Results 1 to 12 of 12
    Sep 2004
    RP23 on El Rey setup
    Sorry, the search function isn't working for me. Any idea of a good starting air pressure for an El Rey with a rp23, 4" rockers and 190lb. rider?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    go by sag around 20-25%?
    Sep 2004
    Quote Originally Posted by crisillo
    Yea, I know that. I am trying to set this up for someone else. I don't weigh that much. I was just trying to get an idea of around how many psi.
    Powered by ice cream.
    Reputation: Enel's Avatar
    Try 155 psi I run 150 and weigh 180
    T , V , & K Rider
    About 80 % my geared up weight converted to PSI seems to give me the right sag on my Capitan ! 190 lbs geared up x .8 = 152 PSI . TIG.
    Happy trails
    Reputation: FATTRAXX's Avatar
    215lbs using 152psi
    Aaron
    Shovel Ready
    Reputation: Cycle64's Avatar
    Besides a percentage. Would not the PSI be different if you were using a HV canister compared to the standard?
    Currently at Mayo Clinic being tested for a kidney transplant. Donors welcome.
    Quote Originally Posted by trb2929
    yes.... the psi for a given sag point is different depending on the sleeve size...
    Shovel Ready
    That is what I thought. So unless we know which canister the individual has or what canister a suggested PSI is for! It is still a shot in the dark suggesting a certain PSI versa a sag percentage.
    exactly..that's why sag is usually a better way to go...or at least an easier starting point...
    MTB B'dos
    Reputation: LyNx's Avatar
    Might sound a bit silly but......get a backpack or camelback etc, load it up with weights/rocks etc until you're close to that weight and then sit on the bike and adjust the PSI until you have the right SAG.
    Quote Originally Posted by BIke N Gear
    jrm
    jrm is offline
    Reputation: jrm's Avatar
    Im using..
    110 psi with the rebound 1/2 way and the lowest PP setting. i weigh 195 and this is with the large canister though..
