Results 1 to 10 of 10
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    X-5 Build weights
    Would like to build something in the less than 28-30 lbs catagory. Could you guys post your builds and their corresponding weights. Thanks alot have a good week.
    JORBA: Six Mile Run
    Reputation: Wobbegong's Avatar
    28.4 lbs. on my scale
    Quote Originally Posted by jrm
    My scale tells me 28.4 lbs.
    Specs are:
    Medium X-5 with quad bearings-fox float w/ propedal
    Fox vanilla fork
    King headset
    Thomson 90mm 5 degree stem
    Easton EC70 Monkeylite xc bar
    Odi lock on ruffian grips
    Thomson Post
    WTB Laser titanium rail seat
    Avid Juicy Seven brakes
    WTB Laserlite disc hubs/ DT Swiss xr 4.1d rims
    Sram X9 triggers
    XT Front der.
    Sram X9 rear der.
    04 XT Cranks
    04 XT Cassette
    Sram PC-99 chain
    Schwalbe Little Albert tires
    jrm
    jrm is offline
    My set up would be almost exact
    Quote Originally Posted by Wobbegong
    Specs are:
    Fox vanilla fork
    King headset
    Thomson Post
    Sram X9 triggers
    XT Front der.
    Sram X9 rear der.
    04 XT Cranks
    04 XT Cassette
    Sram PC-99 chain
    Except for using a Talas, Sram twisters, CK hubs and a BG .2.1 in back and a FA up front..
    Model of Grace and Tact
    Reputation: Scary Mc's Avatar
    Mine is at 34lbs, but I went w/ bomber parts instead of worrying about weight. Z1FR, Rhyno Lite XL's, 2.4's Romic and such....
    Reputation: gonzostrike's Avatar
    mine's nudging 34 lbs as follows:
    medium frame w/ Quad bearings and Romic coil-over
    '03 Marzocchi Z1 FR QR20
    King headset
    Thomson 90x5 stem
    Answer ProTaper 2" rise 27" wide bar
    SRAM X-7 trigger shifters
    Avid SD Ultimate levers
    ODI Lock-On Ruffians
    Hadley 20mm disc front hub
    Avid mech disc 185mm rotor front and rear
    Hadley DH 135mm wide, 10mm thru axle disc rear hub
    14/15 db spokes, Mavic XM321 rims
    Kenda Stick-E Kinetics 2.35 tires
    Thomson 410mm post
    Hope QR post collar
    WTB Rocket V Stealth saddle
    SRAM 9.0 11-34t cassette
    SRAM X-7 rear der
    Shimano XT front der
    Race Face Turbine LP Isis 175mm crank arms w/ 34t middle ring, 22t litte ring, BlackSpire Ring God bash ring.
    Race Face Evolve FR bottom bracket
    Crank Bros Mallet C pedals
    Reputation: MMcG's Avatar
    Jul 2003
    Quote Originally Posted by gonzostrike
    King headset
    Thomson 90x5 stem
    Thomson 410mm post
    Hope QR post collar
    SRAM X-7 rear der
    Hey Gonzo - could you email me a photo of your X-5?
    Also, what is your weight and what springs oil weight/height are you running in your Z1 - I've got one on my Belair now and I'm trying to get it dialed in.
    Mark
    mailto: mmcgrath AT foundation DOT uconn DOT edu
    Quote Originally Posted by CTRider
    Mark
    Below is a picture from Tuesday's ride.
    Z1 is (honestly!) still running original springs and original oil at whatever height Marz filled. I've got some Bel Ray 10wt waiting to go into it, but I'm too fargin' lazy to change the oil!
    Also, I'm trying to decide what fork I'm really going to use... I need a 6" fork up there and want to wait to see all the options -- Fox 36, Marzocchi 66, Manitou Nixon, and, if the rumors are true, Manitou Sherman Firefly 6" with 1.125" steerer.
    aka Willy Vanilly
    Reputation: will8250's Avatar
    Aug 2003
    My medium X-5 with quads and a romic is ~ 30, 31 pounds (I think depending on the scale...)
    Fox Vanilla R
    CK Headset
    Titec Hellbent XC Riser
    XTR levers
    X0 Shifters
    xt front der
    xo rear der
    Truvativ Stylo Team cranks w/ a rockguard instead of a big ring
    Truvativ Team SL bb
    Speedplay Frogs
    XT 11-32 cassette
    Avid 160mm BBDB's
    CK ISO rear laced 3x w/ db spokes to a Hugi x4.1d w/ Nokian NBX 2.1" (tubed)
    Hugi 240 front laced 3x w/ db spokes to a Mavic x317 w/ Kenda Blue Groove 2.35 (tubed)
    Any intelligent fool can make things bigger, more complex, and more violent. It takes a touch of genius -- and a lot of courage -- to move in the opposite direction.
    E. F. Schumacher
    sXe
    My X-5 build
    In the 32-33lbs range.
    X--5 with quad, 6" rockers, Romic
    Z1 FR SL
    CK headset
    Answer protaper 2" bars
    Thomson stem and seatpost
    Magura Louise FR discs
    XO Shifters
    XO rear der
    XT Front der
    XT cranks/bb
    XT cassette
    WTB saddle
    Time ATAC pedals
    CK ISO/Mavic 219 wheels
    Salsa Skewers
    WTB MotoRaptors 2.4r Weirwolf 2.5f
    PEM
    X-5 XL Weight
    My XL X5 w Quad bearing kit and FOK Float Pro Pedal weighed 7.0 lbs even.
    Fok Talas R
    CK Headset
    Ritchey WCS stem
    Magura Marta discs 160mm F/R
    Sram XO Twisters
    XO Short Cage Rear
    XT F Der
    XTR Casette
    PC-99 Chain
    Thompson post
    WTB V Stealth seat
    CK Hubs F/R
    DT rims
    DT 14/15 spokes
    Alloy nipples
    Kenda Tomac Nevegal 2.1Tires
    04 XTR Cranks
    Eagbeater Ti pedals
    Weighs in at 26.75 lbs w/o mud.
  1. 25 pounds 5 Spot
    By Davide in forum Turner
    Last Post: 04-05-2007, 02:49 AM
  2. Another New 5 Spot Story
    By Surfer in forum Turner
    Last Post: 03-22-2004, 01:57 AM
  3. 5 Spot v. Switchblade
    By marshall88 in forum Turner
    Last Post: 03-19-2004, 03:45 PM
  4. Turner 5 Spot Fitting.../sizing...
    By mightywarlock in forum Bike and Frame discussion
    Last Post: 03-17-2004, 10:52 AM
  5. Switchblade v. 5 Spot
    By marshall88 in forum Titus
    Last Post: 03-16-2004, 09:12 PM
