Results 1 to 12 of 12
    more skier than biker
    Nov 2006
    100mm fork on El Commandante?
    Has anyone ever run a 100mm fork on their singlespeed Commandante's? I'm pretty sure the frame is designed for just an 80mm (which I have now), but I want one of the new Fox F29's with remote lockout and it only comes in 100mm and 120mm versions (why no 80mm?).
    Anyway, I'm worried it will mess up the geometry too much, and am curious to see if anyone has a 100mm fork on their Commanders and if they like it or not.
    Thanks in advance compadres.
    Kappius Components Ambassador - Ping me a note for a discount code
    Proud lame eBiker
    Reputation: Internal14's Avatar
    If memory serves....and I am getting older so take that into consideration....but I seem to remember that you can add a 20mm spacer to the negative side of the air assembly and knock it down to an 80mm fork.
    And to answer your question: Nope. Never tried a 100mm on an El Comandante, yet.
    www.velocitybicycles.comWhere customers become friends, not simply a dollar sign.
    Neg reppers r my biatches
    Reputation: FoShizzle's Avatar
    try it, i am sure it will be fine. if you want it "quicker", then make it 80mm.
    Keep Singletrack Single
    Reputation: willem3's Avatar
    This is not recommended by Ventana. They built the frame for the 80mm specifically. The headtube needs to be strengthened to accomadate the 100mm fork.
    Support Bend Trails
    http://bendtrails.org
    Phil's Trail Facebook Page
    https://www.facebook.com/PhilsTrail
    Ultra Ventanaphile
    Dec 2001
    Actually... now that the wrap gusset is being placed on all the hardtails I believe the 100 is ok. Pre '09 models without the wrap gusset (at the head tube) was not recommended.
    -Aaron G.
    "Before D.W., "anti-squat" was referred to as pedal feedback."
    Thanks for the clarification. Good point! My frame is an 07. Are all the new SS frames being built with the drop outs as opposed to the EBB? Just curious. Thanks!
    Support Bend Trails
    Ultra Ventanaphile
    Dec 2001
    Quote Originally Posted by willem3
    I believe the stock frame is EBB but you can order the Slide Drop outs as an upgrade. Not sure on cost difference.
    -A
    -Aaron G.
    Powered by ice cream.
    Reputation: Enel's Avatar
    Quote Originally Posted by FoShizzle
    Try it, and stress crack the HT, DT junction.
    Like I did.
    Still rolling as a commuter though.
    Quote Originally Posted by Enel
    Like I did.
    not sure what my Mav 32 fork was...not an 80mm, but not a 90mm, not sure where its AC fell
    hardtails should only run 80mm forks anyway
    as for stress crack? way to blame it on the bike, phat ass
    You wish you had my girlish figure.
    Ultra Ventanaphile
    Dec 2001
    I just threw up in my mouth a litttle bit......
    -Aaron G.
    Quote Originally Posted by Ciclistagonzo
    <input id="gwProxy" type="hidden"><!--Session data--><input onclick="jsCall();" id="jsProxy" type="hidden">
    I should have asked if Fo thinks this is the Turner forum?
