Results 1 to 6 of 6
    Team Hardcore Cornbread
    Reputation: Phishin Paul's Avatar
    Dec 2004
    Help with zerk injection
    So the zerk grease injection port is new to me. I have the needle injector to apply but can anyone provide a quick step by step instruction. I must have done something incorrect because ever since I injected the grease I have a horrible squeak that I cannot locate. I pulled everything so I am back the problem being the pivot area.
    I went through the list as far as normal squeak spots; pedals, BB, cranks, seat post, saddle, loose bolts, and nothing. The squeak can be heard while either in saddle or off, off pedals or on. It is really bad while under load. I can make the squeak by rocking the bike side to side while rolling. Thanks
    "Set the gearshift for the high gear of your soul".
    El CicloPath!!!!!!!
    Nov 2012
    Ventanas have grease injector ports? on the new models?
    Feb 2006
    Yes - lower drive-side needle bearing
    change is good
    Sep 2004
    M s
    Dec 2004
    Just pulled the rocker arms off and shock again. Cleaned all bolts and used some Super Coat grease on all areas. Creaking is gone.
    Mmmm Rocks Good
    Feb 2005
    I used to get a mystery creak out of my El Capitan that drove me crazy. I looked, cleaned and lubed EVERYTHING (I thought)! Turned out it was the replaceable derailleur hanger. It gets a bit dusty between the chainstay interface and would creak. Cleaned it lubed it and never had a mystery creak again!
    Big, strong, rock crushing, IPA drinking, big hit bike rider!
  1. Zerk question
    By mikkosan in forum Turner
    Last Post: 02-12-2013, 07:30 PM
  2. Chris King BB and Grease Injection Tool
    By MarkMass in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-15-2012, 10:11 PM
  3. Zerk fittings
    By taffturner21 in forum Turner
    Last Post: 01-07-2012, 03:12 AM
  4. Zerk Loob
    By papabear050 in forum Turner
    Last Post: 04-21-2011, 12:01 PM
  5. Missing zerk
    By Caramba81 in forum Turner
    Last Post: 04-10-2011, 06:18 PM
