Results 1 to 9 of 9
    New question here. Help with angles please - especially HA
    I've got a X5 2004 and i am currently running pikes and fox float on 6" rockers. The bike has quite a high BB (around 14"+). I know the angles changed from 70 deg in 2004 to 68.6deg from 2005 onward so i have not got a clue what my HA is.
    I have also read a couple of notes that say that each 20mm in fork (axle to crown length) is about 1 deg but elswhere i have seen 25mm = 1 deg.
    Does anybody have the definitive rule for each mm change in AC length vs HA change?
    I can have a gues at my HA but i am unsure what the change in rockers ie from 5" to 6" has done to the BB height and if this has affected the HA of the bike.
    just as a starter the 2004 angles are based on a AC of 478mm
    the 2005 onward 505mm and the pike is a 518mm (at 140mm)
    cheers for any help in advance
    Dave
    The rule that I've always gone by is 10mm in A-C is equivalent to approximately .5 deg in HA. Now I could be wrong on this, so maybe someone else more knowledgeable will chime in here too. As far as what the 6" rockers do to the geometry of your X5, I have no idea. I've never seen or read anything about it.
    Shot Down in Flames...
    Reputation: D-Rock's Avatar
    Go buy one of these for $12.
    Takes the guessing out.
    D.
    Single Speed Junkie
    Reputation: crux's Avatar
    Quote Originally Posted by D-Rock
    D.
    That won't work the frame is alloy
    Feeding your addiction
    Reputation: Ventanarama's Avatar
    Dec 2001
    Quote Originally Posted by crux
    You can hold it, with your hand.
    "It is inhumane, in my opinion, to force people who have a genuine medical need for coffee to wait in line behind people who apparently view it as some kind of recreational activity". - Dave Barry
    Quote Originally Posted by Ventanarama
    Exactly.
    D.
    48" level
    While you are at the store pick up a framing level, so you can find a section of floor about 15" from a wall that is actually level, cheap ones are less than $15. Anyone with any brand of bike that messes with fork length and different tire diameters and linkage and shock lengths should spend a little more to know what they did and put that together with how it feels on the trail.
    DT
    thanks for the reply lads but over here in Great Britain i cannot find one of those angle finders.
    and why 15" away from a wall?
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Quote Originally Posted by vortexracing
    minimizes the effect of gravitational force on the angle finder
