Page 16 of 16 FirstFirst ... 6 12 13 14 15 16
Results 376 to 383 of 383
  1. #376
    El CicloPath!!!!!!!
    Nov 2012
    The Final Build!!!!!!!
    Frame: 2010 El Ciclon Path Edition W/ 5.5 Rockers
    Shock: Fox Van R 650 spring
    Fork: Rockshox Sektor RL Dual Position Coil 150 w/ X-Firm Spring
    Brakes: Shimano XT with 160 xtr Front Sinitered/160 slx Rear Resin
    Cranks: Shimano XT
    Drivetrain: SRAM front derailleur, XT rear derailleur, XT cassette (11/34) and shifters
    Headset: Cane Creek S3
    Bottom Bracket: Shimano XT
    Pedals: Shimano DX
    Stem: Thomson X4 50mm
    Handlebar: Easton Havoc Alu 750mm 1.5 rise
    Saddle: SDG Aliso
    Seatpost: Thomson Elite
    Wheels: Front SLX qr15/adaptor 9mm thru bolt, Rear ShimanoZee 135x10 thru bolt, Mavic EN521 rims, DT Swiss RWS
    Tires: Kenda Nevegal 2.35 ft, Telonix 2.2 rr
    I was running a 100mm stem, but after seeing what a lot of others have been saying about the merits of a short stem, I decided to try out the 50mm and I'm liking it a lot. I thought the cockpit would feel really cramped, but it actually feels better on the climbs. I ditched the XC wheels for the 521s. The bike feels much more confident now and downhills are much more fun. There is a weight penalty, but after switching to the shorter stem, it seems the new body position actually is enhanced and I'm still able to put down power to the pedals. Well, I think after 6 months of tinkering...it's fianlly complete. Now...................gotta ride more!
    Attached Thumbnails Attached Thumbnails The Set-Up Thread-img_4351_zps1014b774.jpg
  2. #377
    Unfit Norwegian
    Reputation: Dazed's Avatar
    Medium 2013 Ciclón w/ISCG tabs and 142x12 dropouts:
    Let's see...
    2014 150mm Pike Solo Air RCT3, Formula RO brakes w/203mm/185mm discs, Stan's Arch on Hope Pro 2 Evo (wheels will be swapped for Flow EX), Syntace Vector 780mm bars, Syntace Megaforce 2 stem, KS Lev seatpost, XT derailleur/shifter, King headset, etc, etc.
    29.3 pounds, or thereabout.
    Really stoked!
  3. #378
    Lightly salted
    Reputation: fuenstock's Avatar
    Sweet looking build!
    Quote Originally Posted by Dazed View Post
    Let's see...
    2014 150mm Pike Solo Air RCT3, Stan's Arch on Hope Pro 2 Evo (wheels will be swapped for Flow EX), Syntace Vector 780mm bars, Syntace Megaforce 2 stem, KS Lev seatpost, XT derailleur/shifter, King headset, etc, etc.
    Really stoked!
  4. #379
    Reputation: mtnbkr4eva's Avatar
    El Ciclon in Hawaii
    Frame: 2013 El Ciclon
    Shock: FOX Float CTD Boost Valve 7.875 x 2.25 air shock
    Fork: 2013 Fox 32 Talas 26 150 CTD Fork w/Trail Adjust 1.5 tapered head tube Kashima 120- 150mm
    Brakes: Shimano XT M785 Ice Tech with 160 rear rotor and 180 Front
    Cranks: Shimano XT 2 x 10, 175 mm 24 x 36 w/ Race Face Bash Guard
    Drivetrain: Shimano Deore front derailleur, SLX Med Cage rear derailleur, XT cassette (11/36) XT shifters
    Headset: Chris King Inset (Mango in Color)
    Bottom Bracket: Chris King press fit PF30 (Mango in Color)
    Pedals: Kona platforms
    Stem: Control Tech FX 50mm
    Handlebar: KORE Torsion Alloy cut to 29” wide
    Saddle: WTB Pure V
    Seatpost: Gravity Dropper Classic
    Wheels: Industry Nine Hubs and spokes, Stans ARCH EX rims
    Tires: Schwalbe Racing Ralph EVO SnakeSkin PaceStar 26 x 2.2
    30 lbs
  5. #380
    Team Fearless Descender
    Reputation: El Salt's Avatar
    Quote Originally Posted by mtnbkr4eva View Post
    Fresh Build
    Beautiful bike, solid build, and in Hawaii!?!?! I guess I'd say Ole! Nani Loa.
    "...when your ride is nearly over, it seems to have lasted but an instant..."
    Stuff
  6. #381
    Still Stoked on My El Ciclon!
    Two months later, added the following:
    --Gravity Dropper (Turbo Model), dropped some grams, replaced the GD "Classic" model
    --Got the Fox 32 Talas CTD PUSHED (Factory rebuild, Big Hit re-valving, and TALAS to Float Conversion set at 150mm).
    --AEST Platform Pedals (280 grams)
    When I bought the used 2013 Fox 32 TALAS, it had zero movement in the initial stroke, no small bump compliance. After the PUSH re-build, HUGE difference, it was pricey, but worth it in my book.
    Totally stoked with this bike (now at 29 lbs), and with the dialed in suspension the bike just went to another level! Now if you all will excuse me, Im going riding!
  7. #382
    El Ciclon Upgraded
    --New bars
    --1 x 10 (11-42) with 32t RF NW chainring
  8. #383
    Cheesiest
    Reputation: intheways's Avatar
    Quote Originally Posted by el saltamontes View Post
    My latest addition to my small, but nice collection of Ventanas
    Frame: ´13 El Rey, painted rear triangle
    Color: Mango Tango
    Options: none
    Shock: 2013 Fox Float CTD
    Fork: 2013 Fox 32 Talas 29 FIT CTD
    Wheelset: Hope Pro II
    Skewers: Fox 15mm, Fun Bolts
    Seatpost Clamp: Stock
    Front Der: XTR
    Rear Der: SRAM XO
    Shifters: SRAM XO
    Chain: Shimano XTR
    Cassette: Shimano XT 11-34
    Brakes: Shimano XTR
    Cranks/BB: Shimano XT 22/32
    Pedals: Crank Brothers Candy 2
    Headset: Chris King InSet
    Handlebar: Race Face Turbine
    Seat Post: FOX DOSS
    Stem: Race Face Turbine
    Saddle: Selle Italia SLR
    Grips: Ventana Logo Grips
    Front Tire: Schwalbe Hans Dampf 2.3
    Rear Tire: Schwalbe Hans Dampf 2.3
    Accessories: none
    Attachment 793619
    Do you have a weight on this bad boy?
  1. 2nd set of wheels for slicks or get a road bike?
    By Lost81 in forum General Discussion
    Last Post: 01-01-2005, 06:33 AM
  2. 5th Element set up problems with my Bullit
    By gregz12 in forum Santa Cruz
    Last Post: 12-11-2004, 11:54 PM
  3. Whats the best bike set up?
    By KevinVokeyJ24 in forum Shocks and Suspension
    Last Post: 04-22-2004, 03:12 AM
  4. What the best bike set up?
    By KevinVokeyJ24 in forum General Discussion
    Last Post: 04-20-2004, 09:54 PM
  5. Read and Unread thread headings....
    By Monte in forum Site Feedback/Issues
    Last Post: 02-03-2004, 03:14 PM
