29er Hardtail
Could you be kind enough to tell me, what is the difference between El Comandate & Padrino.
Thank you
Bubbleblower
The El Comandante has adjustable dropouts for Single Speeding and only has brake cable stops. The El Comandante Ultimate has both adjustable dropouts for Single Speeding as well as a replaceable derailleur hanger for gears. I assume the Padrino does not have the adjustable dropout, which would require a chain tensioner if you wanted to convert it to a SS. But I could be wrong... I would call and speak with Teresa or shoot them an email because they will line you out in no time!
Thank you
I'll try to find contact detail....I'm offshore North Sea UK for two more week.
Big help thank you
- You may not post replies
- You may not edit your posts
Forum Rules
