Results 1 to 35 of 35
    Ultra Ventanaphile
    Dec 2001
    2012 El Saltamontes Pics
    Here's some pics of the 2012 El Saltamontes.
    This Particular frame is a 15" Merdedes Blue with a Polished rear end.
    I weighed it as is with seatpost color etc. 6.29 lbs.
    Quick rundown of this frame:
    Taper Headtube,
    PF30 BB
    30.9 Seatpost
    New Pivot Location and Pivot
    2" Stroke RP23
    External Cable Routing under TT
    Straight TT with Tubular Seattube Gusset.
    Non-Modular 10x135 Dropouts, the swingarm is unique to the Salt. (lighter)
    New Rockers with the 22mm spacing for the upper Shock Shaft.
    <a href="http://www.flickr.com/photos/31268906@N08/6121379993/" title="IMG_0015 by CiclistaGonzo, on Flickr"><img src="http://farm7.static.flickr.com/6209/6121379993_176ece35f2_b.jpg" width="1024" height="552" alt="IMG_0015"></a>
    <a href="http://www.flickr.com/photos/31268906@N08/6121381335/" title="IMG_0023 by CiclistaGonzo, on Flickr"><img src="http://farm7.static.flickr.com/6204/6121381335_d83a353c00_b.jpg" width="927" height="1024" alt="IMG_0023"></a>
    Taper Headtube (The color looks closest to actual in this shot)
    <a href="http://www.flickr.com/photos/31268906@N08/6121923056/" title="IMG_0021 by CiclistaGonzo, on Flickr"><img src="http://farm7.static.flickr.com/6191/6121923056_0004ccc337_b.jpg" width="1024" height="768" alt="IMG_0021"></a>
    2" Stroke RP23, and 2:1 Rockers
    <a href="http://www.flickr.com/photos/31268906@N08/6121922818/" title="IMG_0020 by CiclistaGonzo, on Flickr"><img src="http://farm7.static.flickr.com/6080/6121922818_6af89b5a46_b.jpg" width="768" height="1024" alt="IMG_0020"></a>
    Polished rear swingarm is nearly impossible to capture correctly!
    PF30 BB.
    <a href="http://www.flickr.com/photos/31268906@N08/6121922560/" title="IMG_0019 by CiclistaGonzo, on Flickr"><img src="http://farm7.static.flickr.com/6198/6121922560_1b7198bfd3_b.jpg" width="1024" height="768" alt="IMG_0019"></a>
    New Salty Specific dropouts with cut out window...
    <a href="http://www.flickr.com/photos/31268906@N08/6121380273/" title="IMG_0018 by CiclistaGonzo, on Flickr"><img src="http://farm7.static.flickr.com/6201/6121380273_79c4fa1d17_b.jpg" width="1024" height="874" alt="IMG_0018"></a>
    Round Tubes for the Seatstays and ovalized for the chainstays...
    <a href="http://www.flickr.com/photos/31268906@N08/6121921798/" title="IMG_0011 by CiclistaGonzo, on Flickr"><img src="http://farm7.static.flickr.com/6199/6121921798_3c27fcf134_b.jpg" width="554" height="1024" alt="IMG_0011"></a>
    Curvy rocker goodness
    <a href="http://www.flickr.com/photos/31268906@N08/6121381617/" title="IMG_0024 by CiclistaGonzo, on Flickr"><img src="http://farm7.static.flickr.com/6065/6121381617_fa56e33afc_b.jpg" width="1024" height="768" alt="IMG_0024"></a>
    One more:
    <a href="http://www.flickr.com/photos/31268906@N08/6121924170/" title="IMG_0028 by CiclistaGonzo, on Flickr"><img src="http://farm7.static.flickr.com/6193/6121924170_a5a58d2024_b.jpg" width="1024" height="650" alt="IMG_0028"></a>
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    is turning a big gear
    Sweet powdercoat.
    Get it unlocked.
    post-ride specialist
    Reputation: icegeek's Avatar
    Sweet.
    (You sure you used the right hardware for those rear pivots? )
    Since when did Need have anything to do with this?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    nice!
    Reputation: slowrider's Avatar
    best looking "new" ventana yet
    I hope I can get an El Rey with that TT
    Reputation: Vrock's Avatar
    Very nice, it's like the best of both worlds, old school look with new pivots and parts....
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    Quote Originally Posted by slowrider View Post
    I would have to agree. Although, I am very concerned with the frame weight....6.29 lbs for a 15 inch frame. So what would a 21 inch frame weigh est. 8 lbs......really for a XC frame. I thought part of these new changes was weight reduction?
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by mtnbiker4life View Post
    "Really? Really? REALLY?! Really?!" - The Miz
    You seriously think a couple of inches of thin walled alu tubing is going to weigh 1.75 lbs?
    This modern frame weighs the same as my old Ti perch equipped Bushing Salty. (18").
    -Aaron G.
    Quote Originally Posted by Ciclistagonzo View Post
    Not serious, I clearly stated est. which means I have no idea but knowing the weight of the smallest frame being est. 6.29 lbs (including seat post) one can say the largest frame could weigh est. 8.0 lbs. Add up the difference in length of seat tube, top tube, down tube and head tube.....could be 1 - 1.75 lbs. I know Ventana doesn't publish weights and folks that purchase Ventana frames look at the entire package not just one parameter (weight).
    Pixie Dust Addict
    Love the Mercedes Blue. I hope that one day I can ride a Mercedes Blue Ventana of my own .
    Not dead yet, just playin
    Reputation: ohpossum's Avatar
    now THAT is what I've been wanting to see..
    I'll start buying lottery tickets now in hopes for a 650b "Bastardamontes"...
    op
    www.msmtb.org - Mississippi Mountain Biking
    ahhhh, sweet. now, if you could only get a 120mm rocker for it...
    My large is 6.6 pounds same 2012 El Salt
    I second the 120mm rocker thing.
    It would be perfect with 120mm
    Not to harp on this too much but I really think the Salty, in its current incarnation, would be perfect as a 120mm trail bike. It's often reviewed as too heavy for XC race and quite honestly that's what the Fuego was for, right?
    I am already running a 120mm Reba with 20mm TA (I think the stiffness of this frame warrants it, IMHO) and that extra 20mm really does open up this bike.
    What would it involve, design-wise? Would it be viable?
    All those in favour, say 'aye'!
    Quote Originally Posted by MangoTangoZach View Post
    That's good to know.....so an Extra Large most likely weighs in a 6.8 - 7.0 lbs. Post up some pictures of your build, Ole'
    Quote Originally Posted by Scubble View Post
    ^^^ Yes.
    T , V , & K Rider
    Drop Dead Gorgeous......
    .....that's about all I can say ! TIG.
    Reputation: zonoskar's Avatar
    Second that dop dead gorgeous comment. But.. is this a custom built frame? Or do not all frames in the 2012 lineup get the hump-back look?
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by zonoskar View Post
    Custom color maybe, and the polished rear for sure. But design wise, no, the Salty was always going to be Straight and butted tubes.
    -Aaron G.
    agreed...
    Now that's what all the new style frames should look like. The hump just doesn't do the frame any justice.
    So purdy! A custom El Salt would be a hoot. Hmmm...
    Love the color, it's on the short list of colors for my next built.
    love that color!
    just have to agree on the 120mm, though (with no bb height change, so a simple rocker won't do). It would make this puppy a long awaited excuse to trade in my 2004 X5...
    Reputation: mojojojoaf's Avatar
    Really pretty- I havent looked at Ventanas in a long time (not Ventana's fault just havent looked this direction is all) and the latest model updates to the Salty and expecially El Ciclon look really good....congrats on the beauty!
    with an inset headset and 120mm front this should still be a tad steeper than 69 HA, right? Warming up to it...
    Super Nice
    Frame is like a work of art
    Taper Headtube,
    PF30 BB
    30.9 Seatpost
    2" Stroke RP23
    PF30 BB.
    One more:
    Sound of Tires on Dirt: Sole Music
    Shredding with Good Comrades: Soul Music
    Hello,
    I am Hector, from Spain.
    I have a "Ventana El Saltamontes" in need of paint.
    I really like the color of the new box. Anyone knows the paint reference?
    Also I have to change the stickers and I really like these Ventana in handwriting type.
    Ups, I can't post links, It's my first message
    Would know where to find them?
    thank you very much
    That will be the "Mercedes Blue" i guess you could send it back to the factory where they could give it a lick and charge you accordingly , you might even get the decals done also
    or get some made to your preference .
    Reputation: BrokenBones's Avatar
    Feb 2005
    Hey Hector give Teresa a call to find out about a factory refurbish. I broke my frame a couple years ago and sent it back for a complete overhaul. It was originally champagne powder coated with a polished rear, but I had Sherwood do the Army green powder coat on the whole frame after it was repaired. They also replaced all the hardware, bearings and decals. It came back just like a new bike. Well worth the few hundred bux!
    Original bike above, refurbished bike below:
    Attached Thumbnails Attached Thumbnails 2012 El Saltamontes Pics-original-cyclon.jpg
    'Bones
    Jun 2012
    very nice. I want this bike
    has remained perfect.
    But, from Spain to send the bike, customs, etc.. and send it back to Spain, customs, etc.. operation is not acceptable.
    If I lived in USA I thought so.
  1. 2012 Magura MT8 pics
    By jbsteven in forum Brake Time
    Last Post: 05-05-2012, 01:29 PM
  2. 2012 Sortie 29er pics
    By Shiba Inu's Rock in forum Diamondback
    Last Post: 08-01-2011, 04:57 PM
  3. Some more 2012 pics
    By R+P+K in forum Specialized
    Last Post: 07-31-2011, 06:04 PM
  4. 2012 Giant Talon 0 pics
    By woodandsteel in forum Giant
    Last Post: 07-25-2011, 08:43 AM
  5. Replies: 10
    Last Post: 01-15-2007, 07:14 AM
