Results 1 to 5 of 5
    Aug 2013
    El Cuervo shock set up help
    I am a bit of a newbe and just bought my first D.H. bike an 07 Cuervo. I have no manual. I know how to adjust preload, and add air as well as turn the dial. I am 200ish pounds should be 185 Lbs by the end of summer. What spring do I need? Recommendations on how to set up the Vanilla RC are appreciated.
    Proud lame eBiker
    Reputation: Internal14's Avatar
    400 or a 450# spring, depending on how soon you'll be at 185lbs. And are you weighing in with all gear and pack? If not, grab the 450#.
    On the Vanilla RC you'll have spring preload, compression and rebound damping to work with.
    Damping settings are very subjective to the rider. Weight only plays a small part in setting up the shock, 'preload'. As for compression and rebound settings that you'll have to answer a few more questions.
    Tracks you'll be riding all downhill with big drops and minimal pedalling? Fast? Slow? Lots of pedaling? How aggressive are you? Racer? Hucker?
    Have you spent a bunch of time and nailed your fork settings? If so, then match up the rear damping settings to balance the feel.
    www.velocitybicycles.comWhere customers become friends, not simply a dollar sign.
    Aug 2013
    I'd say 210ish with gear maybe 200. This is mostly for DH with minimal pedaling. I am coming from a 4 inch travel cannondale rush to my first DH rig moderate speed and for now >4 foot drops. I have not spent much time with set up yet. Just one ride through some nasty boulder and rock stream beads I used to walk the rush through. There is a huge difference in how the bikes ride and perform. I intend to ride deer valley resort in utah quite a bit this year. Perhaps by the end of summer I will have a full face helmet and neck brace then maybe some hucking. I am 34 and mortal if I where 21 again I 'd still be too timid to do Redbull rampage stuff.
    Ultra Ventanaphile
    Dec 2001
    I'm 220 and 230ish with DH gear. I'm running a #500 spring. Matched with a Heavy spring for my Rock Shox. Fork does a LOT of the work in DH so setting that up proper made a big difference for me. Once I dialed the fork, set up the rear to match and been pretty happy. I ride mostly chunky stuff with not much air time (38 myself so I understand the '"mortal" all too well.)
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    So what compression and rebound settings are people using?
    DHX 5.0 -550 spring
    I'm running 7 clicks of propedal
    Volume all the way in and 125psi of bottom out pressure
    With about 1/2 was on the rebound.
  1. El Cuervo frame sizing??
    By Christopher Robin in forum Ventana
    Last Post: 10-02-2012, 10:59 AM
  2. Cuervo build help (drivetrain)
    By Stripes in forum Ventana
    Last Post: 09-10-2012, 09:57 AM
  3. Ventana El Cuervo
    By William42 in forum Downhill - Freeride
    Last Post: 02-16-2012, 08:35 AM
  4. el cuervo....discontinued?
    By istandalone in forum Ventana
    Last Post: 07-27-2011, 02:55 PM
  5. I'm late to the El Cuervo party but....
    By adambarry in forum Ventana
    Last Post: 05-26-2011, 04:51 PM
