Results 1 to 12 of 12
    Cars Hurt.
    What kind of abuse have you put your Ventana through?
    I'm almost finished with my El Capitan build and I have this 4-5' drop in mind that I've never dared to try on my 80mm hardtail. The frame looks like it could take much more than that without a sweat. So fellow Ventana owners, what kind of abuse have you put your bike through? Drops, hucks, ect?
    Space Ghost
    Reputation: Coach417's Avatar
    With that frame, I believe your wheels will be the limiting factor. That has been my experience (Flows/Hopes/Double butted spokes....should have gone straight taper I guess). Or if you are smooth like butter, it won't matter, I'm a hack.
    "No good deed goes unpunished"
    Cars Hurt.
    Thinking back on all the bikes I've owned it seems that the straight gauge spokes break more often. But that could be due to them coming on cheaper wheels that are not build as well. I thought part of the argument for double butted was that they stretched just a little which made for a more supple wheel.
    Mar 2011
    I sold both of mine....
    ....I wish I didnt have to.... Felt like an abusive parent. Does that count?
    -- Feel the gin
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by Michael Ventana
    -- Feel the gin
    I'm calling VPS on you!
    (Ventana Protective Services)
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    T , V , & K Rider
    Depends
    The El Capitan is a pretty robust frame.....I had an 06 that came with 4" travel rockers at the time ! Mine was set up more for xc use but the frame sure seemed to be strong and stiff enough for more adventurous play...it did see a bit of air time but nothing big since I have other bikes for that ! With strong wheels and the right components it should do what your talking......however , as always you pay to play which is just part of this sport ! TIG.
    Mine eventually cracked, but I never did shy away from something that looked fun.
    orthonormal
    Reputation: andy f's Avatar
    The slope of the landing area is a big factor. You can land some pretty big drops with little impact to the frame if there's a nice transition. Drops to flat require you to suck up more of the landing with your arms and legs to limit the beating your bike will take.
    I used to have an urban route I took to work on my old Bianchi BuSS (3.5 lb. Easton Ultralite tubed frame). There were two 3' to flat drops from a cinder block wall into a parking lot that I did almost every day for about 2 years. That frame is now 11 years old and i'm still using it as a commuter. Still have the original wheels on there too.
    The glass is twice as large as it needs to be
    I swear that picture Bunny posted was of my bike on a drop I found off the main line on Slickrock trail. But, I don't have a DHX air on mine - perhaps if I did, I wouldn't have bottomed. . .
    But to answer your question - definitely depends on landing, but their frames take a lot of abuse. I ride things like the picture above pretty regularly for the past 3yrs on mine (going on four) and the only thing I have to show for it is some dings on the seat-tube from hitting the yoke on the seat-stays during drops such as above. Haven't had any headtube issues with the 160mm fork, still quite stiff, overall pretty burly.
    Quote Originally Posted by P-townDave
    which model(s)?
    breezy shade
    Ha ha ha.. that is right off the main line of Slick Rock.
    Quote Originally Posted by nhodge
    which model(s)?
    '08 Ciclon (130mm). Should be a picture of it in "DJ/4x mode" somewhere on the setup thread. . . before a pushed shock, re-paint, bearing replacement. Damn, I've had that thing a while!
