Results 1 to 6 of 6
    Reputation: CarlosPR's Avatar
    S.O.S. loose pivot
    I need help trying to find the pivot that have a lite play. I checked all the pivots and they look ok. The only one that I'm not sure if is tight is the main pivot, because if i use the 10mm hex the other side bearing move and when I use the 5mm hex the other side bearing move too. I think that they are ok too. I think that the problem is in the upper mount shock spacer. The inner sleeve look ok, but the spacer has a little play when is install. The play is a up/down movement not a side by side movement it. That is why I think the problem is the shock spacer. The movement remember the same problem that I had a few years with another full suspension frame from another maker... Any suggestion?
    Mas vale ser punky que maricon de playa
    Quote Originally Posted by CarlosPR
    If I understand you correctly, the DU bushings / reducers have play. This is completely normal. Go to your LBS and have them put new bushings and reducers on the shock. You'll be good to go.
    normal?!
    Quote Originally Posted by Blue Shorts
    But it is normal after 5 months of use? The frame is practically new....
    Unfortunately, yes. It depends on the suspension design and the quality of the bushings. I had to replace mine after about 6 months on my 5 spot. The bushings on my other bike lasted almost 2 years, but it is a short travel bike.
    Ultra Ventanaphile
    Dec 2001
    Blue Shorts or Warrgurru, is right...
    It's the DU bushing in the SHOCK that wears out quickly, has nothing to do with the actual frame. Cheap and easy to fix though.
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    Ventana Mountain Bikes
    You are correct in that the du bushing should last longer than a few months. I believe Fox will warranty their shock bushings for up to a year so call them and get a new one. Our upper shock spacers are hard anodized and rarely need replacing as their bushing (which costs $2 instead of $25 for shock spacers) wears out long before our spacers do.
    -Sherwood
  1. Replies: 12
    Last Post: 06-25-2004, 01:51 PM
  2. Sugar 2+ loose pivot bolts.
    By Nim in forum Trek
    Last Post: 04-23-2004, 10:04 AM
  3. 4 month and 18 month Turner pivot updates.
    By tscheezy in forum Turner
    Last Post: 04-15-2004, 10:39 AM
  4. 5.5 loose pivot syndrome
    By izak in forum Intense
    Last Post: 04-05-2004, 06:50 AM
  5. Help! Loose main pivot on Heckler
    By Stinky Wiz in forum Santa Cruz
    Last Post: 03-05-2004, 06:03 PM
