Results 1 to 15 of 15
    Mar 2013
    Wife Friendly Back Yard Pump Track
    Check out this pump track built by Action Sports Construction! Visit ActionSportsConstruction.com for more info about having a Pump Track built at your home!
    Attached Thumbnails Attached Thumbnails Wife Friendly Back Yard Pump Track-1656201_10152164887951014_81522597_n.jpg
    Captain Climber
    Reputation: Jem7sk's Avatar
    Jan 2013
    How much does something like that cost Alex?
    Mar 2013
    email me with more details alex@actionsportsconstruction.com and ill send you a quote. but pump tracks typically cost 4k-5k
    $4-5k for labor? Or does this quote include design, labor, equipment rental/usage, fuel, mobilization fees and building materials? That estimate seems pretty low...imo
    Mar 2013
    that price include everything. I build 25-30 pump tracks a year. I rarely see them go over 5K
    Well I will be hitting you up next time... we spent over that in dirt alone.... 1100 cubic yards at $4 a yard $100 a truck. Rental of 2 plate packers, a skid steer and mini ex, labor, plus design and mobilization cost. I believe our track was about $35,000 for our bike park.
    You got this!
    Pretty cool... Maybe when I win the lottery
    Reputation: mercyNside's Avatar
    Jan 2014
    Quote Originally Posted by AlexFowler View Post
    Sweet!
    2014 Cannondale Rush 2
    Captain Climber
    Jan 2013
    What's the maintenance on something like this?
    It will depend on the size, type of dirt and climate you live in but with out soil stabilization you will want to water it every couple days at first. Once it is seasoned and all settled you wont need to water it as much but I would still recommended watering and sweeping it before every ride for best results. You will also want to control the weeds or the not super ridden area will begin to grow in. If you can afford it dust fighter will save you a lot of time maintaining and you can ride shortly after rain falls with no damage...
    nothing to see here
    Reputation: Stevob's Avatar
    How long did it take you to build that Alex?
    I see hills.
    I want to climb them.
    More info on dust fighter please
    Dust fighter? What is this, where do you get it and what do you do with it?
    Struggled with weeds last year on my pump track and really interested in anything that reduces maintenance time.
    Btw - can anyone explain the benefit of sweeping? Is have thought after watering that bit of dirt would pack back down.
    Quote Originally Posted by cglasford View Post
    Quote Originally Posted by phat_tony View Post
    Sorry it is actually called dust shield it is an erosion control product that stabilizes the soil and prevents erosion by bonding the dirt particles together. DustShield Dust Control and Erosion Control: Roads-Construction Sites-Empty Lots | Soil-Loc Scottsdale AZ
    You would have to follow the link and order it. I believe you can get it 5 gallon, 55 gallon and 250 gallon options. You mix it 7 parts water to 1 part chemical and then you spray it on liberally to the riding surface. You let it set for 24 hours to cure and then you ride it and it turns the surface rock hard and the water doesn’t penetrate. If applied correctly and cured fully you can broom the water puddles off your riding tread and ride right after rain storms, about 90% of all sanctioned out door bmx tracks use it these days.
    For weed control I would recommend purchasing round up concentrate and mixing it at double strength and spraying the riding surface. It would be best if you could treat it with a pre-emergent agent, this is typically a pellet that you would sprinkle on the ground and it will kill the seeds before they grow. I would do the pre-emergent in the early spring.
    The soil loc product won’t stop weeds so you will have to fight them separately but it will limit their access to the riding surface
    And sweeping, IMHO you want the smoothest track you can get with the least amount of loose soil. If you can water and pack it to the point where it won’t be loose, great then don’t sweep. Typically, especially, when a track is new the silt sediment from the soil you use will work its way to the top as the soil compacts. From my experience the first year is the year you need to sweep and remove the “moon dust” . Again it will all depend on the soil you use. Less silt/sand the less sweeping you will need or use a soil stabilization product and never sweep again. That is what I am going to be doing for the bike parks that I manage.
    https://www.facebook.com/pages/Cotta...96908407004866
    https://www.facebook.com/EaganBikePark
    Good luck!
    Thanks for the detailed response! Wish you guys were in Ottawa Canada - working in it myself was fun but I don't really have the time to figure all this out and would be happy to outsource it.
    Good luck!
    Reputation: HypNoTic's Avatar
    Tony,
    I'm based in Quebec and we also build bike park & trails. Give me a call if you want. I'm near Bromont. We have access to all the supply you need.
    I build trails for moose & beaver
    PTBA member
  1. Replies: 24
    Last Post: 09-07-2014, 08:02 AM
  2. Replies: 8
    Last Post: 08-27-2013, 04:33 PM
  3. Replies: 6
    Last Post: 04-05-2013, 12:10 PM
  4. Back yard pump track. Ideas?
    By Blatant in forum Arizona
    Last Post: 04-02-2012, 07:46 PM
  5. back yard pump track inspired, Mesa AZ.
    By LJYJ in forum Arizona
    Last Post: 04-28-2011, 06:33 PM
