Results 1 to 11 of 11
    Ultra Ventanaphile
    Dec 2001
    El Gordo Pics and Matte "Raw" Aluminum Pics.
    Ran into Sherwood playing on the local lakebed (See NorCal's water issues for explanation) with his new El Gordo which is powdercoated in clear Matte. So while not a true "Raw" Aluminum it appears as such.
    Here's the full Monty...
    I believe his personal frames are 17".
    <iframe src="https://www.flickr.com/photos/31268906@N08/12757398935/player/dd27a4ab00" height="768" width="1024" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    Close up of front Tri, love the look of the Flag Decal on the Raw Alu...
    <iframe src="https://www.flickr.com/photos/31268906@N08/12756831273/player/d5358886c5" height="768" width="1024" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    This El Gordo is a 170mm spacing and clears the 4.8 Lou Tire mounted on Rolling Darryl Rims.
    <iframe src="https://www.flickr.com/photos/31268906@N08/12756853133/player/4b9a484923" height="768" width="1024" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    Close-ups of the Matte Clear PC ie "Raw Alu"
    <iframe src="https://www.flickr.com/photos/31268906@N08/12757150654/player/650d9b4b09" height="768" width="1024" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    <iframe src="https://www.flickr.com/photos/31268906@N08/12756710245/player/17693ba656" height="768" width="1024" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    BB/Front Derailleur Adapter Tire Clearance Etc...
    <iframe src="https://www.flickr.com/photos/31268906@N08/12758518414/player/70c1d1a216" height="1024" width="768" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    And Per the norm, it did not take Sherwood long to get comfy and start playing around.
    <iframe src="https://www.flickr.com/photos/31268906@N08/12758542614/player/feb5b19660" height="888" width="1024" frameborder="0" allowfullscreen webkitallowfullscreen mozallowfullscreen oallowfullscreen msallowfullscreen></iframe>
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    Does Ventana make the fork also? Looks like the welds match the frame.
    whatever...
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by steadite View Post
    I believe the fork is a SALSA (Per Trippower) , that gets stripped and PC'd to match.
    Last edited by Ciclistagonzo; 02-26-2014 at 11:15 AM. Reason: Corrected Manufactuer.
    -Aaron G.
    Reputation: Tripower's Avatar
    Jan 2011
    Quote Originally Posted by Ciclistagonzo View Post
    I believe the fork is a Surly, that gets stripped and PC'd to match.
    I'm fairly certain the fork is a Salsa aluminum Beargrease. It is the fork I am using also.
    Reputation: OldHouseMan's Avatar
    This is such a fun looking bike.
    ...which is powdercoated in clear Matte. So while not a true "Raw" Aluminum it appears as such...
    Can you explain this? I'm not sure if I now what "powdercoated in clear Matte." really means.
    Whatever it means, I do like it.
    I only ride bikes to fill the time when I'm not skiing.
    Powdercoating is just a process. You can put color on things, or you can put a clearcoat on things. Same as wet paint. Clear matte means dull and not shiny. That finish looks super sweet btw...love it.
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by OldHouseMan View Post
    OHM, El Train pretty much got it. Most powder coats are a thermo setting powder that essentially liquifies at high temp and then sets as it cools. The matte finish colors we've seen from Ventana are finished off by a clear coat layer that sets without the shiny super smooth feel hence the "matte". (akin to the matte finish on photo's vs the shiny finish). What Ventana has done here is to not add a color layer to the PC and you are seeing the color of the raw aluminum frame with the clear coat on top. I know that "Raw" frames, ie no finish placed on top, were sometimes requested or desired, but true Raw frames will oxidize, so they need to be constantly buffed and worked on to maintain the look. With this finish, especially the matte, the frame looks raw, but the oxidization should not take place.
    -Aaron G.
    i've been on Ventana frames exclusively for about 7 years . i talked w/ Sherwood at one point about an unpainted frame just to save that much weight. he wouldn't do it. so, i can see why the process now that you're talking about.
    breezy shade
    Thanks for the explanation. I'm definitely considering this for my next Ventana. Do you know if there is an up-charge?
    Ultra Ventanaphile
    Dec 2001
    $55 for the finish, per V HQ.
    I believe some extra frame prep is needed. (Speculation on my part)
    -Aaron G.
    No known cure
    Reputation: Vader's Avatar
    I want a polished frame.
    Ripping trails and tipping ales
  1. Replies: 12
    Last Post: 11-07-2012, 02:55 PM
  2. Replies: 87
    Last Post: 07-29-2011, 02:37 PM
  3. Just a small taste of my Eriksen "re-build"...PICS
    By Upandatem in forum Weight Weenies
    Last Post: 07-19-2011, 11:56 AM
  4. any pics of a fully built "ragley Troof" yet?
    By lokomonkey in forum All Mountain
    Last Post: 07-13-2011, 07:08 PM
  5. "Post Pics Of Your Cannondale XXXX" threads
    By CdaleTony in forum Cannondale
    Last Post: 02-10-2006, 03:04 PM
