I have an XL Chamuco frame on the way and I am making an assumption about the handling of the bike based on the head tube angles of the frame. Let me know if you all think my assumption is correct.
According to the Ventana spec sheet, the XL frame seems to have a bit steeper of a head angle at 69.9 degrees compared to the other sizes whose head angle is between 68-69 degrees with a 150mm fork. I prefer a little steeper head angle and am hoping the XL Chamuco with a 130mm Z1 will handle quicker than the same set up on one of the smaller Chamuco frames.
So, my question to you all is, is my assumption correct or am I missing something???
Thanks for you input, Cheers and have a great weekend!
