Results 1 to 10 of 10
    specialized hardrock parts on black market riot frame
    if i got a black market riot frame would all the parts from my specialized hardrock fit on it?
    Reputation: A Grove's Avatar
    Nov 2006
    All-in-all, they ought to fit up. Only thing that may be of issue would be the steer length(highly unlikely, but still could pose an issue) and BB shell width.
    Although... I hope you aren't expecting those parts to last too long....
    no just till i can afford more lol
    Meh.
    Reputation: XSL_WiLL's Avatar
    You'll need a different headset and a different seatpost and clamp. And you'll probably want to convert the rear wheel to a bolt-on. And of course you'll have to SS it (well, you could use a Saint derailleur or one of those dropout derailleur hanger doo-hickeys).
    Nov 2007
    Aren`t the rear dropouts 14mm? Do you have quick release wheels? If so that will be a problem on the back. You will have to run a single chainring on the front too. Not to mention the seat post and headset.
    Meh.
    Not 14mm drops. 10mm.
    Bikes Rule
    Reputation: Demo-9's Avatar
    Mar 2006
    As mentioned you will need a new post, clamp ( frame does not come with it), headset and maybe a new rear wheel if you have a Q/R. Most Specializeds use a 30.9 post and the riot is a 27.2. Also need an integrated 45/45 contact angle Campy style headset.
    For the cranks it depends on the set-up you have. If you have 3 rings, take off the inner and middle. See of the BB will work with the cranks. Not sure what you have on there but you may also need new cranks...
    Head tube is pretty short and you use an integrated headset so you should be OK there...
    Reputation: terrible's Avatar
    Save up and buy a mob, do the american welders a favor.
    Bikes Rule
    Mar 2006
    Quote Originally Posted by terrible
    LOL. He doesn't have enough $$ for new parts and you want him to drop an extra $200 for the Mob??
    The only issues I could think of would be the headtube/steerer tube, cranks not fitting and seatpost being out of proportion. But enough being said before me, I won't go into detail.
