Results 1 to 10 of 10
    11 is one louder than 10
    Reputation: Green Giant's Avatar
    2011 cable routing pictures?
    It would be great if someone could post some pictures of finished cable routing on the 2011 el Rey or el ciclon.
    Specifically where the looped Velcro sticker pads go and how their rear brake line lays in the seat tube cable mount.
    I can not get mine to lay remotely flat in there.
    Some finished pictures would be helpful.
    Impressed how easily the lines routed through the down tube.
    UPDATE: Talked to Ventana and got an explanation. The velcro stickers go around the cable and brake housing at the location of the tab. That "fattens" up the diameter, making it easier to get a good tension on the zip tie.
    I will post some pictures after I clean it up. Makes sense after talking to them.
    Did the first shakedown ride tonight - will post a review here in due time.
    "The thing is, Bob, it's not that I'm lazy, it's that I just don't care."
    Lightly salted
    Reputation: fuenstock's Avatar
    I posted some pictures of the new ciclon cable routing in this post, not sure if its what your looking for. I havn't had any trouble with the routing.
    Another new Ciclon
    I saw those, thanks. Any chance you could shoot the brake line and that particular zip tie mount? That is the one I am struggling with. Not sure if I can get the cable to "lay down" in the mount more and I know we don't want them to move at all in the mounts. That mount at the shock tabs...
    Thanks.
    Here's mine. One thing I've ended up doing is using two or three small zip ties in each cradle under the bb, rather than one large one as intended. They tighten down the housing better, and the housing stays in place if one of the two/three breaks. You might try that on the seat tube as well.
    Attached Thumbnails Attached Thumbnails 2011 cable routing pictures?-img_0664.jpg
    Lightly salted
    I think you'll be fine if the brake line is not completly seated in the seat tube zip tie tab. I'm not even using a zip tie at that tab and it hasnt been a problem. No cable rub or cable wear at all.
    Keep on Rockin...
    Reputation: Miker J's Avatar
    Nov 2003
    Are the router holes in the down-tube pre-fab? I'd really like a frame w/o the internal routing, and just have zip-tie tabs on the underside of the downtube - this design makes for good downtube protection from rocks and is about the straightest route you can go.
    This the zip-tie option is something Sherwood would do?
    Proud lame eBiker
    Reputation: Internal14's Avatar
    Quote Originally Posted by Miker J View Post
    You can get what you want for sure. It'll take a little extra time, and money, but I'm sure Ventana would do that for you.
    www.velocitybicycles.comWhere customers become friends, not simply a dollar sign.
    The Bubble Wrap Hysteria
    Reputation: mtnbiker4life's Avatar
    I noticed you have the frame / fork listed on fleabay! So you decided to sell it?
    Not any more....
    Quote Originally Posted by mtnbiker4life View Post
    Update 2 for the evening: No longer selling it. Decided to keep it and hopefully sell my Single Speed.
    Shakedown ride tonight - went VERY well. More to come.
  1. Front der. cable routing pictures on durance
    By dbblackdiamond in forum Maverick
    Last Post: 08-31-2011, 11:14 AM
  2. Replies: 5
    Last Post: 08-11-2011, 04:27 AM
  3. cable bridge pictures?
    By Jim Z in VT in forum Trail Building and Advocacy
    Last Post: 06-23-2010, 03:00 PM
  4. Replies: 3
    Last Post: 01-12-2007, 07:00 PM
  5. Roughing it?
    By formica in forum Women's Lounge
    Last Post: 03-11-2006, 08:39 PM
