Results 1 to 3 of 3
    El CicloPath!!!!!!!
    Nov 2012
    Qestion about rear axel spacing...
    I think I know the answer to this but just want to be 100% sure. Is the standard read axle spacing 135 x 10mm? Does that mean the drop out diameter is 10mm and the total axle spacing, not counting the part that is actually in the drop out , is 135mm?
    Proud lame eBiker
    Reputation: Internal14's Avatar
    Yes the 10x135 means a 10mm axle slot in frame whether it be a 10mm axle sticking part way through the dropout, or 10mm bolts running in to the axle from the outside in a bolt-on rear hub.
    The 135mm is the face to face inside dimension of the dropouts on the frame. The nut to nut dimension of the hub must be that as well. No pulling the rear end apart to punch in a 142mm hub or something goofier.
    www.velocitybicycles.comWhere customers become friends, not simply a dollar sign.
    El CicloPath!!!!!!!
    Nov 2012
    Thank you!
  1. Convert Hope Pro 2 Rear Hub axel spacing, 135mm to 145mm QR?
    By ebnelson in forum Tandem Mountain Bikes
    Last Post: 10-15-2014, 02:10 PM
  2. Shimano XT rear Hub/Axel play
    By Fachiro1 in forum Wheels and Tires
    Last Post: 04-04-2013, 10:38 AM
  3. RS Psylo 20mm Thru axel and Sram 15mm thru axel
    By Haystack Calhoun in forum Shocks and Suspension
    Last Post: 02-16-2012, 09:10 PM
  4. Rear dropout QR 135 or through axel 142?
    By jonny boy in forum Specialized
    Last Post: 01-13-2012, 04:06 PM
  5. 10 mm vs 12 mm rear axel -- who wins?
    By Leprechaun in forum Turner
    Last Post: 10-02-2011, 08:07 PM
