Results 1 to 8 of 8
    El Chamuco question
    I have a size large El Chamuco, the fox float shock is wearing out and I would like to replace it with a romic shock. I found a place that still sells them and I don't know the eye-to-eye length of my shock. If you know this number please send it my way.
    Cedric
    For the Chamuco, the shock length is 200mm (7.875") and the stroke is 57mm (2.25"). (I seem to remember Romic spec'ing their shock at 8.0" at one time, but you'll be fine with either 8.0 or 7.875.)
    T , V , & K Rider
    I have a Romic shock ( 7.875 x 2.25 ) that has never been used.....I replaced it with a PUSHed Vanilla RC on my 1st generation La Bruja before it was built up and never looked back ! My experience with a Romic shock was not so good on another bike ....the shock lasted three rides before spewing oil all over and rendering it useless ! However, Romic did rebuild it at no cost and the shock performed well to when I sold the bike about 6 months later ! TIG.
    Update: I have the right length on the romic shock. I need to know what size spring should I use. 300lb, 400lb, 500lb? will fox springs work on a romic shock?
    thanks ,
    Cedric
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by saidrick View Post
    thanks ,
    Cedric
    Need some info...how much do you weigh kitted up?
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    I weigh around 190lb-195lb. I usually wear a medium size camelbak, that probabley adds another 10-20lbs.
    hope that helps.
    thanks,
    Cedric
    jbf
    jbf is offline
    Reputation: jbf's Avatar
    I weigh about 155lb and was using a 450lb spring on my El Chamuco with the Romic. Fox springs do not fit as they have a different diameter and won't fit in the spring seats. I still have my old Romic with both 450 and 500lb springs. If you want it I'll let it go dirt cheap. PM me if you have any interest.
    <a href="http://www.flickr.com/photos/61173108@N02/6254021628/" title="P1100511 by jbrianflood, on Flickr"><img src="http://farm7.static.flickr.com/6051/6254021628_7d934dfd96.jpg" width="500" height="375" alt="P1100511"></a>
    Ultra Ventanaphile
    Dec 2001
    hope that helps.
    thanks,
    Cedric
    Yeah, I'd say run the 500. 550 would be better, but not sure what increments Romic made theirs.
    ~200# (you n kit) x 2.6 leverage ratio~ 520.
    -Aaron G.
  1. New El Chamuco Set-up
    By SUB160 in forum Ventana
    Last Post: 01-31-2006, 10:11 AM
  2. Another sizing question? on El Chamuco
    By aaronpv2 in forum Ventana
    Last Post: 04-26-2005, 09:06 AM
  3. Weight Question.... X5 vs El Chamuco
    By bikin in forum Ventana
    Last Post: 07-07-2004, 01:18 PM
  4. Chamuco frame spec question for you guys?
    By 2farfwd in forum Ventana
    Last Post: 04-02-2004, 10:04 AM
  5. question about El Chamuco vs SC Bullit
    By ride red in forum Ventana
    Last Post: 03-09-2004, 12:59 PM
