Results 1 to 11 of 11
    el terremoto - DHX Coil or Air?
    fork will probebly be Talas 36.
    What would you put on this frame?
    melon farmer
    Reputation: marcus_dukakis's Avatar
    Apr 2005
    if I had to choose, I'd take the DHX coil over the air any day. I've only had bad experience with thE DHX Airs, but they mave have improved it in recent years.
    If you want an air shock for the Terremoto, get the RP23 with standard air sleeve.
    I have a CCDB and RP23 on my Terremoto and the RP23 is good for XC type rides, but I wouldn't do anything too crazy on it. The CCDB is the best shock I've ever owned, hands down.
    Reputation: Mr Bling's Avatar
    Jan 2005
    SAme here I own a DHX5 and a RP23. But between DHXA and DHX5, I'd go with the coil.
    Good God, you truly are awakening my UGI with your frequent mentioning of the CDDB!
    Former Homer...Ventana convert: extreme poseur!
    Reputation: RSutton1223's Avatar
    Quote Originally Posted by marcus_dukakis
    +1
    CCDB on my 6" Ciclon.
    I would go coil.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    coil!
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    I would check to see if you can take a credit on the frame without a shock and just buy a CCDB or get it with a RP23 and buy a CCDB. Or take the Fox Coil then send it to PUSH.
    That's just my opinion. The only experience I have with coils are with Romic. But when the time comes for me to run a coil.....it will be a CCDB
    melon farmer
    Apr 2005
    Quote Originally Posted by Mr Bling
    Hehehehe.... it won't be long now.
    I have the number to call when you are ready!
    Hey Cris...that comment goes for you too. It is only a matter of time.
    Quote Originally Posted by RSutton1223
    HEHEHEHE
    The worst of it..it's that I know it's true
    Bodhisattva
    Reputation: The Squeaky Wheel's Avatar
    Quote Originally Posted by ran1974
    DHX-coil.
    RP23 will work if you aren't doing excessively long downhills with lots of repetitive quick hits - in which case RP23 can overheat and start to pack up.
    DHX-air is finicky and I'm not a fan.
