off the list for me. I read it on my digital subscription to DR.
    What really struck me as odd as it starts out as a love fest, speaking of the 25 years parallels of the two companies (DR & Ventana), and how many bikes they have tested over the years, and how great they have all been - and then spent the second half of the article trashing them (in my view). Wonder if they didn't get the response they wanted from VUSA? You would think with that kind of purported relationship, they would have shelved this review until a resolution was reached, and then made mention of it in the review but also covered the way it was addressed. As it stands now, if it is ever resolved, it may get a mention somewhere in an upcoming edition, but nowhere near as visible as a 2 page spread in the reviews section of the 'rag.
    Just seems problematic to me, can't imagine Sherwood is pleased.
    MTBR: Your dad's online mountain bike forum.
    Mar 2011
    The issue has to do with the size tire the test rider was using Wild Grip'R 2.25.
    I don't know about you, but on a 160mm travel frame, 2.25" tire seems small. If they were trying to fit an especially large 2.5" in there I could see an unforseen issue, but 2.25? Shit, even I want to see this tire now!
    Quote Originally Posted by blaklabl View Post
    Me too. The Zeus is a AM maybe even an Enduro capable bike. If you can't fit a tire that is 2.25 then whats the use.
    Team Hardcore Cornbread
    Reputation: Phishin Paul's Avatar
    Dec 2004
    I have had my Zeus 1 year exactly riding year round in SoCal. Only 1 time did I have any rub and it was due to not enough pressure in shock and, a few pounds I had put on with injuries. This was on a 2.5 foot drop I do regularly and it has happened only once. I ride with a 2.25 Ardent on rear with TL28 hoops always in 160mm travel mode Front/rear. I call user error on the review. If anything I wish I could get more travel out of the bike. 1 year riding the bike with correct settings vs. what appears to be incorrect one time review. I have several options of bikes to ride and the Zeus is the one I always end up riding so I ride the crap out of it. No issues for me but I don't write a blurb in Bike Rag so take it for what it is worth.
    "Set the gearshift for the high gear of your soul".
    It's hard to see how user error could cause tire rubbing at full compression, unless the frame has been modified or the shock isn't the correct i2i and stroke. Bottom out is bottom out, regardless of rider weight or shock sag. Ideally, the shock should bottom out before the tire contacts the seat tube.
    orthonormal
    Reputation: andy f's Avatar
    It's not an issue of a volume reducer or not running the shock with enough pressure. You should be able to completely compress the rear end with zero pressure without the tire making contact. That is absolutely a design flaw. That said, Ventana is an awesome company and I'm sure they'll sort things out quickly and take great care of their customers
    The glass is twice as large as it needs to be
    orthonormal
    Ventana will definitely take care of their customers; they always do. The issue would be more prospective customers reading the review. They'll probably shy away, which is bad. Lots of damage control to do.
    Agreed, but some here are blaming the reviewer for faulty shock set up. That's BS.
    Two Tired
    Reputation: CheapWhine's Avatar
    Dec 2005
    More article details
    I was wondering when comments on this article would show up. I don't own a Zeus (still on an X-5), but this seems like a major design flaw. There should not be any "standard" size tire that can hit the frame under any conditions. In the lower right corner of the photo page, the shock is deflated and the tire is resting against the down tube. The article also stated, "After riding for the photo shoot the paint has completely scrubbed off the frame."
    Sherwood did not do himself a favor with his written response:
    When we get the test bike back from Dirt Rag we will thoroughly check that frame out and see if there is a problem with that particular test bike (turns out your test bike is the one and only 21" sized Zeus we have built so far) and will implement any adjustments to our production frames if necessary at that time. Like the early days with the 29" wheels the 27.5" wheel sized market place is very dynamic right now with new tires entering the market almost daily. As an in-house builder we assess new product and make appropriate adjustments to our frames as needed at almost real time.
    The article makes it sound like the frame was supplied by Ventana and built out using popular parts, none of which should have caused the problem.
    Based on the number of 27.5" bikes in the market now, it is not that immature of a technology, so the response doesn't sound right. Judging by the other comments in this thread, this is not something unknown or unique to this specific 21" frame. To my ear, Sherwood's response doesn't reflect the high level of customer service and customer satisfaction that Ventana has built over the years.
    Too bad.
    Let the good times roll.
    trailroller.com
    fai
    fai is offline
    Sep 2004
    My wife has been using a 16"Zeus for over a year now with a 2.35 Hans Dampf tyres getting full travel without any tyre frame contact with a RP23 shock. I have recently started using a 19" one and use the same tyres but fitted the DHX air that I was using on an El Ciclon. I have been using the shocks full stroke, the bike has been used at a downhill site I did all the big drops. I have not had a problem with any tyre frame contact with my bike set up as it is. I did have this issue on an X5 but a shock retune sorted that. I am interested in finding out what other Zeus owners have come across this tyre frame contact.
    AJR
    Quote Originally Posted by CheapWhine View Post
    Too bad.
    Although I don't find Sherwood's comment to be that odd, I do believe he has to go into damage control mode and quickly deal with this. I still keep the Zeus on the list of maybe to buy next bikes, but this issue has to be resolved or at least an answer as to why this has happened.
    Was the paint scrubbed off on the back off the seat tube? Because if that was the case than we aren't talking about an occasional hit but indeed about something that is a major issue.
    But I also read a lot people here saying they don't have this problem on their Zeus. So I'm even more keen on finding out what was wrong here?
    For those who don't have tire rubbing, please post which travel setting you're using.
    fai
    fai is offline
    Sep 2004
    My wife and I both use the 160mm travel setting.
    AJR
    140 mm, no tire rub with a Nobby Nic 2.35.
    Ok, thanks. If there's no tire rub at bottom-out in the 160mm setting with a 2.35 Hans Dampf, I personally wouldn't be thinking "design flaw," nor would I worry about it.
    Well thats good to know but I would still like to know why they had this issue.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Ventana may have to hire one of those highly paid Spin Miesters to do damage control. I can't see this design flaw going over well with prospective 650B customers now there are so many other offerings. I hope for the best
    Quote Originally Posted by TPA8580 View Post
    Indeed. On the one hand, fai is using a full 160mm with a Hans Dampf, which is big for a 2.35 (probably big enough to be acceptable as a max. tire size), without tire/frame contact. On the other, P. Paul and Dirt Rag have had rubbing with nominally smaller tires. So the mystery is yet to be solved!
    Could some frames be different from others? All sizes share the same 74º seat tube angle, swingarm length, and pivot placements, so it seems unlikely. I wonder if the different shocks might have just minor variations in i2i and/or stroke, enough to allow rubbing on some frames but not on others. I have had shocks that didn't measure out exactly to spec in the past. Hmmm.
    Elitest thrill junkie
    Reputation: Jayem's Avatar
    Remember that air-shocks have a rubber bumper in them, so if it stops 1 or 2mm short with all the air out of the shock, it'll still hit during a real compression on the trail that uses all or nearly all of the travel.
    There was also something that the DR issue said about frame size. What size frames does Fai and his wife have?
    As far as shocks, yes, there can be variations. I've had it with Fox (a 7.87in shock ended up measuring 8" exactly i2i) and with a CCDB (one fit my Ciclon where the other didn't, but didn't measure it to see the difference).
    Keep in mind I ride small frames, so the i2i is more of a fitment issue than what it would do with the tire hitting the seat tube.
    Apparently the frame was a 21" frame which Sherwood said was their first. So it may lie in the geometry of the the very large frame.
    I myself would go for a small frame 15'5" or 16" frame so maybe the problem wouldn't be a problem there.
    But Still I wonder what the frames sizes are of the people who don't have this issue and what their riding style is like. I would definitely like to use it for the AM or even Enduro side of things.
    Reputation: Vespasianus's Avatar
    And in most cases, that "rubber bumper" is really just an O-ring.
    On MTBR, the reputation is infamous.
    I've been on a 19" Zeus since late Feb. (could be March, time flies) and have run it in both 160mm and 140mm, but mostly 140mm with 2.3 Hans Dampf tires without any rub. The bike has been to Whistler, Squamish, raced in the Cascadia Cup Enduro and seen lots of 4-5ft drops. I run a 160mm fork and weigh 215 and the seat tube shows zero evidence of rub. That said, it was pretty easy to run out to the garage and see whats what. In the 140mm setting zero rub, In the 160mm setting... uh, rub.
    Clean Seat tube. No signs of rub after lots of abuse in mostly the 140mm setting
    Fully compressed in the 140mm setting. Close, but zero rub with a fully inflated Hans Dampf
    160mm setting and fully compressed. The tire is easily pressed into the seattube about an 1/8 of an inch.
    Last edited by wipp; 10-01-2013 at 10:28 PM. Reason: Added captions and corrected purchase date
    Dec 2004
    Quote Originally Posted by JC822 View Post
    Whoa, I hope that isn't true...the solution for a new 2300.00 frame is to send the shock out to a third party shock upgrade specialist for additional money, time and warranty voiding????
    Wipp, thanks for the clear, definitive pics. So it seems that the Zeus can't be run at 160mm with a 650b rear wheel and meaty tire without some rubbing at bottom-out.
    Maybe V will offer a new rocker with a slightly shorter max travel setting. Solutions for now seem to be the 140mm setting, 26" rear wheel, or just living with occasional tire/frame contact. (A friend of mine has ridden his Stinky for years with a nice polished spot on the back of the seat tube!)
    Albeant, my Zeus has always felt better at 140mm than 160mm, so for the most part I'm very happy with the frame, the quality is incredible and I've never felt short changed running it at 140mm. In the 160mm setting the spring rate was too linear for my taste. Not sure about the smaller wheel size in the back... but if your going to run a 2.5 tire it does make some sense in the 160mm setting, if I had any little wheels left I'd give it a try.
    All that said, I hope the folks at Ventana will offer a 150mm rocker with a slightly more progressive feel than the 140mm. Really splitting hairs with that request, because 10mm is about .4 inches of travel but why not ask?
    fai
    fai is offline
    Sep 2004
    Zeus frame design flaw?-dsc_1622.jpgI have now done just over 200 miles on my Zeus 160mm travel. No problem as you can see.
    AJR
    Quote Originally Posted by fai View Post
ID:	836261I have now done just over 200 miles on my Zeus 160mm travel. No problem as you can see.
    so, how 'bout letting the air out of the shock & taking pictures showing clearly the space between the tube/tire, like wipp's
    breezy shade
    Reputation: OldHouseMan's Avatar
    Ventana is losing credibility on this. I do hope they offer a fix, but silence says a lot.
    Sherwood has not posted a public reply about this here or anywhere else, nor has anything been posted on their website (other than you can buy a complete bike now). Shame too.
    IMO, Ventana is far from losing credibility over this one. Sure, it's not ideal for this to come to light with the new models, but as far as I know, this is one of the first problems across a model line-up (If it truly is across the whole Zeus model line) that I've seen from Ventana. Take a look at some of the other forums (Niner is a good example) and the problems seem to run rampant.
    I'm also not saying these types of problems are expectable either, but it definitely shouldn’t tarnish the reputation of a otherwise stand-up company.
    I only ride bikes to fill the time when I'm not skiing.
    Quote Originally Posted by wipp View Post
    Thanks Wipp for the indeed very clear pictures.
    The Zeus is becoming less and less of a favorite in my book, although I'm not willing to drop it just yet. But I really would like to know exactly how come a bunch of people have rub and a bunch don't.
    To me this is looking more and more like a shock pressure issue. This combined with tires larger than 2.25 tires.
    But isn't the Zeus meant for the AM/Enduro market? Don't most people in that segment use big tires? And if a frame can do 140/160mm of travel, shouldn't it work just as well in 140mm as in 160mm?
    Sherwood needs to fix this or at least come with a recommendation on how to solve the issue. A different rocker might change this but reducing the travel would in my book make the frame just not well designed. In other words a reduction in travel would make me choose something else.
    But I have faith that this will be sorted out and I will give Sherwood and his crew a chance to fix this. But if by next year this issue still persists than I will spend my money elsewhere.
    I think a lot of people don't have problems because it's pretty damn hard to use 100% of the shocks travel when the shock is aired up, in fact I think it's near impossible. I also don't think it's a good idea to rely on the shock air pressure vs frame design to prevent rub. I'm not looking for that extra travel but I might want to run an even bigger tire at some point so a fix would be good.
    Ventana Mountain Bikes
    We just got the test bike back this week. Will take a bit of time to see what is up.
    I have been silent because I had nothing to say since I had not had the opportunity to see the test bike. One thing I will say is that my response printed in the magazine was taken a bit out of context in that I was answering a differently directed question regarding tire, size, and rub and based on the tester's tire description I mistakenly thought he had gotten ahold of a new tire that was not available to the public yet...but somehow due to space, or whatever, that question did not show up in the article but my response did.
    I will post up here when I figure out what is up and I won't speculate until I have time to look things over. In the end there is no reason why a customer shouldn't be able to run a fat 650b tire on a Zeus and you can rest assured that I will make it so.
    SPG
    "One lick from the lollipop of mediocrity and you suck forever" anonymous
    Perhaps we should look at this issue and ask what was wrong with the 26"er's? When you read online or print issues the complaints were first 29"er's posing design and travel limitations, so the industry stepped in and said hey what about 650B. Us as consumers enjoy the latest and sometimes not always the greatest products, so we gave 29ers and 275 a shot and here we are again facing design limitations and travel issues with larger wheels- 275. Frame builders essentially are trying to deliver for consumers the ride characteristics of a 26'er but for the bigger wheels. When reviews are done for the larger wheeled bikes the nic-picks look for characteristics that liken to the handling and fit of a 26"er.
    I don't intend this to be a wheel debate, just a thought.
    Yes 29"ers can be faster in the right environment
    275 could be the answer for those looking for a bit more roll over roots and rocks but share similar traits to a 26"er.
    ......and 26"er has been around we've logged many miles on them, had many great rides and suited many disciplines of mountain biking.
    I've had my Zeus for just over a year and had ZERO rubbing issues. I have a 17" frame and have run 2.3 Neomotos until they were toast and now am running 2.35 Nobby Nics (the Nobby Nics are significantly larger tires with better grip IMHO). Other than the very first ride, I've been running the rear at 160mm and do bottom out the shock every week or so. If it would have happened at all I would have seen it. There might be rubbing issues with the larger sizes, but not the 17" that's for sure.
    fai
    fai is offline
    Sep 2004
    I cannot understand why some frames have a problem and some do not. I have let all the air out of the shocks on my wifes and my own Zeus frames and is not possible to get the tyre to contact the seat tube. It is clear that this is not the case on all frames. This is a question I do not have an answer to. They are all made on the same jig and should have the same parts. I know the swing arm is the same as a 26" with different dropouts and the rockers and connecting arm from the swing arm to the rockers are different. I have measured the difference in length of the arms the 26" is approx 345mm and the 27.5 is approx 360mm. These parts look the same and if by some chance the wrong one was fitted then I can see a real problem with contact. I am not giving that as an explanation, but if one frame clears then they all should.
    AJR
    fai
    fai is offline
    Sep 2004
    Had to wait to get someone to push down on the saddle. This is pushed down as far as the shock allows.Zeus frame design flaw?-zeus-005.jpg
    AJR
    fai
    fai is offline
    Sep 2004
    This is with me sitting on it with no air in the shock.Zeus frame design flaw?-zeus-004.jpg I cant explain it.
    AJR
    El CicloPath!!!!!!!
    Nov 2012
    In my experience with a lot of single pivot designs, all have the potential of having the tire contact the seat tube with the limiting factor being the shock stroke. Actually, all frames have this potential issue if the swing arm follows a similar arc. Take the shock off any fully, and i think you can compress and get them all to touch, so doest it have to do with shock stroke, spring rate/weight, and set up?
    Different shock, different stroke?
    This is with me sitting on it with no air in the shock.Click image for larger version.
ID:	836406 I cant explain it.
    No known cure
    Reputation: Vader's Avatar
    Quote Originally Posted by Fachiro1 View Post
    On the previous generation frame, I remember the upper yoke of the seatstays was being relived on the underside for clearance. I sent my rear end in and this was not done to my chainstay. I've never e perienced contact but I'm running a coil shock if that makes a difference.
    Ripping trails and tipping ales
    El CicloPath!!!!!!!
    Nov 2012
    After looking at a lot of different pics of different frames....I think the other big factor would be the angle of the seat tube in relation to the pivot location.
    Thanks Fai, for showing those pictures. Indeed it may be a combo of shock, frames size and fairy dust
    But it's good to know that Sherwood is on it. I'll wait for his opinion.
    I too would go for a different shock, probably a Cane Creek or an Xfusion.
    What kind of fork are you using a 160mm travel fork? And do you have the standard head angle?
    fai
    fai is offline
    Sep 2004
    Standard 19" frame Fox 36RC2 fork.
    AJR
    Fwiw, not even close to seat rub at full compression on 160 mode and maxxis highroller 2.5. Mine is an el cap front with a Zeus rear and 24 inch seat tube, so not exactly the same as the other posts...
    Quote Originally Posted by sirsam84 View Post
    It looks like the shock is mounted in the forward position, which nets 140mm.
    Yup. I'll bet your tire is just kissing the seat tube at 160mm.
    Quote Originally Posted by albeant View Post
    Lol...shoot, I had that chip figured out backwards...makes sense though. Dumb question...do I have to do anything other than remove bolts and flip the chip to change travel?
    No, just unbolt and flip the chip. You may also have to add some washers to be able to fully tighten the bolt...
    Wow...that is crazy. Maybe the preconceived Notion that it was 160 mm of travel, but that 140 felt like 160!
    Whew! Maybe 1/8 inch clearance with real 160 of travel...really glad I read this thread: probably would have kept on riding thinking I was at 160 ad never changed it!
    Update?
    160 is different from 140...definitely more linear feel to the shock. Part of thi is probably due to my 260 lbs, but I'm now thinking about getting the ctd pushed.
    Definitely no tire contact on te seat tube from riding.
    May 2005
    I read the review and it was funny to see the writer go from saying "this is the best bike I have ridden during my time at dirt rag" to saying the bike was completely flawed. One question , could the clearance differences be connected to 142x12 vs 135qr? I've got a carbine 275 and know what dropout changed can do to a frame
    Great question. Hadn't thought of that at all.
    I'm running the 142 thru axle and have rub
    Quote Originally Posted by atlas4gr View Post
    The Dirt Rag Zeus is also 142 thru.
    May 2005
    I'd think a set of modified 142 dropouts (longer) would do the trick
    Just reading through this and wanted to note that the 2.25 wild grip'r in the non advanced version is a big tire. I have them on two bikes and they measure out about the same size as a Hans Dampf. The advanced version is a smaller casing.
    Sent from my iPad using Tapatalk HD so please forgive the typos that occur when typing with two fingers.
    Riding slowly since 1977.
    May 2005
    I read recently that the 2.35 actually measures in at 2.5 so I believe you
    Mine is a 142 dropout...tire is a true 2.5 highroller...no rub at all...
    fai
    fai is offline
    Sep 2004
    I have just looked at the pictures of the Zeus on the Dirt Rag website that they were using. The bolt on rear dropouts are different to those on the Zeus frames that my wife and I have. They do however look like the ones fitted to my El Ciclon. Zeus owners check your dropouts compared to the picture on Dirt Rag website and compare to see if you have the longer dropout.
    AJR
    Rub but no Rub. What's the Rub?
    Went out with the bike today in the 160mm mode and flat landed a medium sized (3-4') BMX jump five or six times real hard to see if I could get it to rub. The shock was set at 200lbs and 20%(ish) sag and 215lbs of royal self on the bike. Zero rub.
    On the stand, when I completely let the air out of the shock I get rub. In real life on the trail, no rub. So... no rub, until it rubs I guess. Either way I'd still like a rocker that split the difference at 150mm and was as progressive as the 140mm setting on the current rocker.
    All that said, awesome frame. It's held up well over a season of use and abuse and the geo is spot on for me. My only real complaint is that it doesn't fly or peddle itself up hills
  67. #67
    May 2005
    Fai do you have a picture of your dropouts?
  68. #68
    fai
    fai is offline
    Sep 2004
    <a href="http://www.flickr.com/photos/67399715@N06/7651434456/" title="zeus dropout by Alanatriversidecyclecentre, on Flickr"><img src="http://farm8.staticflickr.com/7140/7651434456_747218105d.jpg" width="500" height="335" alt="zeus dropout"></a>
    This is the dropout type on the two Zeus frames we have. I know this is not a 142x12 but it still has the machined dimple as the 142x12 dropout on mine has. As you can see the axle is further back than the one on the Zeus pictured in Dirt Rag.
    AJR
  69. #69
    May 2005
    you're right, looks like 1/4" plus
  70. #70
    Feb 2013
    I have had my Zeus for over a year, and it has never rubbed under my fat ass! Seriously the best bike I have ever owned and I owned a bike shop for 14 years. Quality is second to none, and Sherwood stands by his products 100%. If there is a problem it will be fixed.
  71. #71
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Should not happen.
  72. #72
    Damn it, i got rub today. Big G-out to a step up and- Brbrbrbrbrb. Didn't effect much, but it was there.
  73. #73
    That sucks! Do you know if you have the correct dropouts? I wonder if their is a solution yet to the problem.
  74. #74
    Not sure what the correct dropouts are? I forgot to mention that I just mounted a pair of fresh Conti 2.4 Mountain Kings- they seem narrower but maybe slightly taller than the poky Hans Dampf tires that they replaced. Nice to be running Conti's again, even if they buzzz!
    Quote Originally Posted by mtnbiker4life View Post
  75. #75
    Posts #3 & #4 on this page show pictures of both.
  76. #76
    not the greatest pic, but it seems to be more milled out than post #4 and maybe slightly further back.
  77. #77
    Mine looks pretty much like Wipp's, but I am definitely not getting rub will full compression and Maxxis High-Roller II's 2.5...
  78. #78
    OK, this is a completely stupid oversight on my part- after cleaning up my bike I noticed that my new rear wheel way out of dish, enough to easily cause rub in a G out, so I don't think there was any rub on the seat tube it was completely on the seat stay and completely my fault. After re-dishing the wheel I went back to the same trails and zero rub. So... no rub.
  79. #79
    Proud lame eBiker
    Reputation: Internal14's Avatar
    Brilliant!
    www.velocitybicycles.comWhere customers become friends, not simply a dollar sign.
  80. #80
    Proud lame eBiker
    So a wheel out of dish causes the rub?
    "a completely stupid oversight on my part- after cleaning up my bike I noticed that my new rear wheel way out of dish, enough to easily cause rub in a G out, so I don't think there was any rub on the seat tube it was completely on the seat stay and completely my fault."
    I'm guessing this: Wheel out of dish...probably undertensioned, possibly....27.5" rim/wheel a bit more flex to it than a 26"......when loading the bike hard in the g-out it was probably not spot on dead straight up and down perpendicular to ground so loaded frame/flexed rim/tire buzzed SEATSTAY.
    wigg was hyper aware of any tire rub noise after reading this thread and heard the noise and drew his conclusions without due diligence of deflating rear shock and compressing shock to see if it WAS the tire hitting the SEAT TUBE.
    I'm making a HUGE amount of ASSumptions in my theory....so we'll have to wait for wigg to get back to this thread. He's probably out ripping it up instead of e-biking like the rest of us saps staring at a computer.
  81. #81
    Who's Wigg?
    I'm making a HUGE amount of ASSumptions in my theory....so we'll have to wait for wigg to get back to this thread. He's probably out ripping it up instead of e-biking like the rest of us saps staring at a computer.[/QUOTE]
  82. #82
    Proud lame eBiker
    Wigg=wipp At least in my feable mind. Doh!
    Who's Wigg?
    B
    [/QUOTE]
  83. #83
    OK.
    So, both the Conti and the Hans Dampf rub if all the air is out of the shock. Neither rubs if my wheel isn't almost a 'friggin half inch out of dish and I've got air in the shock. The wheel is a new build and was properly tensioned. I'm guessing that it wasn't set in the stand correctly for the final round of tensioning nor was it checked for dish afterwards. It was an easy enough fix and all is good.
    Still a huge fan of the bike and looking forward to racing it next season.
    Quote Originally Posted by Internal14 View Post
    [/QUOTE]
  84. #84
    Hi Guys, any word yet on what caused the rub. If they find it they should give it back to dirt mag to let them have a go at it again.
  85. #85
    Ultra Ventanaphile
    Dec 2001
    I've got the bike now, flogging it and finding NO RUB, will do a full write up when I'm done demo'ing. But for now, here's a teaser pic. Zero rub after this Clyde did this drop twice.
    <iframe src="https://www.flickr.com/photos/31268906@N08/12092313035/player/3c654be421" height="708" width="1024" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    -Aaron G.
  86. #86
    fai
    fai is offline
    Sep 2004
    Great shot and technique.
    AJR
  87. #87
    Can you bottom-out the shock in 160mm mode without tire/frame contact?
  88. #88
    fai
    fai is offline
    Sep 2004
    I have never been able to get the tyre to touch even when I knock the o- ring off the shock.
    AJR
  89. #89
    Ultra Ventanaphile
    Dec 2001
    I bottomed out the shock on the first drop, (O-ring fell off shaft)
    and no rub. Second attempt o-ring did not fall off (measured out to 58mm of stroke and again no rub.
    I wanted to wait for my full review before explaining, but simply put. The issue was human error. As seen in the DR picture the 26" Dropouts were installed for checking alignment. And accidently left on. They should have been swapped out for the 27.5 dropouts that are marked by the extra machined divots, round for 135mm and squared off for thru axle.
    All customer bikes go through secondary QC that would have caught this error, The DR bike didn't as it was shipped out right away to them.
    Mechanically the design is just fine. As demonstrated by my 225#’s beating on it without any issues.
    -Aaron G.
  90. #90
    Thanks for the info. Good to hear that the DR Zeus was an isolated problem.
    So now I'm wondering what happens when one bolts up the Zeus dropouts to a Ciclon. 650b clearance?
  91. #91
    Second that. I've tried but it just won't rub ;-)
  92. #92
    a totally honest mistake made by people working for a totally honest company. that's the way i see it.
    breezy shade
  93. #93
    fai
    fai is offline
    Sep 2004
    The swingarm is the same but the brake stay and rockers are different. You would probably have clearance problems at full travel as well as messing with the bb height.
    AJR
  94. #94
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by Ciclistagonzo View Post
    Speaking of my review, here it is with more pics.....
    Demo'd a Zeus, my review with Pics.
    -Aaron G.
  1. Design feature or flaw.... Fuel EX8 Frame flex
    By DenDerWuz in forum General Discussion
    Last Post: 09-17-2013, 02:26 AM
  2. SRAM X.9 Rear Derailleur has got a rather annoying design flaw!
    By kapusta in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-15-2013, 06:16 AM
  3. W.T.Hel..........! possible design flaw in RIP RDO
    By AZmtncycler in forum Niner Bikes
    Last Post: 09-14-2013, 04:22 PM
  4. SPECIALIZED ENDURO warranty design flaw
    By 2biker in forum Specialized
    Last Post: 02-23-2012, 07:05 AM
  5. minor Fantom 29er frame gripe. design flaw?
    By dr.mediocre in forum Motobecane
    Last Post: 04-12-2011, 08:20 AM
Members who have read this thread: 4
