Results 1 to 39 of 39
    El Terremoto...rising rate?
    I'm just wondering: Is the El Terremoto suspension rising rate?
    or maybe it's falling rate?
    thanks
    Meduix
    Quote Originally Posted by meduix
    thanks
    Meduix
    The Terremoto's rate is not as rising as the rest of the Ventana line. Here is what Darren said (long before my X-5 cracked and was replaced with the TM):
    The TM has a pretty flat rate when compared to other Ventana’s which gives it less mechanical bottoming control. Because of this the bike relies more on the spring and damper for bottoming control.
    Hope that helps!
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    Quote Originally Posted by CharacterZero
    Hope that helps!
    Ditto!
    and more info here (I know you already saw it meduix )
    El Ciclon - rising rate?
    And a lot of information here:
    That covers running a RP3 and the TM suspension curve. Too bad it ended up in the joker forum!
    LOL
    not so super...
    Reputation: SSINGA's Avatar
    Bring the pain Homers!!
    Nothing to see here.
    Quote Originally Posted by SSINGA
    oh no... not THE PAIN!
    PS: anyhow..I think CF likes Ventana
    involuntary dismounter
    Reputation: dHarriet's Avatar
    Quote Originally Posted by crisillo
    i'm pretty sure you don't want to tell people that!
    Solo Trail Explorer and Granny Gear Ninja!
    friends will help you move, good friends will help you move a body...
    Quote Originally Posted by dHarriet
    touché
    you got me there dH!
    wouldn't be the first time....and it CERTAINLY won't be the last!
    Reputation: RSutton1223's Avatar
    I am pretty sure he has moved on to Knolly.
    Quote Originally Posted by RSutton1223
    Yeah, when I complimented his new build, save the SB8 tires, he got all uppity and in my face, calling me a hater and insinuating that I am a poseur...all followed by how he is taking the SB8s off to run Nevegals. Too funny, cuz that is what I had said in the comment on the build.
    craaaaazeee!
    Well, I received the answer from Mr. Sherwood yesterday and as some of you said the TM is a rising rate bike in the first 2/3 of the shock stroke and a falling rate bike in the last 1/3...which yields a rising rate overall.
    I'm a bit worried about that I'd prefer a full rising rate design.
    Does anybody know how does the TM feels on jumps?
    The shock would be a CCDB
    Do you think it will have a good suspension perfomance?
    I come from a VPP design (ITS 6.6), I like the VPP it's plush and progressive...but the rear end is too flexy...that's the reason I'm looking for something stiffer, like the TM...
    bye
    Meduix
    I wouldn't worry.... it shouldn't be a problem with a shock with good bottom out control...
    How does it feel on jumps with a CCDB? Bottomless! Talk about a match made in heaven. It feels like it has a lot more travel than it really does. I couldn't be any happier with the TM/CCDB setup. I really wish I could explain it better, but words don't really do the bike justice. You have to actually ride one with a CCDB on it. It's amazing. Get in touch with Malcolm at Cane Creek if you have any questions...he is the Double Barrel king.
    I still see how much progress I have to make to ever jump like that
    I wanna be like Robb when I grow up!
    (Honestly! )
    (Honestly! )
    That is actually one of the smaller ones at Carter's. The qualifier is a nasty 5 footer and there are some nice doubles, ski jumps, hip jumps and rock gardens. My only wish is that it was a longer run.
    I am sure that the CCDB can be tuned to a T for any combination of riding factors, with bottom out control and platform being one of them.
    wonder
    I know that PUSH worked wonders for my DHX-C, and from what I have read, one can acheive similar results with the adjustablity of the CCDB without the aftermarket service.
    Damn.... I'll keep practicing then!!!!!!
    I already have the CCDB on my 6.6...I think it's a fantastic shock, but didn't know how it works on a TM...as I can see it works perfect...
    One of the reasons I'm thinking in a TM is the shock size (the same as my 6.6) so I can keep the CCDB that is almost new (1 month only), the other candidate is the Nicolai Helius FR which is the same shock size...
    The only things I don't like from the TM is the falling rate design at the last 1/3 of travel and the head angle, I'd like it a bit more slack...from 67.5º to 67º or maybe 66.5º...Sherwood told me it's possible to change that.
    The rest of the geo is almost perfect...it's low, long and slack enough so it must be very good on the downhills...
    bye
    Dani
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    bye
    Dani
    Controlling bottom out on the Terremoto is a legitimate concern. I couldn't tune the stock DHX-c to my liking but am content with a Push-tuned DHX-c. Still, I can on occassion hit bottom on drops running a 600 pound spring with 175lb rider (with gear)
    If you ended up with a 170mm fork like you were alluding to, then the HA would be slacked about .5* depending on A2C.
    Do you have a fork that you are moving over, or are you picking up something new?
    I weigh 194 lbs without gear...205lbs with gear (I suppose...) and I'm running a 550lbs spring on my Intense 6.6 with no bottoming issues.
    Do you mean that I will need a firmer spring if I move to the TM?
    bye
    Meduix
    Bodhisattva
    bye
    Meduix
    You may, or you may not. I can't say.
    I'd reckon that if you ran a DHX on the Terremoto you'd definitely need a heavier spring.
    I don't quite understand it, but folks seem to get away with much lighter springs on the CCDB.
    Good investigation!!
    I already have a Fox 36 VAN rc2 which I'd like to keep.
    I don't want to make the HA slacker by mounting a taller fork...it'd rise the BB too and I don't want it...
    meduix
    I am running a 450# spring on the Double Barrel and 190lbs give or take with gear.
    Bodhisattva
    That's what I mean. I'm not saying it's wrong by any means, but I don't understand how you can be running a spring 150 lbs less than mine while weighing 15# more than me. Obviously, damping has something to do with it, but how that can be achieved without making the shock feel like mush mystifies me.
    Then again, there's a good reason why I'm not an engineer....
    meduix
    Right on, then I suppose altering the HA is your best bet if you aren't running a CK hs that you could throw on the Ventana 7mm spacer (for a fraction of a degree of change, right?).
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    Quote Originally Posted by The Squeaky Wheel
    yeah, but rsutton is phat and you are all muscle......since muscle weighs more than fat you actually weigh more than him. you may not be smart enough to be an engineer but you are at least a doctor and should know this simple fact.
    I'm not sure if I've understood you...(sorry, but english is not my first language...)
    are you saying that I could change a fraction of a degree of the HA using the Ventana 7mm spacer on a Chris King headset?
    Anyway, using this spacer would rise the BB too, right? so where is the diference?
    I could make the HA more slack by using a taller a2c fork or by using a taller headset...or even with a larger tires....
    The fact is that I want to keep the BB height as low as possible with a slack HA (67 or 66.5), just like a mini-DH geometry...
    Do you think it's not a good idea? any sugestion?
    Meduix
    Ultra Ventanaphile
    Dec 2001
    I'm guessing that the CCDB has more oil volume and truely seperates slow and high speed shim stacks, So they are able to do their job better. The better the damper works the less spring you need.
    Here's some more confusing info too, My OLD Old Old School Vanilla RC? The original Coilover with Remote Reservoir, I run a 650# spring and Weigh 235 with gear. (Of course my Bruja is 1/2 Rising 1/2 Falling)
    Go figure!
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    Quote Originally Posted by FoShizzle
    I have hit a brand new low in my life...Fo called me phat. I think I'll stay in bed for a month now...
    dude, i called you phat, not fat...big difference! its a compliment
    D'oh, sorry - you read it right, I was wrong in suggesting it. Forgot about the low bb thing - you will have to alter the HA by custom geometry, anything else will raise the BB.
    Having a nice day!
    Reputation: LoneStar's Avatar
    That is actually one of the smaller ones at Carter's. The qualifier is a nasty 5 footer and there are some nice doubles, ski jumps, hip jumps and rock gardens. My only wish is that it was a longer run and I had stronger rims.
    There, Robb. Fixed it for you.
    Reputation: Mr Bling's Avatar
    Jan 2005
    Yeah same here, my flabber is gasted...I don't quite understand how that is. Really need to double check that if I ever get to buy one of these toys. Still hesitate between pushing it and going CCDB. Such a shame there is no Push affiliates in the Euro zone.
    Former Homer...Ventana convert: extreme poseur!
    Try with this:
    www.tftunedshox.com
    I think they are the Push dealer for Europe, they're at UK.
    bye
    Meduix
    Jan 2005
    they are and with the Euro-pound conversion it makes it more expensive than to ship it to the US, havit done by Push and shipped back. amazing!
