Results 1 to 7 of 7
    Where to find 24 to 28 tooth ss chain ring
    i was just wondering were i can find some single speed specific front chain rings. i need something from 24t to 28t. oh yes another thing they have to be 4 bolt. any responses will be helpful
    h-town hucker
    Reputation: sandyP1's Avatar
    what cranks do you have?
    some brands will have an option of different sized chain-wheels.
    i know that the Truvativ luftlarm or whatever its called has many different choices for the chain-wheel when you buy the cranks.
    Reputation: cummings's Avatar
    May 2005
    You have to have 3-piece, bmx style cranks. examples are deity, profile and other bmx. If you do, go to danscomp.com it is a bmx site and it has a wide selection of chainwheels
    i have truvativ isis cranks. so is there anyway to find a chainring that is thicker than normal
    May 2005
    No, there is no mtb style "thicker" chainring. and are you trying to do micro drive?
    dirt rules
    Reputation: sittingduck's Avatar
    Apr 2005
    Quote Originally Posted by localcuztomkona
    Just get a bashguard...
    Local Paperboy Hero
    Reputation: Cru Jones's Avatar
    The smallest you'll be able to run on the outside is probably 32. Check out one of these (make sure you get the 4 arm type)...
    http://www.jensonusa.com/store/produ...Chainring.aspx
    You could run a smaller gear on the inner chain ring spot and then put a bash guard on the outside. I'm not sure if they make single speed specific for the inside gears, though. But, something like this should work just fine...
    http://www.jensonusa.com/store/produ...gs+4+Bolt.aspx
