Results 1 to 5 of 5
    Reputation: Hobietom20's Avatar
    Salty swing arm on Fuego
    This was addressed in the old format but I can't figure out how to get there. Anyway, any tricks to putting a Salty swingarm on my wife's Fuego?
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    For an official answer I'd ask Larry or Sherwood..
    Quote Originally Posted by Hobietom20
    But I called Teresa about this a few months ago. If your wife's Fuego is a bearing model, then all you need to get 4" of rear travel is a set of Salty rockers, not a whole rear triangle. As far as I know, the bushing model rockers are not compatible.
    A set of rockers was ~$150 when I spoke to Teresa.
    op
    Feeding your addiction
    Reputation: Ventanarama's Avatar
    Dec 2001
    Yep, that's correct. Assuming it's a bearing-pivot model then the only difference is the rockers themselves.
    Larry Mettler
    http://www.mtnhighcyclery.com
    So bushings models are not compatible?
    Yuk. I already have the stock rocker arms from my Salty resting in my toolbox.
    Ventana Mountain Bikes
    If you have a bushing Fuego, we have adapters to adapt the new bearing rear end to it. It does require a trip through the factory for machining of some additional clearance at the lower pivot however. After that, the bearing swing arm will bolt right up.
    Call Teresa if you are interested 916 631 0544 x 203
    Sherwood
  1. Replies: 13
    Last Post: 01-30-2010, 11:53 PM
  2. If you could use either top or bottom swing F. der. which would you choose and why?
    By DCepp in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-13-2004, 06:46 AM
  3. Replies: 9
    Last Post: 02-04-2004, 02:50 PM
  4. Fuego meet Swinger..Swinger meet Fuego..
    By ohpossum in forum Shocks and Suspension
    Last Post: 01-30-2004, 08:16 AM
  5. Replies: 1
    Last Post: 01-12-2004, 07:32 AM
