Results 1 to 7 of 7
    What do you think of my new mountain cycle
    Hey all i just bought this biked used off pinkbike a few weeks ago. Took it in for a tune up at lbs but the brakes still squeak/grind and the cranks creak a bit. But overall it is a really nice bike to ride and is a bit small but still a good size.
    Pictures:
    What do you guys think, is it a good quality bike. I paid 550$ canadian
    Megadeth
    New brakes, tensioner, chain guide and forks would do it good.
    My. Car. Is. A. POS!
    Reputation: literocola's Avatar
    Check your cranks to make sure they are tight with a 8mm allen.
    If they still creek, take the cranks off, take the BB out, clean very well with cleaner. I use White Lightning. Clean out the BB shell of your frame so there is no cr ap in the shell. Cover all the threads of your BB shell, and BB with grease. Re-install the BB, cranks, and make sure they are tight! This should stop your bike from creaking. But not in all cases.
    Husserfelt cranks are cheap so, if the problem persists, just replace the cranks and BB.
    A Gentleman and a MTBR'
    There's something about Mountain Cycle.... I love the look of those frames, so beefy.
    does it need the chain-guide on the front with a single speed set up?
    Reputation: mcrumble69's Avatar
    Nice ride!!! The Rumble is a great frame..
    Try cleaning the brake rotor with rubbing alcohol, and lightly sanding the pads with sandpaper. Just make sure you don't touch the pad surface with your fingers. The oil from your skin can contaminate them.
    Quote Originally Posted by colourclassic
    i dont have an unlimited budget :| . whats wrong with my forks.
    And how do i get the brakes off to sand with sandpaper
    Meh.
    Reputation: XSL_WiLL's Avatar
    If you don't know how to do something as simple as removing the pads, you probably shouldn't do it yourself.
    Go read the Park Tools repair section or buy yourself a book about bike maintenance.
