Thread: Stem issue:
    resident dumbass
    Reputation: dirtyharry's Avatar
    Stem issue:
    My friend bought a pretty darn nice rebuilt Stance Static real cheap to replace his MX comp, but even without the spacer the steer tube is too short. I've had a look at it, and with a shorter stem (referring to the height of the clamping part on the steer tube) and no spacers, the Stance could fit. He currently is running a Hussefelt stem with matching bar, and needs a smaller stem that fits a 31.8 mm bar, something roughly 2/3 or less the height of the Hussefelt. If his bars were 24.5's, my Funn Rippa stem would be a tight fit (if that gives you an idea).
    What can he buy that is roughly the same length (from the bar clamp to the steer tube clamp) but shorter steer tube clamp as his hussefelt stem?
    Incase you don't understand what dimensions I'm referring to, here's an educational drawing.
    I'm out of things to say . . .
    Reputation: Evil4bc's Avatar
    Quote Originally Posted by dirtyharry
    Harry
    Have your friend look into the stems from S.I.C. they have the shortest clamp height and accept 31.8 bars and also 25.4
    Hope this helps , if not our new stem should be ready in about 2 weeks !!
    Follow me on Instagram for up to date build pics -Brad4130
    Nem-Pro store
    Nem-Pro Blog
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    Quote Originally Posted by Evil4bc
    Harry
    Shameless self-promotion :P
    resident dumbass
    thanks a million, man! That's EXACTLY what he needs. I just called him and told him.
