Page 2 of 3 FirstFirst 123 LastLast
Results 51 to 100 of 105
  1. #51
    Lol...shoot, I had that chip figured out backwards...makes sense though. Dumb question...do I have to do anything other than remove bolts and flip the chip to change travel?
  2. #52
    No, just unbolt and flip the chip. You may also have to add some washers to be able to fully tighten the bolt...
  3. #53
    Wow...that is crazy. Maybe the preconceived Notion that it was 160 mm of travel, but that 140 felt like 160!
  4. #54
    Whew! Maybe 1/8 inch clearance with real 160 of travel...really glad I read this thread: probably would have kept on riding thinking I was at 160 ad never changed it!
  5. #55
    Update?
  6. #56
    160 is different from 140...definitely more linear feel to the shock. Part of thi is probably due to my 260 lbs, but I'm now thinking about getting the ctd pushed.
    Definitely no tire contact on te seat tube from riding.
  7. #57
    May 2005
    I read the review and it was funny to see the writer go from saying "this is the best bike I have ridden during my time at dirt rag" to saying the bike was completely flawed. One question , could the clearance differences be connected to 142x12 vs 135qr? I've got a carbine 275 and know what dropout changed can do to a frame
  8. #58
    Great question. Hadn't thought of that at all.
  9. #59
    I'm running the 142 thru axle and have rub
    Quote Originally Posted by atlas4gr View Post
  10. #60
    The Dirt Rag Zeus is also 142 thru.
  11. #61
    May 2005
    I'd think a set of modified 142 dropouts (longer) would do the trick
  12. #62
    Zeus frame design flaw?
    Just reading through this and wanted to note that the 2.25 wild grip'r in the non advanced version is a big tire. I have them on two bikes and they measure out about the same size as a Hans Dampf. The advanced version is a smaller casing.
    Sent from my iPad using Tapatalk HD so please forgive the typos that occur when typing with two fingers.
    Riding slowly since 1977.
  13. #63
    May 2005
    I read recently that the 2.35 actually measures in at 2.5 so I believe you
  14. #64
    Mine is a 142 dropout...tire is a true 2.5 highroller...no rub at all...
  15. #65
    fai
    fai is offline
    Sep 2004
    I have just looked at the pictures of the Zeus on the Dirt Rag website that they were using. The bolt on rear dropouts are different to those on the Zeus frames that my wife and I have. They do however look like the ones fitted to my El Ciclon. Zeus owners check your dropouts compared to the picture on Dirt Rag website and compare to see if you have the longer dropout.
    AJR
  16. #66
    Rub but no Rub. What's the Rub?
    Went out with the bike today in the 160mm mode and flat landed a medium sized (3-4') BMX jump five or six times real hard to see if I could get it to rub. The shock was set at 200lbs and 20%(ish) sag and 215lbs of royal self on the bike. Zero rub.
    On the stand, when I completely let the air out of the shock I get rub. In real life on the trail, no rub. So... no rub, until it rubs I guess. Either way I'd still like a rocker that split the difference at 150mm and was as progressive as the 140mm setting on the current rocker.
    All that said, awesome frame. It's held up well over a season of use and abuse and the geo is spot on for me. My only real complaint is that it doesn't fly or peddle itself up hills
  17. #67
    May 2005
    Fai do you have a picture of your dropouts?
  18. #68
    fai
    fai is offline
    Sep 2004
    <a href="http://www.flickr.com/photos/67399715@N06/7651434456/" title="zeus dropout by Alanatriversidecyclecentre, on Flickr"><img src="http://farm8.staticflickr.com/7140/7651434456_747218105d.jpg" width="500" height="335" alt="zeus dropout"></a>
    This is the dropout type on the two Zeus frames we have. I know this is not a 142x12 but it still has the machined dimple as the 142x12 dropout on mine has. As you can see the axle is further back than the one on the Zeus pictured in Dirt Rag.
    AJR
  19. #69
    May 2005
    you're right, looks like 1/4" plus
  20. #70
    Feb 2013
    I have had my Zeus for over a year, and it has never rubbed under my fat ass! Seriously the best bike I have ever owned and I owned a bike shop for 14 years. Quality is second to none, and Sherwood stands by his products 100%. If there is a problem it will be fixed.
  21. #71
    Axe
    Axe is offline
    Custom User Title
    Reputation: Axe's Avatar
    Quote Originally Posted by wipp View Post
    160mm setting and fully compressed. The tire is easily pressed into the seattube about an 1/8 of an inch.
    Should not happen.
  22. #72
    Damn it, i got rub today. Big G-out to a step up and- Brbrbrbrbrb. Didn't effect much, but it was there.
  23. #73
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    That sucks! Do you know if you have the correct dropouts? I wonder if their is a solution yet to the problem.
  24. #74
    Not sure what the correct dropouts are? I forgot to mention that I just mounted a pair of fresh Conti 2.4 Mountain Kings- they seem narrower but maybe slightly taller than the poky Hans Dampf tires that they replaced. Nice to be running Conti's again, even if they buzzz!
    Quote Originally Posted by mtnbiker4life View Post
  25. #75
    Posts #3 & #4 on this page show pictures of both.
  26. #76
    not the greatest pic, but it seems to be more milled out than post #4 and maybe slightly further back.
  27. #77
    Mine looks pretty much like Wipp's, but I am definitely not getting rub will full compression and Maxxis High-Roller II's 2.5...
  28. #78
    OK, this is a completely stupid oversight on my part- after cleaning up my bike I noticed that my new rear wheel way out of dish, enough to easily cause rub in a G out, so I don't think there was any rub on the seat tube it was completely on the seat stay and completely my fault. After re-dishing the wheel I went back to the same trails and zero rub. So... no rub.
    Quote Originally Posted by sirsam84 View Post
  29. #79
    Proud lame eBiker
    Reputation: Internal14's Avatar
    Brilliant!
    www.velocitybicycles.comWhere customers become friends, not simply a dollar sign.
  30. #80
    Proud lame eBiker
    Quote Originally Posted by Stripes View Post
    So a wheel out of dish causes the rub?
    "a completely stupid oversight on my part- after cleaning up my bike I noticed that my new rear wheel way out of dish, enough to easily cause rub in a G out, so I don't think there was any rub on the seat tube it was completely on the seat stay and completely my fault."
    I'm guessing this: Wheel out of dish...probably undertensioned, possibly....27.5" rim/wheel a bit more flex to it than a 26"......when loading the bike hard in the g-out it was probably not spot on dead straight up and down perpendicular to ground so loaded frame/flexed rim/tire buzzed SEATSTAY.
    wigg was hyper aware of any tire rub noise after reading this thread and heard the noise and drew his conclusions without due diligence of deflating rear shock and compressing shock to see if it WAS the tire hitting the SEAT TUBE.
    I'm making a HUGE amount of ASSumptions in my theory....so we'll have to wait for wigg to get back to this thread. He's probably out ripping it up instead of e-biking like the rest of us saps staring at a computer.
  31. #81
    Who's Wigg?
    I'm making a HUGE amount of ASSumptions in my theory....so we'll have to wait for wigg to get back to this thread. He's probably out ripping it up instead of e-biking like the rest of us saps staring at a computer.[/QUOTE]
  32. #82
    Proud lame eBiker
    Wigg=wipp At least in my feable mind. Doh!
    Who's Wigg?
    B
    [/QUOTE]
  33. #83
    OK.
    So, both the Conti and the Hans Dampf rub if all the air is out of the shock. Neither rubs if my wheel isn't almost a 'friggin half inch out of dish and I've got air in the shock. The wheel is a new build and was properly tensioned. I'm guessing that it wasn't set in the stand correctly for the final round of tensioning nor was it checked for dish afterwards. It was an easy enough fix and all is good.
    Still a huge fan of the bike and looking forward to racing it next season.
    Quote Originally Posted by Internal14 View Post
    [/QUOTE]
  34. #84
    Hi Guys, any word yet on what caused the rub. If they find it they should give it back to dirt mag to let them have a go at it again.
  35. #85
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by TPA8580 View Post
    I've got the bike now, flogging it and finding NO RUB, will do a full write up when I'm done demo'ing. But for now, here's a teaser pic. Zero rub after this Clyde did this drop twice.
    <iframe src="https://www.flickr.com/photos/31268906@N08/12092313035/player/3c654be421" height="708" width="1024" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
  36. #86
    fai
    fai is offline
    Sep 2004
    Great shot and technique.
    AJR
  37. #87
    Can you bottom-out the shock in 160mm mode without tire/frame contact?
  38. #88
    fai
    fai is offline
    Sep 2004
    I have never been able to get the tyre to touch even when I knock the o- ring off the shock.
    AJR
  39. #89
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by albeant View Post
    I bottomed out the shock on the first drop, (O-ring fell off shaft)
    and no rub. Second attempt o-ring did not fall off (measured out to 58mm of stroke and again no rub.
    I wanted to wait for my full review before explaining, but simply put. The issue was human error. As seen in the DR picture the 26" Dropouts were installed for checking alignment. And accidently left on. They should have been swapped out for the 27.5 dropouts that are marked by the extra machined divots, round for 135mm and squared off for thru axle.
    All customer bikes go through secondary QC that would have caught this error, The DR bike didn't as it was shipped out right away to them.
    Mechanically the design is just fine. As demonstrated by my 225#ís beating on it without any issues.
    -Aaron G.
  40. #90
    Thanks for the info. Good to hear that the DR Zeus was an isolated problem.
    So now I'm wondering what happens when one bolts up the Zeus dropouts to a Ciclon. 650b clearance?
  41. #91
    Second that. I've tried but it just won't rub ;-)
  42. #92
    a totally honest mistake made by people working for a totally honest company. that's the way i see it.
    breezy shade
  43. #93
    fai
    fai is offline
    Sep 2004
    The swingarm is the same but the brake stay and rockers are different. You would probably have clearance problems at full travel as well as messing with the bb height.
    AJR
  44. #94
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by Ciclistagonzo View Post
    Speaking of my review, here it is with more pics.....
    Demo'd a Zeus, my review with Pics.
    -Aaron G.
  1. Design feature or flaw.... Fuel EX8 Frame flex
    By DenDerWuz in forum General Discussion
    Last Post: 09-17-2013, 03:26 AM
  2. SRAM X.9 Rear Derailleur has got a rather annoying design flaw!
    By kapusta in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-15-2013, 07:16 AM
  3. W.T.Hel..........! possible design flaw in RIP RDO
    By AZmtncycler in forum Niner Bikes
    Last Post: 09-14-2013, 05:22 PM
  4. SPECIALIZED ENDURO warranty design flaw
    By 2biker in forum Specialized
    Last Post: 02-23-2012, 07:05 AM
  5. minor Fantom 29er frame gripe. design flaw?
    By dr.mediocre in forum Motobecane
    Last Post: 04-12-2011, 09:20 AM
