Results 1 to 3 of 3
    Reputation: zanq's Avatar
    Adjusting PSI in El Rey rear shock?
    I'm sure this a fairly stupid question but one I'm not finding a straight-forward answer too...
    I picked up a used (2007) El Rey frame. This is my first experience with a FS bike as well as 29er. I have it built to the point that I'm making finer adjustments, including suspension sag. The rear shock is a Fox Float RP23 and the schrader valve for adjusting the pressure is blocked by an arm of the link. I can't even get the dust cap off. Is there a trick to gaining access to the valve or do I have to disconnect the shock from the lower mounting point and swing it up?
    Thanks for any help!
    Ventana El Rey - 3x9
    Schwinn High Plains w/ drop bars - 3x8
    Surly Ogre - Alfine 8/SS
    Nevermind, found this thread. Different frame but same issue.
    Adjusting RP23 on El Saltamontes
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by zanq View Post
    The recommendation of the Gonzo valve is a really good one for those Generation frames.
    -A
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
