Results 1 to 13 of 13
Thread: Old El Ciclon
    jbf
    jbf is offline
    Reputation: jbf's Avatar
    Old El Ciclon
    I came across a 2008 17" El Ciclon frame and was hoping you guys could help me out with how these older models size out. The top tubes of the older frames seem a bit short compared to the new version. I am 5'9-1/4" barefoot and as near as I can tell I would need a 90mm stem to match the position I ride on my current hardtail.
    Can anyone chime in with their experience riding the old El Ciclon? Your size and frame fit specs would be appreciated ...
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Here is the geo chart for a 2009 El Ciclon. I believe the 2008 thru 2010 are the same geometry numbers. I think the medium frame will fit but I would compare it against what you're currently riding. At most you may have to change out the stem, Ole'
    Attached Files Attached Files
    jbf
    jbf is offline
    Quote Originally Posted by mtnbiker4life View Post
    Thanks for the chart. Since the website was updated, all the info on the "old" Ciclon seems to be gone. I had only been able to locate a 2008 data sheet online and it appears the standard geometry was slightly tweaked in 2009. I assume it remained constant thereafter. I am going back and forth on whether the 17" or the 19" would best suit me.
    Team Hardcore Cornbread
    Reputation: Phishin Paul's Avatar
    Dec 2004
    I am 99.9% sure the geo on the 2008 EC is different from the 09-10. The 2008 had 5 inches or rear travel and in 2009 it was changed to 5.5 (140mm). I purchased an 08 and considered upgrading the rockers. I am going only on memory here so don't hold me to it.
    I searched and could not find the geo. I am 5-9.5 but with a 30 inch inseam. I still ride the 08 17inch EC with a 90mm stem and 140mm TALAS and it is a great fit. I started searching for the old geo so I could compare to the Zeus. It looks like if I go the Zeus route I will have to custom. Even the small has a 30 inch top tube.
    Let me know if you have any specific questions.
    "Set the gearshift for the high gear of your soul".
    Quote Originally Posted by Phishin Paul View Post
    30" top tube!?!?! not a chance
    breezy shade
    I pretty sure the 2008 was the first year they bumped the rear travel to 140mm.
    Dec 2004
    Quote Originally Posted by nhodge View Post
    Stand over, my bad. Still, the Zeus is one tall mother.
    I had a 2008 and it was 5"/127mm travel. I'm 5' 10.5" and rode a large. At 5' 9" I'd for sure lean medium on the old models.
    jbf
    jbf is offline
    Quote Originally Posted by LncNuvue View Post
    Thanks for your thoughts. As an east coast rider I'll probably lean toward the medium as the agilty of the smaller frame would probably work better on the trails I ride regularly.
    No known cure
    Reputation: Vader's Avatar
    Quote Originally Posted by jbf View Post
    There are 5/6 inch combo rockers for the '06-'10 frames. I feel that the 5.5 rockers are perfect(for me). Size wise, I'm 5' 11" and had a 18" front triangle made if that helps
    Ripping trails and tipping ales
    zod
    zod is offline
    Southern Fried mUni
    Reputation: zod's Avatar
    Jul 2003
    Anyone have the geometry on older Ciclon's by chance? I have a 2007.
    jbf
    jbf is offline
    Quote Originally Posted by zod View Post
    <a href="http://s1172.photobucket.com/albums/r574/jbf99/?action=view&amp;current=elciclon2007datasheet.jpg " target="_blank"><img src="http://i1172.photobucket.com/albums/r574/jbf99/elciclon2007datasheet.jpg" border="0" alt="Photobucket"></a>
    zod
    zod is offline
    Southern Fried mUni
    Jul 2003
    excellent....was wondering about head angle. thanks
