Results 1 to 5 of 5
    Powered by ice cream.
    Reputation: Enel's Avatar
    Comandante/Padrino headtube gussets?
    I have noticed that newer Comandantes and Padrinos have a sizable gusset between the head tube and the down tube similar to my old Salty.
    My early model Comandante has no such gusset.
    Just wondering if there have actually been some failures, or if the gusset is simply precautionary. I check the area fairly frequently, but it would be a very bad place to have a frame failure. A typical 29"er fork has at least the a-c and leverage of a longer 26" fork that you would use on a Salty for instance.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    I paid extra for the gusset. It was for my piece of mind and the cool factor
    Welcome Turner Homers!
    Reputation: el Turtlehead's Avatar
    The gusset is for those using 100mm forks....
    ...I'm not running one and therefore Sherwood didn't put one on there.
    Quote Originally Posted by Enel
    Just wondering if there have actualy been some failures, or if the gusset is simply precautionary. I check the area fairly frequently, but it would be a very bad place to have a frame failure. A typical 29"er fork has at least the a-c and leverage of a longer 26" fork that you would use on a Salty for instance.
    Ask me about my translucent green clearcoat!
    moe.
    I think they are standard on '08s
    Per Sherwood...
    "These people take a dump thatís a bigger difference than the a 5 Spot and a Blur LTc." DT
    AOK
    AOK is offline
    Reputation: AOK's Avatar
    Quote Originally Posted by el Turtlehead
    Yup. When I told Sherwood I was planning to run a 100mm fork on my Comandante, he recommended the HT gusset as well as a beefier top tube (same TT as an El Salt).
