Results 1 to 16 of 16
    Jan 2009
    ... and if we just ... who uses protection these days?
    any of you ss dj guys run a chainstay protector?
    Not me.... If u want to, go ahead
    Would you please look around before creating a new thread, there's 5+ threads of yours in the first page...
    Reputation: panda-man's Avatar
    Trojan?
    Jan 2009
    good Lord man
    on my old r6 forum those guys wouldn't shut the **** up. not tryin to piss on anybody's cornflakes but i guess im just used to that
    Bikes Rule
    Reputation: Demo-9's Avatar
    Mar 2006
    At least this post does not reference wheels.
    Rule of thumb - single speeds and chainstay protectors do not look good. Period.
    wait...what?
    Reputation: CaliforniaNicco's Avatar
    what KIND of protection? me, I go w/o
    Don't worry about a chain protector. If your chain is decently tight you will have zero slap.
    Meh.
    Reputation: XSL_WiLL's Avatar
    None necessary with a single speed setup. If you're getting slap, you don't have enough chain tension.
    dirt rules
    Reputation: sittingduck's Avatar
    Apr 2005
    I put a couple of stickers on the chainstay of my 20". 25/8 gearing has the chain running VERY close to the chainstay, and I can't (sensibly) make the chain tight enough not to hit it once in a while.
    SuperInstigator
    Reputation: tibug's Avatar
    Quote Originally Posted by sittingduck
    Same here...I run 25-10. I wrap the chainstay because I will not run my chain very tight. It's not a good thing to have the chain that tight, in my opinion.
    I wish I didn't know now what I didn't know then.
    Bikes Rule
    Mar 2006
    25-10 you should be able to get the chain tight enough that it does not touch the chainstay. Another reason to run a Splined chainring - even tension and no tight spot.
    SuperInstigator
    Quote Originally Posted by Demo-9
    Oh sorry I meant 28-10. There really isn't much of a difference between 28-10 and 25-8 regarding whether the chain will hit the chainstay or not...and the way mine is with a 28t Profile Imperial sprocket and stock Haro cranks..I do not like how tight the chain has to be in order to not contact the chainstay...its not good for the pawls and the rest of the drivetrain. I cannot use a splined chainring at this point in time, but on my new build, I will be running 48 spline profiles and a splined Tree sprocket.
    Reputation: A Grove's Avatar
    Nov 2006
    it really comes down to chainstays and what gearing. my chain will slap on hard landings while riding street, etc. thus i wrap it.
    Reputation: ServeEm's Avatar
    Jun 2005
    I"m surprised no one mentioned condoms.
    I run 4 pegs on my 20 with 28/11, I couldn't fit tensioners so it's loosen which forced me to wrap my stays. Now I run a 24/9 w/ pegs and the new ratio allows me to slam my wheel literally so I have to take apart my chain to get my wheel off. Nice and tight, never loosens, loving it.
    gnar, brah
    Reputation: Andrewpalooza's Avatar
    Dec 2004
    I'm rockin the 23-12 and I wrapped my chainstay. Impossible to get enough tension that it won't slap once in a while. I'd rather not hear any back-talking from my bike, personally. If I'm going to overshoot a jump and make my chain slap, at least I don't have to listen to it.
    Trestle Bike Park
    My leg feels funny
    Reputation: liqwid's Avatar
    I still have one on but should probably cut it off. I put it on there with a spring loaded tensioner but have pretty much eliminated any chain play.
