Results 1 to 12 of 12
    Keep Singletrack Single
    Reputation: willem3's Avatar
    El Comandante Creaking under load.... Mystery.....
    Need some help here. My 2012 El Comandante with the Sliders is creaking under load. I have a new chain, bottom bracket, chainring, chainring bolts, and cog/locking ring installed. All torqued correctly and professionally installed. I have determined that the only thing that could be causing the creaking are the sliders themselves. I have dismantled them, de-greased, and will re-install once I get my new wheel set.
    Has anyone else had this issue? Any recommendations for when I re-build? Grease or no grease on the bolts? Torque settings for the #6 and #5 bolts? I have a clicking torque wrench and always follow the specs. Looking for advice. Want to make sure to avoid this from happening again. I had 2,000 miles on the frame when this started. The bolts may have been over-torqued?? Not sure.
    Thanks in advance!
    Support Bend Trails
    http://bendtrails.org
    Phil's Trail Facebook Page
    https://www.facebook.com/PhilsTrail
    El CicloPath!!!!!!!
    Nov 2012
    Quote Originally Posted by willem3 View Post
    Thanks in advance!
    Was it creaking before the new componets were installed?
    This is for the El Comandante Hardtail. These are the sliders used to adjust chain tension.
    Support Bend Trails
    Feb 2006
    It sounds like a dry creak somewhere - - - meaning some bolt, seat rail or something is dry and begging for grease.
    Hopefully it's not the bike.
    Ultra Ventanaphile
    Dec 2001
    I'm nearly 4 years in with my Sliders and still no noises from them. Plenty from my GXP BB followed by a ticking from my Stylo Chainrings. (Grease on the spider chainring bolt tabs finaly cured it).
    But to answer your question about Torque values.
    Got these off the website FAQ, I know it states "For Suspension Bikes" but the torque values apply to the sliders too.
    #5 (6mm Allen Cap Screw) Minor pivot, upper and lower Shock bolts 90-100 inch pounds.
    #6 (8mm Allen Cap Screw) Upper Shock Bolt 150-170 inch pounds.
    One thing, I did wrong the first time, was I over torqued the 6mm bolts, and deformed the washers, had to get new washers and then torqued correctly, haven't had any issues.
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    change is good
    Sep 2004
    I weigh 235lb and my frame doesn't creak. Handlebar, seat, seat post, BB, loose crank - all have been sources, especially the seat. I do have a creak currently which comes and goes. I think it's the cleat- pedal interface.
    Thanks guys. Very helpful!! I think the washers are the trick. I did over torque. Rebuilding the bike with a new belt drive this week and will carefully install with the torque settings from the website.
    Happy Riding!!!
    Support Bend Trails
    Had the same issue on a Salsa Spearfish. Ended up bring the adapter for the Press Fit BB. Didn't look to see if your BB is a PF, but if so, good chance that is your problem given all else you've done..
    Quote Originally Posted by Coop29 View Post
    Yes. New washers from Ace Hardware and get the proper torque specs from Theresa @Ventana. I misplaced them. Also, proper belt or chain tension is key.
    Hope that helps!
    Support Bend Trails
  1. Arrggg! Creaking under load and have tried almost everything
    By Bubba74 in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 10-17-2016, 04:44 PM
  2. New El Comandante
    By n8rhino in forum Ventana
    Last Post: 04-06-2013, 09:39 AM
  3. New El Comandante Sigilo
    By Killrop in forum Ventana
    Last Post: 07-11-2012, 05:29 PM
  4. Any creaks with the Comandante?
    By DrDon in forum Ventana
    Last Post: 09-15-2011, 11:55 AM
  5. New Ventana El Comandante
    By hypokondriak in forum Ventana
    Last Post: 02-07-2011, 12:59 PM
