Results 1 to 11 of 11
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    New pivot placement....
    I'd love to get a good demo on a Ventana but can't anytime soon - so I'm left only to pester others in espace.
    Looking at the pivot placement on the new Ventanas has me concerned that it is nearing the realm of a high single pivot, albeit, "not so high" single pivot. Anyone out there who can comment? I like the feel of a super plush low single pivot and have no desire in giving that up for "pedaling efficiency".
    Anyone notice a loss of suspension compliance under hard pedaling with the new design, compared to the prior design?
    Thanks.
    fai
    fai is offline
    Sep 2004
    I have come straight off an 09 El Ciclon onto a 2012 frame. I also was riding an El Terremoto. I swopped the forks,wheels, bar and stem from the Terremoto onto the new frame. This of course is only my opinion. I am using the frame in the 150mm travel setting. It is a totally different ride to the earlier frames, it rolls faster, is plush and climbs over techy stuff really well. I have used it on certain rides that I find very hard that contain a couple of climbs I have never been able to get up without stopping at sketchy bits on the steep rooty rocky bits. I have been able to clear them on this bike, admittedly I am now using a 10 speed cassette with a 36 but you still need a frame that keeps rolling easily while pedeling over that stuff. I like a frame with a smooth comfortable ride as I am not a racer so comfort is an important part of my set up. I think the ride will not disappoint you. I ride with the shock set on 0 only using the propedal on road climbs. I hope you can get a test ride soon.
    Sunny Chicksands by Alanatriversidecyclecentre, on Flickr
    AJR
    Proud lame eBiker
    Reputation: Internal14's Avatar
    I will say that the 'feel' of the bike is a bit different. One thing I notice is in this scenario: You're going up a climb. There's rocks and roots to get up and over. On the older frames you could feel the suspension compress when you rolled onto the ledge you're trying to get up and over. Then as you came over the top of the ledge the suspension would come up in travel, then settle back into the travel a bit.
    The newer bike stays higher in it's travel. It seems as though it gives slightly less on the ledge overall, still smooth enough initially to get up and over, then once you're on top of it it stays higher in the travel. Making it really easy to get on the gas and build a pedal stroke or two of momentum before hitting the next ledge. The old bike had a hard time with that initial pedal stroke being a bit mushy.
    So the new bike is not as outright plush feeling climbing, it is very much punchier getting up an dover the techy parts.
    If that makes any sense at all....
    www.velocitybicycles.comWhere customers become friends, not simply a dollar sign.
    Keep on Rockin...
    Nov 2003
    Thanks....
    Quote Originally Posted by Internal14 View Post
    Yep.... more like a high, forward single pivot Clearly though the pivot is still quite low so I'm pretty sure it would pedal more like my Lenz than my old SC Bullit.
    If I recall correctly you had the Chucho? That's the Ventana I'd like to get (but am trying to get a test first). How's the bike working out since your last post?
    Quote Originally Posted by Miker J View Post
    If it is more like a high, forward pivot, the high-pivot characteristics are incredibly subtle--I can guarantee you it won't pedal at all like your bullit. I spent 9 years on the Ventana Chamuco, another high-pivot bike, and the new Ciclon doesn't display any of the bad climbing-over-rough-terrain characteristics that I'd gotten used to on the Chamook. (I appreciate lots of things about the high single pivot, but climbing in rocky terrain isn't its strong suit.)
    The new design stays supple when climbing hard on rocky steeps or lunging up ledges, and I don't feel any suspension/chain tension interference. It just doesn't wallow as much as the other low-pivot Ventanas I've owned (Bruja gen 1, Bruja gen 2, El Salt), so it climbs better. Not sure why, but it does seem to pedal and roll faster over choppy terrain.
    No known cure
    Reputation: Vader's Avatar
    All the negative suspension traits of the past generation that have been mentioned here, can easily be erased with a properly set up CCDB. I'm not in denial either as I've already picked my new frame's color.
    Ripping trails and tipping ales
    post-ride specialist
    Reputation: icegeek's Avatar
    this talk of wallowing sounds like more to do with rate curve and shock characteristics than it does about pivot location
    Since when did Need have anything to do with this?
    Quote Originally Posted by icegeek View Post
    You can run a bed spring on _dw link bikes and they still ride great - has to be the bike's fault.
    No known cure
    Quote Originally Posted by Stripes View Post
    Is it the yellow you had? I like the yellow.
    Speaking of which, you should have it spec'd with the DBair. I'm really looking forward to that shock coming out.
    Air suspension is not my thing. Besides, I'm more than manly enough to carry around a coil shock and fork, dropper post...and that boat anchor of a stem I got from you.
    Attached Thumbnails Attached Thumbnails New pivot placement....-sedona046.jpg
  1. Rear Pivot Placement
    By Poolstick in forum Shocks and Suspension
    Last Post: 02-22-2010, 07:13 PM
  2. dmr sts placement
    By juiced79 in forum Singlespeed
    Last Post: 11-17-2008, 06:24 AM
  3. Highline main pivot placement
    By AW_ in forum Turner
    Last Post: 08-02-2008, 10:58 AM
  4. ire placement
    By DuskDenizen in forum Wheels and Tires
    Last Post: 07-24-2006, 08:20 PM
  5. Chainstay Vs. Seatstay Pivot Placement On Fs Designs
    By mtnbkrdr98 in forum Bike and Frame discussion
    Last Post: 06-03-2004, 06:08 PM
