Results 1 to 8 of 8
    Reputation: OldHouseMan's Avatar
    CCDB on an X-5 with 6" rockers?
    I did a quick search and didn't see this specificly stated, but did see quite a few Ventanas with the Double Barrel. Does it fit with the 6" rockers and not contact the down tube with the reservoir? From the measurements on the Cane Creek site, it looks close.
    I'm thinking about going with the air version when it becomes available.
    I only ride bikes to fill the time when I'm not skiing.
    Thanks for the info. I contacted Cane Creek and it looks like the CCDB Air will be released in January 2012.
    ventanakaz
    Reputation: 1962's Avatar
    i wonder if the CCDB air would be a better shock for my la bruja than my fox DHX air 5.0 btw needs new oil and seal, The thing leaked oil since day one when i traded in my terremoto for the la bruja, And found out the day i traded in the terremoto it had a crack at the BB seat tube area. i must of cracked it at north* so what do u guys think fox or crane creek ? ...ralph
    i need to ride more. building jumps takes to much time...my other hobby is kicking the crap outta my home built mook jong.
    CAO
    CAO is offline
    I am real impressed with the ccdb on my 140mm bruja/ciclon mut. Very control damping to the point that it out shines the pushed pike out front. Check with the brain trust for clearance on the x5 it will be close. Sherwood dimpled a couple of our downtubes to clearance hese big reserviour shocks. Unfortunately the ccdb will not fit on a gen 1 bruja, i am still trying to fit a current shock to the gen1 witch and hope i can get a vivid to clear that big downtube.
    Tomac 98Special in Classifieds
    No known cure
    Reputation: Vader's Avatar
    The only problem I've had with my first gen CCDB on my custom numbered EC is that the low speed adustment knobs will eat two holes in a water bottle.
    Ripping trails and tipping ales
  1. HL 5 Spot, Push Rockers & CCDB
    By oceanfissure in forum Turner
    Last Post: 09-20-2011, 09:24 PM
  2. CCDB "new on trial tool"?
    By GhisalloWheels in forum Shocks and Suspension
    Last Post: 09-29-2008, 08:58 PM
  3. CCDB and Push Rockers on Spot?
    By 2trax in forum Turner
    Last Post: 11-13-2007, 03:40 AM
  4. Replies: 20
    Last Post: 04-23-2007, 02:27 PM
