• 01-02-2013
    Fachiro1
    Path Edition El Ciclon and fork Choice
    Happy New Year All!!
    Had a question regarding the Path Edition and Fork choice.
    Will using a 150 fork on the front end change the HA and SA from the 66 and 74?
    I think I read somewhere that the frame was designed around a 140 fork.
    THANKS for any info!!!
    Regards,
    Rog
  • 01-03-2013
    iconic83
    I'm running a pike coil u-turn at 140mm. i emailed the guys at the path shop and they said the bike works best with 140 to 150 mm
    I personally haven't tried with 150 mm
  • 01-03-2013
    Fachiro1
    Thanks for the info people!!!!
  • 01-06-2013
    Fachiro1
    I finally got the bike built up.....the brakes still need some adjustment and i do need to get a stiffer spring. Thanks to all for the advice.....its been fantastic.
    Ok........I have to say........
    The bike is frggin awesome!!!!!!! I love it!
    The geometry just kicks ass. I bombed down a local DH run this afternoon, of which I previouslyalways felt a bit apprensive riding the Turner Flux........but on the El Ciclon...........
    Woah!!!!!!! What fun! Havent had that much fun in years!!!
  • 01-06-2013
    iconic83
    need pictures!!! where did you get the frame from? i got mine (2010 model) second hand
  • 01-06-2013
    Fachiro1
    Fantastic! I got ut from The Path. I think its a 2010 as well....do you know what rockers/travel your bike us? Do you know the shock stroke?
  • 01-07-2013
    Vader
    I have a custom EC that's the same as The Path's, but in an 18" and 1* steeper head angle. The first fork I ran was a Marzocchi RC3 44 in 140mm. I was using all the travel so I went with a RC3 44 in 150mm. The bike is perfect now with a 67* HA.
    Shock stroke is 2.25" with 5.5" of travel
  • 01-07-2013
    Fachiro1
    Fantastic!
  • 01-07-2013
    iconic83
    My one is 5.5" rockers with a 2.25" stroke shock - check my other post on how to find out what rockers you have:
    http://forums.mtbr.com/10038656-post2.html
  • 01-07-2013
    Fachiro1
    They are marked 551-09....does that mean i have 5.5" of travel?
  • 01-08-2013
    iconic83
    that's correct! you should then have a 2.25" stroke shock
  • 01-08-2013
    Fachiro1
    Thanks for all the help and info!
  • 01-08-2013
    Fachiro1
    Until I get a longer fork..Im running the Fox FIT RLC 120 from my Turner Flux....110mm Sten..yeah I know...............not the right stuff, but the bike really feels great!!!!!!!! I still need to switch out the spring with a heavier one.
    But the geometry os confidence inspiring!!!!!
  • 01-09-2013
    Fachiro1
    I'm having a terrible time with the rear FormulabRX brake...............it's been squeeling like a banshee the whole time!!!!
    should i try sanding the disc? replace the pads? i've spend about 10 hours trying realign it..........to no avail....
  • 01-14-2013
    Fachiro1
    Got the shorter stem and the handling really improved!
    I also got the RS Sektor 150, Gotta get it installed now!!!!!!
  • 01-15-2013
    Fachiro1
    The Sektor arrived . I think the Medium spring is a bit plush, but the fork action is awesome! With the front end sitting higher now, I think the bike is now balanced and feels the way it was intended!
    The Sektor feel significantly stiffer than the Fox, at least to me. The dual position coil actually works!
  • 01-15-2013
    Fachiro1
    Originally Posted by Stripes View Post
    Can't wait for the ride report with the new fork :)
    Thank you for all the help!
    I'm going to take her up in a few days....Glendora Mountain Road most likely.....I know the stock spring is soft, but I think I used to run DH dual crown forks just as soft back in the day.
    Definitely feels more stiff!!!!!!!!!!!!!!!!!!!!!!!!
  • 01-17-2013
    Jeff in Bend
    I had the same brakes on my elchucho. I tried everything and could never get the rear brakes to be quiet. Switched to xt's and not a peep.
  • 01-17-2013
    Fachiro1
    I cant wait to get the xts......these are driving me nuts!
  • 01-18-2013
    Fachiro1
    Turns out the rear brake seals are shot... I think brake fluid was getting on the pads and disc, ths causing the squeeling............
  • 01-18-2013
    Jeff in Bend
    I doubt that is the cause of the squealing, fluid on the pads would probably help with the noise albeit with total brake failure.
  • 01-18-2013
    Fachiro1
    Youre probably right!
    There is so little space between the disc and the pads. Just by sitting on the bike makes the pads touch the disc. It squeels only when coasting.
  • 01-21-2013
    Fachiro1
    I took her up Glendora Mountain Road! I climbed the road up to the the gate at the top and took the fireroad/single track offroad down.
    Wow!!!!!
    First off, the suspension is AWESOME.
    I have a 650 lb. spring and three clicks from open on the Fox Van R and it just soak up everything. In the first 5 minutes of the downhill, something was going on with the fork. My first thought was.....this fork is terrible! Its notnabsorbing anything! But I look down at the right crown and I realized I had forgotten to unlock the lock out......duh! I had locked out the fork and lowered the travel for the long climb. The lock out and dual travel worked flawlessly.
    The fork soaked up everything! Its stiff for a 9mmQR. I initially thought the stock medium spring would be too soft, but it was good. I was getting about 15% sag, and it took all the bumps this trail dished out no problem!
    Almost died on this ride..!! No kidding. About 1/3 of the way down, the single track "broke." There was a section that was completely gone and all you had was the side of the mountain dropping down about 200 feet. Lucky I saw it in time and braked.....skidded......stopped.......I'm a 43 year old man and I yelled out..."SHHHHHIIIIIIITTTTTTTTT!!!!!!" lol!!!
    For those of you that ride this trail, you know about the whole bottom of the trail being a horrendous rock garden. It really tested out the suspension. There were a few toxic water crossings as well. I decided to walk/carry the bike through these.....the water looked..............sinister!
    The only problem on the ride........the rear brake, a brand new XT.........was howling like a banshee by the time I hit mid ride down. It was terrible!
    I got some resin pads today and switched out the metal ones......... and the noises seem to be gone......hope it fixed the noise issue!
    Dear Sherwood, Teresa, and the whole Ventana coompany, and the Path.....thanks for making such an awesome frame!
  • 01-22-2013
    Fachiro1
    So...............the bike is COMPLETE!!!!!
    I switched out my Formula RX's for new XT's The rear howling seems to be cured by the resin pads.
    I thought I nearly had a minor disaster with the front brake today. I installed it and the line was just too long. Actually it still seems a bit too long, but I'm okay with it right now.
    I must have read those instructions on how to trim the hoses a million times and read all the posts on the subject.
    I uncrewed the hose, pulled out the line......tried to cut with an exacto, but couldnt, so I used some wire cutters, which actually made a good cut. But getting the new nipple on the hose was damn difficult! I dont have a vise so I thought I could just hold it with some wrapped pliers. I tried using a rubber mallet, but it just would go in. There was a little bit of oil spillage, but I couldn't tell if it was from the cut hose or the one in my hand. I finally just pushed the nipple in against my desk.
    I put the olive on (not really understanding what that part was for) and screwed the newly cut hose into the lever....screw things down....
    When I went to push the pistons in to semi bleed.....oil starts pumping out of the connection.....I pull the lever, and more oils starts coming out...DAMN!!!!! Oil seemed like it was everywhere!!!! got on my shirt, my pants......I felt like Robin Williams in RV!
    So I pull the hose out....inspect the end...and the olive is un-uniformilly deformed. I guess I inserted the hose in the wrong way and had the olive positioned incorrectly....
    So in goes a new olive......carefully screw things down......wipe everything with OH......install caliper.............align pads.......pump the brakes........
    It was still working fine. No mushiness....went for a ride to bed in the pads.....so far so good!!!!!!
  • 01-22-2013
    fuenstock
    Nice bike, enjoy it! Those xt brakes are a good choice, super strong brakes:thumbsup:
