Results 1 to 5 of 5
    Want an easier gear on my 24 inch bike.. what sprocket size?
    Hi
    Currently I'm running 30t front and 12t rear. This gearing is abit uncomfortable at a skate park. I would like an eaiser gear.
    I was thinking of putting 26t front. Do you think will work? What do people normally run on 24inch bikes.
    Evil The Following MB 2017
    Canondale Scalpel Team 2015
    Kona Raijin 2014 SS
    Pro Crastinator
    Reputation: .WestCoastHucker.'s Avatar
    a 4t drop is pretty substantial. that said, it will be tons easier to spin for the park, but will also be tons slower everywhere else. i currently run a 25/10 which is spot on equivalent to your 30/12, but spend almost all my time at the jumps. i feel i would only wanna drop maybe 2t for strictly park though..
    ended up getting 28t sprocket and its perfect for the park
    Kona Raijin 2014 SS
    Play round with this to cross compare on gear ratios - tires factor into the equation as well!
    Gear Calculator | bmxultra.com
    Reputation: cmc4130's Avatar
  1. Gear inch ratio
    By jball1125 in forum Singlespeed
    Last Post: 01-22-2017, 10:24 AM
  2. Front sprocket size on a 1x11?
    By L84Beer in forum Fat bikes
    Last Post: 01-25-2016, 12:35 PM
  3. Replies: 9
    Last Post: 04-03-2014, 06:24 AM
  4. PBJ Max Chainring/Sprocket Size?
    By Foxbat in forum Transition Bikes
    Last Post: 10-26-2013, 11:19 AM
  5. Gear Inch and Top Speed Calculator
    By BikePartPorn in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-13-2011, 12:06 AM
