Results 1 to 20 of 20
Thread: ss gear ratio?
    ss gear ratio?
    stock my bike is 28/14 or 2:1. man, im spinning my brains out on the street. anybody run 28/12 on the street and trails? im lookin for a good overall gear ratio? thanks
    Reputation: the_godfather's Avatar
    28/13 works out to about the same as a BMX. which is usually fine for me. if you are wanting a lot more speed then go for 28/12 but it will be quite hard
    i ride my bi*ch hard
    Reputation: spazzy's Avatar
    28/12 isnt that hard
    i am running 34/14 and i am doing just fine, build up the legs a little and then you are golden
    Yo!
    Yo! is offline
    Reputation: Yo!'s Avatar
    Dec 2008
    I ran a 32/16 on my DJ with 24"s and I was spinning. I liked the pop off the line, but I could never maintain any decent speed for street.
    I'm 5'9, 180lbs. on a size 14 bike, and I run a 170mm crank arm with a 36t in front, and a 17t out back. This ratio is the magic number, because it leaves me just enough low end but also keeps me from spinning too much.
    Just figure out your gear inches by taking your front tooth count divided by your rear tooth count and multiply it by your wheel diameter. 55 inches is classic BMX; my 36/17 on 24"s is 50.8.
    A 2:1 is about 48 inches.
    I played with a dozen different ratios, and this is the best one for me and for anyone, in my opinion, who needs a versatile ratio for rolling street in the 5'9, 180 range on a size 14. Sheldon Brown will argue that running an even tooth count up front with an odd out back will contribute to faster chain wear, as will running micro gearing, but that's a no big deal sacrifice when finding your magic ratio, especially if you're running SS with steel chainrings front and back.
    Reputation: spicoli-ss's Avatar
    Jun 2005
    gear ratio
    I ride street and park. My gear ratio is 36x12. I did ride a 32x12 and I was spinning way too much, I am entertaining the idea of buys a 34t, but the 36 is great to whip around the bowl with at the park.
    Yo!
    Yo! is offline
    Dec 2008
    That's a pretty steep ratio....what size wheels are you running?
    Don't you find it difficult to climb with that setup?
    I'm running 28x13, works nice for most things. Sometimes I think I want to drop to a 12 in the back but there are some ugly hills where I ride street.
    CAMBr West
    Gives us a couple bucks and we'll give you some trails with sweet jumps and stuff.
    dirt rules
    Reputation: sittingduck's Avatar
    Apr 2005
    36x12 would be practically unrideable on a 26. Steep as hell on a 24 too, but doable.
    28x12 on 26" ftw.
    Jun 2005
    After I reread my post I forgot to mention I ride a 24" rear wheel. I don't ride hills or dirt on this bike. This is a strictly park bike/pool bike. Sometimes, I find the 36 a little tall, which is why the 34 seems intriguing to me...I like speed around the pool, but it does take a few laps to wind it up.
    Meh.
    Reputation: XSL_WiLL's Avatar
    I didn't notice a huge difference when I went from 36:18 to 28:13. I may drop down to a 12t in the rear.
    Jun 2005
    This link will give you gear ratio in inches and you can compare different setups.
    http://software.bareknucklebrigade.c...it.applet.html
    It's a good indicator...
    guess im gonna need stronger legs to roll with 28/12 on trails with any climbs
    dirt rules
    Apr 2005
    Quote Originally Posted by spicoli-ss
    That's a really nice calculator, thanks for posting that.
    I want a calculator that will tell you the exact CS length with different combos for full and half links.
    GAME ON!
    i run 32:14 for street
    RIP Adam Yauch
    "M.C. for what I AM and do, the A is for Adam and the lyrics; true"
    Reputation: A Grove's Avatar
    Nov 2006
    25/11 for me on two-six's. Perfect ratio for me.
    JMH
    JMH is offline
    Sugary Exoskeleton
    Reputation: JMH's Avatar
    Feb 2005
    I have a 28/13t setup on my hardtail, a bit taller 34x15t on a little slopestyle bike. Both feel good for their respective uses, I ride the SS a little faster on steeper stuff so the bigger gear is nice.
    Reputation: cmc4130's Avatar
    Quote Originally Posted by Yo!
    finally. someone knows what the hell is going on. it's an easy formula. use it, people.
    your goal is around 55 gear inches for DJ/4x/pumptrack/skatepark/mtbmx......
    34/16, 32/15, 30/14, 28/13, 26/12 all work great with 26" wheels. if you have 24" or 20"s it's gonna be different.
    I post too much.
    Reputation: snaky69's Avatar
    Mar 2005
    It's in my guide, woot!
    23/9...seems about right.
    dirt rules
    Apr 2005
    Quote Originally Posted by i like downhill
    Maybe for 24" wheels.
    2.5:1 on 26" is a bit tall, unless you only go downhill.
