Results 1 to 30 of 30
    Jan 2009
    Rear wheel - 135 mm vs 142 mm
    I just ordered a new El Rey and have a question. Do I go with a 135 mm rear wheel or upgrade to 142 mm? I am 6'6" and about 225 lbs. Would the bigger size be noticable? I have only ridden 135 mm....
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    It should be stiffer at the axle interface, but it does not build a stronger wheel since the hub shells are usually the same.
    10mm/135mm bolt on options also so provide a fairly stiff interface
    Some hubs like Hope Pro 2 can be converted to 142mm
    Jan 2009
    I'm using Hope hubs with Flow rims. I saw that Hopes can be converted to a 12x142 axle and was wondering if this was a useful modification....kinda similar to the upgrade on going from a 9 mm QR to a 15 mm thru axle on the front?
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by sbk99 View Post
    You have the correct thought.
    As Cris pointed out the hub shells are the same, so the wheel itself is not stronger. But the interface between the hub and the rear triangle is, for multiple reasons. First, the "thru axle" part, the axle connects into the dropouts with a 12mm interface, a full 17% larger diameter than the 10mm. Second the mechanical connection is 360 degree's arround the axle, not just the QR faceplate squeezing the hub face against the dropout.
    So that's the long winded version of yes it's a useful modificaton just like 9 to 15mm, although I prefer the 20mm TA.
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    Proud lame eBiker
    Reputation: Internal14's Avatar
    At 6'6" and 225lbs I'd say for sure to the conversion. There's no drawback to having an even laterally stiffer rear triangle, right? So why not? Yer a tall guy and tall guys put a ton of torque in funny ways into bikes. I just did the Hope Conversion, it was easy to do. (Although, as it stands there's a bit of an issue with the Maxle used in the back on the 142mm, but nothing a little grinder work to the Maxle compression ring won't solve).
    www.velocitybicycles.comWhere customers become friends, not simply a dollar sign.
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by Internal14 View Post
    Semi-hijack...
    Can a Pro II rear be converted to 10mm Thru? What about a Hope XC? Thanks.
    -Aaron G.
    Proud lame eBiker
    Quote Originally Posted by Ciclistagonzo View Post
    Semi-hijack...
    The Pro II to 10mm sure. That XC, not so much as I believe they use a smaller diameter bearing. But I'd have to check to make 100% sure....
    Ultra Ventanaphile
    Dec 2001
    Cool, if I only had $$$ , or I should say, if my $$ wasn't already pre-spent!
    -Aaron G.
    Jan 2009
    Thanks...Other than the nomical cost for the droupouts and axle conversion, I don't see a downside, either. I'm sold.
    Proud lame eBiker
    Happy extra stiff riding to you, TallMan.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Buy your bike parts and the government will take care of your children. Yes We Can
    I guess some people are a little sensitive to my political references......it's my opinion or joke and unless I violate mtbr rules then you can eat it sucker. One more thing do you think mtn biking is void of politics? What rock have you been hidding under.
    Reputation: rearviewmirror's Avatar
    135mm w/ 10mm TA is plenty stiff, I wouldn't change a thing if I was after a new wheelset.
    Draft College Republicans
    MEDBLKANOSCBLT2RP23
    Reputation: pakdoc's Avatar
    Dec 2005
    So, If I have a Chris King hub on the rear running a normal qr 9mm skewer, what are the simple options?
    What are FUN bolts?
    What do you need to do to convert to 10mm or Fun bolts etc?
    RTR
    Quote Originally Posted by pakdoc View Post
    What are FUN bolts?
    Chris King offers a 142 x 12mm Axle conversion if you decided to go that route. The Fun Bolts do provide a better interface then just using a quick release.
    Proud lame eBiker
    Quote Originally Posted by Stripes View Post
    You don't need anything other than an allen wrench (or a couple) to run fun bolts. They retail for something like $40 and you replace the sleeve in the hub used for the QR skewer. Once you take that out, screw in the fun bolts and use an 8mm allen to tighten them.
    The 12mm TA and the conversion kit are more expensive, and truthfully, the fun bolts should give you enough stiffness.
    Thru axle can be installed, at least in theory, without any tools. And th least thing I want to do if have to pull out tools to take the back wheel off and on when you throw it in the back of a car.
    Fun Bolts never seemed that 'fun' to me anyway. Silly name.
    Ultra Ventanaphile
    Dec 2001
    Ok, good point. Not that an 8mm allen wrench is hard to deal with
    It's more I don't think you get that much more stiffness since the body is still a 135mm shell, right? Let me know if I'm wrong, because I'm not an engineer.
    See my first post, already answered that. No the Wheel is not stiffer but the interface betwix the axle and the rear tri is stronger with the TA. The fun bolts don't add anything to the equation except mechanically squeezing the dropout harder than you can with a QR. And I agree with Myke, I prefer toolless 10mm TA. (reminds me I need to call Myke...)
    -Aaron G.
    Reputation: OldHouseMan's Avatar
    I haven't found the Chris King hub with Funn Bolts to be all that difficult. Other than digging around for the allen wrench, it's not that much slower than a quick release. As for the claimed additional stiffness the Funn Bolts add, I'm not sure. I went from a Santa Cruz Superlight to an X-5 with the heavy duty rear, so there's not really much comparison.
    If I had a choice now, I'd probably go with the 142 rear. Everything I've read makes sense to me and it's kind of cool that the 142 axle was designed to use the 135 hub body and keep all of our wheelsets from going obsolete.
    I only ride bikes to fill the time when I'm not skiing.
    ventanakaz
    Reputation: 1962's Avatar
    ...i'm not up to par on the rear axle thing and just got back on my la bruja after not riding for over three months. i have a CK rear hub on it with QR and road north*, downieV and also jumps. what should i do to the hub to make it clamp better or stronger at the rear drop out. fun bolts or what ? ...ralph
    i need to ride more. building jumps takes to much time...my other hobby is kicking the crap outta my home built mook jong.
    ventanakaz
    ...i was just thinking since you have to change the sleeve (axle) and the fun bolts cost $40 then you also have to buy the axle for the fun bolts. whats that cost ?...ralph
    So out of the box the 12mm Maxle will not work with the new Ventana 142 x 12mm rear swingarm configuration. Then why do a 142mm rear end if the Maxle will not work? Would you mind illustrating how much grinding is needed to get the Maxle to work. cheers, ole'
    With the seatstay/rear dropout configuration, there's not enough room to tighten down the QR lever. Apparently, it's doable by just using an allen key in the Maxle, but that's a pretty inelegant solution.
    There also seems to be a clearance issue with the large "nut" on the QR end of the maxle. Ventana was talking about just machining it down, but of course that doesn't solve the other clearance problem I described above.
    The Shimano axle works perfectly, however. The only advantage I can see with the maxle is that it expands into one dropout, mimicking the traditional pinch-bolt setup with thru-axles. I have no idea how much that radial clamping would add to stiffness, but I can tell you the frame is gruesomely stiff with the Shimano axle.
    ventanakaz
    If you have relatively new enough King hubs, you don't have to change the axle--you just remove the 9mm QR sleeves. The fun bolts and QR 9mm axles are the same in the rear hubs, and have been for a few years.
    If they're older, I don't remember how much the rear axle was.. something like $60.. I think, check with an LBS or whoever you buy your parts from.
    ...i have the older 5mm adjustment so i would have to buy the axle & fun bolts, I don't think it would be worth getting it and i might not notice the differance between the two, Anyway thanks for the help...ralph
    I have to say I don't understand the love for Hope hubs. I cracked my rear Pro II three times before switching to CK . . . No problems so far. 225lbs at 6'6". maybe I just had bad luck? Well my front hub has been running smooth I guess
  1. Replies: 13
    Last Post: 08-04-2009, 02:54 PM
  2. Lacing front wheel different that rear wheel?
    By JB. in forum Wheels and Tires
    Last Post: 03-31-2009, 09:34 AM
  3. Replies: 10
    Last Post: 01-27-2009, 02:31 AM
  4. Replies: 3
    Last Post: 07-29-2008, 03:59 PM
  5. Any way to modify a rear disk wheel to fit as a front wheel ?
    By th3crack3r in forum General Discussion
    Last Post: 04-05-2007, 05:43 PM
