Page 8 of 8 FirstFirst ... 45678
Results 351 to 383 of 383
  1. #351
    Pixie Dust Addict
    El Paulmandante Ultimate
    Frame: '11 20" El Comandante Ultimate
    Frame Color: Mercedes Blue
    Options: full housing rear der cable saddles, cable saddles for dropper post
    Fork: '10 Reba XX with 20mm lowers
    Wheelset: Industry Nine Enduro hubs, 20mm front axle, Stan's Flow rims
    Skewers: DT Swiss 10mm RWS rear
    Seatpost Clamp: Salsa Lip-Lock (Blue)
    Chain: SRAM PC990
    Rear Derailleur: SRAM X.0 9 speed
    Front Derailleur: N/A
    Shifter: SRAM X.0 9 speed
    Cogset: SRAM 9 speed PG990 12-34
    Brakes: Magura Marta SL Magnesium
    Cranks: The Hive FifteenG SS 175mm
    BB: The Hive 30mm BB cups
    Pedals: TIME ATAC ROC
    Headset: Cane Creek 110
    Handlebar: Easton EC70 low-rise
    Seat Post: Gravity Dropper 3" drop
    Stem: Thomson X-4 80mm 0°
    Saddle: WTB Rocket V
    Grips: Extreme Steering Chunky
    Tires: Maxxis Ikon tubeless
  2. #352
    Lightly salted
    Reputation: fuenstock's Avatar
    I havn't posted my build so here it is,
    Small 2012 Ciclon @ 140mm
    Revelation RLT Ti dual air @ 150mm
    canecreek headset
    Xtr 2x9 crankset with gamut bash guard
    Azonic 420 pedals
    xtr front der
    sram xo rear der
    sram xo shifters
    Juicy carbon brakes
    Thomson x4 50mm stem
    Sunline v1 720mm bars
    Peaty grips
    Crossmax xl wheels
    front wtb Bronson 2.3 tire
    rear wtb wierwold 2.1 tire
    kindshock i950r post
    wtb saddle
  3. #353
    is turning a big gear
    Just a new pic...
    Get it unlocked.
  4. #354
    Reputation: Lumagent Morple's Avatar
    I bought this Terremoto a few years back, and just recently got back into riding (after nearly 2 years off the bike). Here it is with a couple new additions (I swapped the DHX coil for a Monarch RT3 and swapped the old chainguide out for an E13 LG-1 Trail):
  5. #355
    Nice, but ¿you don't make long climbs, not you?
    It's surprising for me to see a DH chainguide with an air shock! ¿Monarch is standard or pushed? i had a RP23 Boostvalve on my Terremoto and it was a **** (I sold it). Actually, I'm usin a CCDB with a Lyrik 170 DH coil
  6. #356
    2012 ElCiclon
    2012 17" ElCiclon
    " width="549">
    Weight: 29lbs 10oz
    Fork: 2012 Fox 32 Talas 150mm wiht 15mm thru axle
    Rear Shock: 2012 Fox RP23
    Wheels: Stans ZTR 355 laced to CK hubs front and rear
    Brakes: Shimano XTR trail
    Cranks: Shimano XTR tripple/9spd
    Rear Der: Sram XO, 9spd
    Shifters: Sram XO
    Seat: WTB Rocket V, Ti rails
    Seatpost: Thomoson Elite
    Stem: 100x10 Thomson Elite
    Bars: Envy carbon low rise
    Tires: Schwalbe Fat Ablert (tubeless) 2.35"
  7. #357
    Lightly salted
    Nice
  8. #358
    Jan 2011
    I may as well stop lurking and post mine. Made 6 weeks ago, got her last week.
    El Ciclon (19", Candy Red, RP23 shock)
    Fork: Fox 32 Talas 140 RLC
    Headset: Chris King
    Stem: Thomson Elite
    Bar: Easton EA70
    Grips: Lizardskinz Lock-On
    Seatpost: Thomson Elite
    Saddle: Fizik Aliante K:IUM
    Brakes: Avid Juicy 7
    Shifters: Sram X.7
    F. Derailleur: Shimano XTR M970
    R. Derailleur: Sram X.9
    Crankset: Shimano XTR M970
    Chain: Shimano XT
    Cassette: Shimano XT
    Wheelset: Mavic Crossmax ST
    Skewers: Salsa Flip-Offs
    Pedals: Crank Bros Candy SL
    Tires: Kenda Small Block 8 2.35 DTC
    Planned upgrades: Hope Tech M4 Evo brakes and floating rotors on the way. XTR 10spd drivetrain.
  9. #359
    Apology for the 650b forum re-run...
    El Bastardo – RP-23, semi-custom; 19" ST/22.5"TT, Grinch Green
    White Brothers Loop @ 150mm, 15mm TA
    Crane Creek 100 headset
    Truvative Stylo T30 stem
    Race Face SIXC carbon bar/Ergon GA1 grips
    Rase Black Mamba 9" dropper
    WTB Pure V ti
    Brakes: XTR Trail (new XTR Ice 185 rotors and XTR composite pads since photo)
    Shifters: SRAM X0
    Crank: XTR FC-M980
    F der: XTR
    R der: SRAM XX long cage
    Cassette: SRAM XG 1099 11-36
    Canfield Crampons
    ZTR Flow/DTS 240
    Pacenti NeoMoto set up tubeless
    I jumped through a couple hoops (fork, brakes) before arriving at this build, and I think it's a wrap. May dial back the fork to 140mm. Thought I'd ditch the big ring for a guard/guide, but liking it so far and little problem dropping chain.
    I can honestly say I've never had more fun going down a trail than on the GreenBeast. Thanks to ed.rides.bikes for the nice price on the used frame.
    Mike
  10. #360
    Sweet Terremoto!
    Nice build indeed - so how does the Monarch RT3 work on your Moto???
    I am not feeling ok withe the standard Fox RP 23...
    best
    Chris
    Quote Originally Posted by Lumagent Morple View Post
  11. #361
    Reputation: csoskin's Avatar
    Jan 2005
    Quote Originally Posted by She&I View Post
    WTB Pure V ti
    Shifters: SRAM X0
    Crank: XTR FC-M980
    F der: XTR
    Canfield Crampons
    ZTR Flow/DTS 240
    Mike
    Hey, love that bastard. What's the setback on that rase post and how do you like it?
  12. #362
    Quote Originally Posted by csoskin View Post
    I'm guessing the setback is 1–1.25 inches (bike's not where I am). I really like certain aspects of the post; all mechanical, stops every 1/2 inch through the range, huge range, can lift bike by seat, trigger takes little effort to activate. My beefs so far: Spring tension could be stronger. It's a little fussy with wanting to be clean and lubed, which the weak-ish spring exacerbates. The adhesive pad on one of the housing guides tore away from the plastic guide, need to fix or get replacement. With all said, the range alone makes it a great pick for trail/AM use, and of course 27.2 availability is a big factor. You do need lots of straight seat tube to run it. It ran neck-and-neck with my Spesh Blacklite (diff bike) until it started getting fussy. Now I'm hedging toward the Blacklite, which works super positively even with a large packed seat bag. The Rase makes me want more range in my BL, though. Guess the ultimate post (for me) still doesn't exist...
    Cheers,
    Mike
  13. #363
    El CicloPath!!!!!!!
    Nov 2012
    Frame: 2010 El Ciclon Path Edition W/ 5.5 Rockers
    Shock: Fox Van R
    Fork: Rockshox Sektor RL Dual Position Coil 150 w/ X-Firm Spring
    Brakes: Shimano XT with 160 SLX Front Sinitered/160 XTR Rear Resin
    Cranks: Shimano XT
    Drivetrain: SRAM front derailleur, XT rear derailleur, XT cassette (11/34) and shifters
    Headset: Cane Creek S3
    Bottom Bracket: Shimano XT
    Pedals: Shimano DX
    Stem: Easton Vice 100/6 degree
    Handlebar: Easton MOnkey Lite 2"
    Saddle: WTB
    Wheels: Shimano XT
    Tires: Kenda Nevegal 2.35 ft, 2.2 rr
    The Bike fits PERFECT!
  14. #364
    El CicloPath!!!!!!!
    Nov 2012
    A small update....rear rotor is now a 160mm Absoluteblack. Andf finally added a Hope seat QR!
    Quote Originally Posted by Fachiro1 View Post
    Shock: Fox Van R
    Cranks: Shimano XT
    Pedals: Shimano DX
    Saddle: WTB
    Wheels: Shimano XT
  15. #365
    Reputation: el saltamontes's Avatar
    New El REy
    My latest addition to my small, but nice collection of Ventanas
    Frame: ´13 El Rey, painted rear triangle
    Color: Mango Tango
    Options: none
    Shock: 2013 Fox Float CTD
    Fork: 2013 Fox 32 Talas 29 FIT CTD
    Wheelset: Hope Pro II
    Skewers: Fox 15mm, Fun Bolts
    Seatpost Clamp: Stock
    Front Der: XTR
    Rear Der: SRAM XO
    Shifters: SRAM XO
    Chain: Shimano XTR
    Cassette: Shimano XT 11-34
    Brakes: Shimano XTR
    Cranks/BB: Shimano XT 22/32
    Pedals: Crank Brothers Candy 2
    Headset: Chris King InSet
    Handlebar: Race Face Turbine
    Seat Post: FOX DOSS
    Stem: Race Face Turbine
    Saddle: Selle Italia SLR
    Grips: Ventana Logo Grips
    Front Tire: Schwalbe Hans Dampf 2.3
    Rear Tire: Schwalbe Hans Dampf 2.3
    Accessories: none
    XC legs,
    DH balls...
  16. #366
    May 2013
    Hybrid set-up Ventana marble peak fs
    Sherwood might scream....
    I love her too much to trash her at the trails. So a hybrid set-up for nice cruising at the beach.
    All the way in singapore. If im not wrong there is only 2 Marble Peak FS here.
    Frame: 1997 Marble peak FS
    Color:
    Options: none
    Shock: Fox ALPS 5R
    Fork: Rockshock Indy XC
    Wheelset:
    Skewers: Shimano
    Front Der: XTR
    Rear Der: XTR
    Shifters: XTR
    Chain: Shimano XTR
    Brakes: Shimano XT Vbrakes
    Pedals: Kore
    Headset: Race Face
    Handlebar: Da Bomb
    Seat Post: Uno Uno
    Saddle:GT - Awaiting Custom Leather saddle
    Grips:
    Front Tire:
    Rear Tire:
    Accessories: none
  17. #367
    El CicloPath!!!!!!!
    Nov 2012
    Quote Originally Posted by num3ga View Post
    sherwood might scream....
    All the way in singapore. If im not wrong there is only 2 marble peak fs here.
    Frame: 1997 marble peak fs
    color:
    Options: None
    shock: Fox alps 5r
    fork: Rockshock indy xc
    wheelset:
    Skewers: Shimano
    seatpost clamp: Stock
    front der: Xtr
    rear der: Xtr
    shifters: Xtr
    chain: Shimano xtr
    cassette: Shimano xt 11-34
    brakes: Shimano xt vbrakes
    cranks/bb: Shimano xt 22/32
    pedals: Kore
    headset: Race face
    handlebar: Da bomb
    seat post: Uno uno
    stem: Race face turbine
    saddle:gt - awaiting custom leather saddle
    grips:
    Front tire:
    Rear tire:
    accessories: None
    beautiful!!!!!
  18. #368
    My old ventana Pantera will die in a marvelous singletrack. If I could buy a Ventana with elevated chainstays, I'll put it at home like an sculpture. But I'll NEVER use it like a wallmart's bike
  19. #369
    El CicloPath!!!!!!!
    Nov 2012
    The Final Build!!!!!!!
    Shock: Fox Van R 650 spring
    Brakes: Shimano XT with 160 xtr Front Sinitered/160 slx Rear Resin
    Cranks: Shimano XT
    Pedals: Shimano DX
    Stem: Thomson X4 50mm
    Handlebar: Easton Havoc Alu 750mm 1.5 rise
    Saddle: SDG Aliso
    Wheels: Front SLX qr15/adaptor 9mm thru bolt, Rear ShimanoZee 135x10 thru bolt, Mavic EN521 rims, DT Swiss RWS
    Tires: Kenda Nevegal 2.35 ft, Telonix 2.2 rr
    I was running a 100mm stem, but after seeing what a lot of others have been saying about the merits of a short stem, I decided to try out the 50mm and I'm liking it a lot. I thought the cockpit would feel really cramped, but it actually feels better on the climbs. I ditched the XC wheels for the 521s. The bike feels much more confident now and downhills are much more fun. There is a weight penalty, but after switching to the shorter stem, it seems the new body position actually is enhanced and I'm still able to put down power to the pedals. Well, I think after 6 months of tinkering...it's fianlly complete. Now...................gotta ride more!
    Attached Thumbnails Attached Thumbnails The Set-Up Thread-img_4351_zps1014b774.jpg
  20. #370
    Unfit Norwegian
    Reputation: Dazed's Avatar
    Medium 2013 Ciclón w/ISCG tabs and 142x12 dropouts:
    Let's see...
    2014 150mm Pike Solo Air RCT3, Formula RO brakes w/203mm/185mm discs, Stan's Arch on Hope Pro 2 Evo (wheels will be swapped for Flow EX), Syntace Vector 780mm bars, Syntace Megaforce 2 stem, KS Lev seatpost, XT derailleur/shifter, King headset, etc, etc.
    29.3 pounds, or thereabout.
    Really stoked!
  21. #371
    Lightly salted
    Sweet looking build!
    Quote Originally Posted by Dazed View Post
    Let's see...
    2014 150mm Pike Solo Air RCT3, Stan's Arch on Hope Pro 2 Evo (wheels will be swapped for Flow EX), Syntace Vector 780mm bars, Syntace Megaforce 2 stem, KS Lev seatpost, XT derailleur/shifter, King headset, etc, etc.
    Really stoked!
  22. #372
    Reputation: mtnbkr4eva's Avatar
    El Ciclon in Hawaii
    Frame: 2013 El Ciclon
    Shock: FOX Float CTD Boost Valve 7.875 x 2.25 air shock
    Fork: 2013 Fox 32 Talas 26 150 CTD Fork w/Trail Adjust 1.5 tapered head tube Kashima 120- 150mm
    Brakes: Shimano XT M785 Ice Tech with 160 rear rotor and 180 Front
    Cranks: Shimano XT 2 x 10, 175 mm 24 x 36 w/ Race Face Bash Guard
    Drivetrain: Shimano Deore front derailleur, SLX Med Cage rear derailleur, XT cassette (11/36) XT shifters
    Headset: Chris King Inset (Mango in Color)
    Bottom Bracket: Chris King press fit PF30 (Mango in Color)
    Pedals: Kona platforms
    Stem: Control Tech FX 50mm
    Handlebar: KORE Torsion Alloy cut to 29” wide
    Saddle: WTB Pure V
    Seatpost: Gravity Dropper Classic
    Wheels: Industry Nine Hubs and spokes, Stans ARCH EX rims
    Tires: Schwalbe Racing Ralph EVO SnakeSkin PaceStar 26 x 2.2
    30 lbs
  23. #373
    Team Fearless Descender
    Reputation: El Salt's Avatar
    Quote Originally Posted by mtnbkr4eva View Post
    Fresh Build
    Beautiful bike, solid build, and in Hawaii!?!?! I guess I'd say Ole! Nani Loa.
    "...when your ride is nearly over, it seems to have lasted but an instant..."
    Stuff
  24. #374
    Still Stoked on My El Ciclon!
    Two months later, added the following:
    --Gravity Dropper (Turbo Model), dropped some grams, replaced the GD "Classic" model
    --Got the Fox 32 Talas CTD PUSHED (Factory rebuild, Big Hit re-valving, and TALAS to Float Conversion set at 150mm).
    --AEST Platform Pedals (280 grams)
    When I bought the used 2013 Fox 32 TALAS, it had zero movement in the initial stroke, no small bump compliance. After the PUSH re-build, HUGE difference, it was pricey, but worth it in my book.
    Totally stoked with this bike (now at 29 lbs), and with the dialed in suspension the bike just went to another level! Now if you all will excuse me, Im going riding!
  25. #375
    El Ciclon Upgraded
    --New bars
    --1 x 10 (11-42) with 32t RF NW chainring
  26. #376
    Cheesiest
    Reputation: intheways's Avatar
    Quote Originally Posted by el saltamontes View Post
    Color: Mango Tango
    Options: none
    Front Der: XTR
    Rear Der: SRAM XO
    Shifters: SRAM XO
    Chain: Shimano XTR
    Brakes: Shimano XTR
    Seat Post: FOX DOSS
    Accessories: none
    Do you have a weight on this bad boy?
  1. 2nd set of wheels for slicks or get a road bike?
    By Lost81 in forum General Discussion
    Last Post: 01-01-2005, 07:33 AM
  2. 5th Element set up problems with my Bullit
    By gregz12 in forum Santa Cruz
    Last Post: 12-12-2004, 12:54 AM
  3. Whats the best bike set up?
    By KevinVokeyJ24 in forum Shocks and Suspension
    Last Post: 04-22-2004, 04:12 AM
  4. What the best bike set up?
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 04-20-2004, 10:54 PM
  5. Read and Unread thread headings....
    By Monte in forum Site Feedback/Issues
    Last Post: 02-03-2004, 04:14 PM
