    Feb 2013
    Specialized P2 crank spindle?
    I'm resurrecting a 2004 P2, and am looking for the right crank... That is, it had a cartridge BB; I removed, put in an external BB, slid in an new SLX (hollowtech), but there's about 10mm of space, too much for spacers. So, can ya'll help me out here: Does anyone know the right spindle length -- or a correct specific crank -- for this set up? If I left out any necessary info, just let me know. Thanks.
    Don't know what to tell you it should be a straight forward installation.
    http://bike.shimano.com/publish/cont...stallation.pdf
    Reputation: rogbie's Avatar
    What is the width of the BB shell? I'm assuming it's a 68mm and the crank/bb you're using is for a wider BB shell.
    Feb 2013
    Thanks for the good help -- I gleaned that from the tech doc; it has to be that. I'll double-check with a micrometer soon. The build is kinda on the back burner...
  1. Crank spindle life
    By urmb in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 07-19-2013, 09:23 PM
  2. XTR Crank spindle not long enough?
    By cfrea in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 01-07-2013, 07:35 AM
  3. Sram crank spindle slop. What is missing?
    By melonheaded in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-01-2012, 05:20 AM
  4. Truvativ Stylo crank loose on spindle
    By cackalacky in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-15-2012, 07:14 PM
  5. Has crank spindle size changed?
    By agriholic in forum Shimano
    Last Post: 01-11-2011, 09:30 AM
